Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-18-2012, 01:55 PM   #1
2011boostdwrx
Member#: 263470
Default Akuma build thread for my 2011 SWP WRX 9New 6 star speed 20GXR ball bearing turbo!
My 2011 WRX is now going through a 2011 STI 6spd swap, Stage-1 SB, Kamak 20GTX STS turbo, AP ELH, Akuma Big Maf custom intake (for the new parts).
The first block went with the standard #4 Ringland at 11K, the next SB blew out a cylinder wall on #4 (704 series casting) wih the HTA68 turbo pushing 23.5 PSI @ 350+ WHP with HSF-2 Mth kit @ 1:1 ratio.
So mods as follows:
Akuma Stage-1 SB (we are still not sure how we are going to bulletproof). New (Now stage-2 full internal build, h-beams, ACL etc., 05 STI 702 series halves)
AP Tuned Akuma Pro-Tune
2011 STI 6 spd swap with DCCD delete, Center VSD, 1:1 ratio running stock diffs and axles, TWM SS, Redline Goods Boots
ACT HDSS clutch kit w/OEM flywheel
Kamak 20GTX STS (9-blade) Turbo
FIC 800CC, 255 lph, GS EBCS
FMS FMIC, w.custom Akuma intake kit
Perrin Turbo Inlet, PTP Turbo Blanket, GS Heat Shield
AP ELH, GS Upipe
CNT DP/CBE quad tip
Aquamist HSF-2 Meth Kit, remote trunk mount
ISC Coil Over w/rear BC extenders and 6-piston BBK kit
Perrin Front & Rear sways, GT-Spec strut tower
ST-120 wheels 18x8 et48, Khumo tires
Alpine INAw910, H800, PDX-V9, CDT, JL 10W3V3
SMY w/porsport boost & EGT
Car going bach under the knife shortly as sson as the SB is figured out.
2011boostdwrx is offline   Reply With Quote
Old 10-18-2012, 03:07 PM   #2
2011boostdwrx
Member#: 263470
Old 10-18-2012, 03:09 PM   #3
2011boostdwrx
Member#: 263470
Old 10-18-2012, 03:11 PM   #4
arodarod
Member#: 335389
2013 Sti HB
It gonna be nice!!!
arodarod is offline   Reply With Quote
Old 10-18-2012, 06:28 PM   #5
russ9127
Member#: 189531
2008 WRX Hatch
Silver w/ STi spoiler
Beautiful! What lip kit is that all the way around?
russ9127 is offline   Reply With Quote
Old 10-18-2012, 06:35 PM   #6
Ultimateone
Member#: 48025
15 Mustang GT
Awesome
Ultimateone is offline   Reply With Quote
Old 10-18-2012, 07:39 PM   #7
2011boostdwrx
Member#: 263470
BaysonR CF side and rear spats, front BTA CF lip.
Old 10-18-2012, 07:50 PM   #8
ZJDizzle
Member#: 205851
2004 PSM WRX Sedan
STOCK AS F**K
why the DCCD delete?
ZJDizzle is offline   Reply With Quote
Old 10-18-2012, 07:52 PM   #9
2011boostdwrx
Member#: 263470
Didnt want to deal with the DCC controller, plus there are some reported issues with the controller and center diff at high horsepower.
Old 10-21-2012, 11:30 AM   #10
2011boostdwrx
Member#: 263470
Hve everything in ready to go, just debating what to do with the 704 series block this time. I may just chaulk it up to an anomoly and go ahead and build again. Dont know yet.
Old 11-20-2012, 08:30 PM   #11
2011boostdwrx
Member#: 263470
Quick update had the new KAmak compressor cover thermal coated red. The engine build is almost complete, New Crank, Eagle H-Beams, Weisco pistons, ACL race bearings...
Done by GSD coating in NJ awesome people over there and great price.
