Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 10-19-2012, 02:57 PM   #1
Charlton
Member#: 43038
2002 Forester S
Default Just Installed Fram Filter; Am I Screwed?
So at Auto Zone they were running a special today for a 5 qt of oil and a Fram filter for $20.
It's the orange Fram filter.
I'm driving a 02 Forester with 155K miles.
I plan on changing the oil every 3K miles
So am I screwed using the orange Fram filter?
I looked online and evidently there are some bad reviews.
Charlton is offline   Reply With Quote
Old 10-19-2012, 03:08 PM   #2
nogreatloss
Member#: 328620
2006 STi
Your engine is now destroyed. Ill take it off your hands.
nogreatloss is offline   Reply With Quote
Old 10-19-2012, 03:56 PM   #3
JohnM10
Member#: 244231
2006 Impreza 2.5i 5M
Crystal Grey Metallic
I wouldn't worry about it. I prefer the Purolator PureOne filters (PL14612). I get them through Amazon and I buy my oil at Wallymart. I used a Fram filter in the past when I realized I ran out of my Purolator filters and I had already drained the oil. I have an Autozone within walking distance.
JohnM10 is offline   Reply With Quote
Old 10-19-2012, 04:12 PM   #4
aeoporta
Member#: 334126
2013 5mt Sp Premium
Venetian Red & Dark Gray
ahhh fram, RUNNNN!!!!
aeoporta is offline   Reply With Quote
Old 10-19-2012, 04:22 PM   #5
cmiovino
Member#: 134005
2004 WRX Premium
My dad ran Frams on our '95 for years and years before handing it off to me - no issues. I've done a TON of research on oil filters, cut them apart, and all that.
In general, I found the Pureolator PureOne to be as good as people say they are with the metal end caps. The OEM Subaru blue ones were made of cardboard only, but this stuff was tough! The Fram one was noticably less sturdy as compared to the OEM one.
I run Pureolators on all my cars. Synthetic for mine, PureOne for our Forester, and the Classic for the Camry. Great products.
Old 11-23-2012, 11:42 AM   #6
travisamorgan
Member#: 327502
2007 Impreza 2.5i
what about using the fram tough guard silver ones?
Last edited by travisamorgan; 11-23-2012 at 11:42 AM. Reason: mistyped a word bad...
travisamorgan is offline   Reply With Quote
Old 11-23-2012, 01:25 PM   #7
gdoggmoney
Member#: 158150
2007 Impreza 2.5i
Newport Blue pearl
Take it off if you are worried. I would not go redlining the car all over and abusing it but it should be ok. Thousands and hundreds of thousands of cars run them with no issues immediate -- perhaps just long term wear.
gdoggmoney is offline   Reply With Quote
Old 11-23-2012, 01:27 PM   #8
lavid2002
Member#: 226864
Lol, all those reviews make me laugh. Too much time on their hands really. I love using the fram filters because of the grippy surface, they work fine. I drive my car pretty hard too.
Don't sweat it. If cars spun rod bearings from fram filters, do you think they would stay in business? I have been using them forever.
lavid2002 is offline   Reply With Quote
Old 11-23-2012, 02:34 PM   #9
Pickler
Member#: 301247
09 Impreza 2.5i MT
i used fram once on my TL and it was fine. their only problem is durability so just don't prolong your OCI and should be fine.
Pickler is offline   Reply With Quote
Old 11-25-2012, 01:05 AM   #10
1RareBreed
Member#: 338706
2004 RBB Flat 4
Just change to something besides fram next oil change... Your fine
1RareBreed is offline   Reply With Quote
Old 11-25-2012, 09:54 AM   #11
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
I doubt you hurt the engine, but Fram oil filters are about the worst filter you could use, unless they have improved.
A few years ago, the parts guy at a Moto Guzzi dealer cut a few filters apart to compare the insides. Seems many Guzzi riders are cheap! Anyway, the Fram is a lot cheaper then the UFI filter Guzzi uses. IIRC, he tested three or four filters, but I don't remember the others.
The UFI easily had twice as much filter media as compared to the Fram by having more pleats folded into it. Also there was the filter media itself. The Fram allowed debris of a larger micron to pass through it. (Didn't filter down to as fine as the others.) Then there was the pressure (bypass) valve that is inside. I don't remember if the Fram had it but took less for it to bypass or didn't have it at all. On the UFI, the filter media was glued on the ends with metal caps. The Fram used a "cardboard" material to attach the edges of the filter media. It was simply a cheap filter!
The absolute cheapest thing you can do to any engine is proper maintenance, period! You have to understand that cutting corners like this generally does not cause a catastrophic failure. Sometimes maybe, but usually just premature wear is a result of inferior oils and filters. The only way to know for sure down the road is compression testing, and oil analysis, short of disassembly and using a micrometer to measure and visual examination of the bearing surfaces for scoring. Plain bearings rely on a film of oil to seperate the moving surfaces. If debris can pass through the filter it is like having sand between the mating surfaces. Not as drastic, but you get the idea.
It is kind of one of those you can pay me now or pay me later type of things. Me, I refuse to have a Fram oil filter on any of my vehicles. I always used Bosch on my old WRX. For now, I'll probably use the Subi filter on the '13.
To each his own, but you did ask.
John
Guzzi 1 is offline   Reply With Quote
Old 11-26-2012, 02:48 PM   #12
FstEddie22
Member#: 10938
2001 Impreza 2.5RS
Silverthorn Metallic
Hmmm. Never realized there were so many bad reviews for Fram filters. I've always used the Tough Guard ones because of the grippy ends. My car is a 2001 with 180,xxx miles and I've never had a problem. Change my filter with my oil every 3K-5K miles. Like everyone says, if you are worried about it just change it next time.
FstEddie22 is offline   Reply With Quote
Old 11-26-2012, 04:05 PM   #13
cmiovino
Member#: 134005
2004 WRX Premium
The tough guard ones are completely different internally from the regular ones... in fact, they're actually good. Metal end caps and all that jazz.
With that said, the OEM blue Subaru ones have paper end caps. Left one in for 6k miles and dissected it... perfectly fine. Fram ones are made in the same factory as the OEM blue ones, just to a little bit different spec.
Basically, it's not the end of the world, but for a few bucks more, I like the piece of mind of knowing I have something like Purolator on there.
Old 11-26-2012, 04:52 PM   #14
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
I thought Honeywell made the fram filters, just as they make the blue Subaru filters.
alt14 is offline   Reply With Quote
Old 11-28-2012, 07:44 AM   #15
dropride
Member#: 337059
Ive changed plenty of oil in subies that people had fram filters on and none of them had problems
dropride is offline   Reply With Quote
Old 12-03-2012, 10:30 PM   #16
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
I had a Tough Guard in for around 4000 miles for my last oil change and I had no issues with it.
pkL is online now   Reply With Quote
