Old 10-18-2012, 04:46 PM   #1
colorfull
Member#: 136688
2005 Impreza RS
Default Water pump: Bosch or OEM?
Gathering all I need for my clutch/timing belt/cams replacement:
- Gates timing belt kit
- Exedy KSB04 clutch
- Delta 1000 cams
and...
I was set on getting an OEM water pump from SubaruGenuineParts for 73$, but there are some Bosch water pumps for 50$ on Amazon...
Am I better off with the OEM for 20$ more, or is the bosch a better choice?
Thanks!
colorfull is offline   Reply With Quote
Old 10-18-2012, 04:51 PM   #2
Alistairh
Member#: 268286
2011 STi
Dark Grey
is the Bosch a direct factory replacement?
Either way, both are reputable names imo.
Alistairh is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 07:42 AM.