Old 11-20-2012, 11:50 PM   #12
bluemax189
Member#: 137405
2011 WRX
20g 6spd
looking like an amazing build so far. interested in the trans swap if you have more info.
bluemax189 is online now   Reply With Quote
Old 11-21-2012, 12:07 AM   #13
2011boostdwrx
Member#: 263470
I was going to go with the Albins gear set straight 1-2 Helical 3-5, but the housing on the 5-spd is the real problem, you can only fit a gear so big in it. So I had Rallispec build me a 6 spd that I could install using my diffs, etc as I already have 6-pot front brake upgrade, They took out the DCCD and put a viscous type center diff in. I wanted the cheapest 6-spd swap option and rallispec knew exactly what to do.
I need a new clutch naturally, flywheel, MC hose, 6 spd cover plate, shifter and linkage, rear prop shaft and adapter and trans mount and of-course the 6 spd trans. Rallispec offers awesome pricing so call them!
Old 11-21-2012, 12:13 AM   #14
Ultimateone
Member#: 48025
15 Mustang GT
Wow, building quite the animal
Old 11-21-2012, 12:22 AM   #15
cruisnhard
Member#: 254408
2008 Impreza WRX
I like the red turbo housing!
cruisnhard is offline   Reply With Quote
Old 11-21-2012, 10:29 AM   #16
2011boostdwrx
Member#: 263470
Thanks it has been a long long road with this car!
Old 11-22-2012, 09:03 PM   #17
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
i've seen these turbos on ebay. i havent seen any reviews though, do they look like a good product?
anthony12052 is offline   Reply With Quote
Old 11-22-2012, 09:56 PM   #18
2011boostdwrx
Member#: 263470
Kamak turbos are not on ebay at least last time I looked, this was a direct order form Kamak, they have an awesome rating and reliability record. They are sold under many rebranded names though. This is the STS 9-blade wheel with the billet compressor wheel.
Old 11-23-2012, 03:27 AM   #19
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
oh, could of been mistaken. the turbo looks legit though, cant wait to see what your car does with it bolted on!
Old 11-23-2012, 11:28 AM   #20
2011boostdwrx
Member#: 263470
We are shooting for 375-400 WHP, I was at like 360+ with the HTA68 turbo at 24 psi, so hoping for a little less cylinder pressure with the larger 20 G and a few more WHP. Torque is no problem now with the STI 6-spd swap.
New mods form the HTA are:
AP ELH, GS up pipe, 3" custom intake, speed density tuning, non catted DP and few other odds and ends!
I also went weith the older 702 series block because of the latest cylinder cracks in the 704 series. Lets keep our fingers crossed.
Old 11-24-2012, 10:26 AM   #21
2011boostdwrx
Member#: 263470
This is what I went with in the motor:
New STI/WRX Crank (Heat treated)
Weisco forged pistons w/coated skirts
Eagle H-Beam rods
ACL Race Bearings
Killer Bee Windage Tray & Oil Pickup
OEM Subaru Gasket kit
OEM oil pump
STI Oil Cooler
702 series case halves out of an 05 STI (trying to get away from the 704 series)
Decked the stock WRX heads cleaned etc.
AP ELH w/GS up-Pipe all DEI Titanium Wrap w/DEI silicone sealer
Kamak GTX-20 STS Turbo w/thermal coated compressor
Akuma custom 3" intake
AEM 3.5 Bar MAP
Aquamist HSF-2
Old 12-04-2012, 10:53 PM   #22
2011boostdwrx
Member#: 263470
updated new block going together
Old 12-11-2012, 09:15 PM   #23
2011boostdwrx
Member#: 263470
Some more assembly pics
Some slight turbo fitment issues, but working that out! Didnt know it, but the turbo comes with a spacer plate etc.
Old 12-14-2012, 02:30 PM   #24
2011boostdwrx
Member#: 263470
Kamak Turbo update:
Old 01-03-2013, 09:24 PM   #25
2011boostdwrx
Member#: 263470
Update custom Akuma big maf intake for all FMIC setups, looks awesome strong solid mounting just a great intake, maximized straight area right before MAF to maximize street drivability!!
Better pics here: http://forums.nasioc.com/forums/show...239333&page=11
