Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 10-19-2012, 04:23 PM   #1
Charlton
Member#: 43038
2002 Forester S
Default How Much Torque on Oil Pan Bolt?
Changed oil today and torqued down the oil pan bolt pretty tight with my ratchet. How tight is too tight. I changed the oil with the car on the ground so it's not like I gave the bolt my full body to torque
Charlton is offline   Reply With Quote
Old 10-19-2012, 04:25 PM   #2
shamrocker
Member#: 258219
2011 WRX Limited
WR Blue Pearl
33 ft lbs, I believe.
shamrocker is offline   Reply With Quote
Old 10-19-2012, 06:22 PM   #3
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
^ Somwhere around that, plus or minus a few foot-lbs
chazly413 is offline   Reply With Quote
Old 10-19-2012, 07:54 PM   #4
Charlton
Member#: 43038
2002 Forester S
So is this a lot of torque?
Old 10-20-2012, 01:24 AM   #5
chazly413
Member#: 151079
2005 2.5RS RBP
Not particularly, no.
Old 10-22-2012, 02:35 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
In the words of the Germans, it is guten tight
Old 10-22-2012, 07:37 PM   #7
GrundleJuice
Member#: 165749
I usually use my German tq wrench on fasteners like that. Even tq across the sealing surface is more important than the actual number, especially with a liquid gasket.
Old 10-22-2012, 07:46 PM   #8
Kraakmo
Member#: 332518
2009 Impreza OBS 5mt
Silver on Silver
for the 01-09 Forester with 2.5 N/A Engine, it is indeed 33 ft-lbs
Kraakmo is offline   Reply With Quote
Old 10-22-2012, 07:47 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Liquid gasket? Does your car not use a crush washer?
As for the torque spec, I'm with Matt - guten tight. I'm pretty anal with using a torque wrench to get the proper torque on things, but pulling out a torque wrench for the oil drain plug seems a bit excessive.
Old 10-22-2012, 07:47 PM   #10
Brainstormtuning
Member#: 335005
2004 Subaru STI
did you replace the crush washer?
Brainstormtuning is online now   Reply With Quote
Old 10-23-2012, 06:31 PM   #11
Tmibiker
Member#: 328048
2002 Impreza 2.5TS
Midnight Black Pearl
According to the factory manual for my '02 Impreza, 33ftlbs (44Nm) is the spec'd amount of torque for the drain plug bolt on the SOHC engine.
Tmibiker is offline   Reply With Quote
Old 10-23-2012, 06:50 PM   #12
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Just to see one time I used my tourqe wrench and the ring crushed at about 31lbs so I'd say that just tighten till the rings crushed and you should be fine
alt14 is offline   Reply With Quote
Old 10-25-2012, 01:03 PM   #13
ALX4247
Member#: 336103
2000 Legacy GT
I had to wrestle mine off once. must have had 100lbs of tq on it. Last time I let jiffy lube touch my car.
I assume they over tighten it so that the chances of it coming out and them being liable for the damage is deceased.
ALX4247 is offline   Reply With Quote
Old 10-25-2012, 01:19 PM   #14
alt14
Member#: 271928
2014 WRX Limited
Nope just liable for striping your threads lol
Old 10-25-2012, 01:53 PM   #15
ALX4247
Member#: 336103
2000 Legacy GT
my buddy had the treads on his pan half way stripped. luckily it wasn't the bolt. An impact gun on a regularly serviced bolt is just ridiculous.
Old 10-25-2012, 03:17 PM   #16
alt14
Member#: 271928
2014 WRX Limited
Impact guns other than untightening is a bad idea
Old 10-25-2012, 03:56 PM   #17
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
I had the same issue with it after a dealer did the 60k. You'd think they would know better.
Counterfit is offline   Reply With Quote
Old 10-25-2012, 07:25 PM   #18
GrundleJuice
Member#: 165749
I read the original post and saw "oil pan bolt" thinking the bolts that hold the pan to the case.
Old 10-26-2012, 03:36 PM   #19
ALX4247
Member#: 336103
2000 Legacy GT
Thinking people know anything is setting yourself up for disappointment.
Old 10-26-2012, 03:58 PM   #20
Counterfit
Member#: 124254
"The Scoobinator"
Too true.
Old 10-27-2012, 04:59 PM   #21
Tromix
Member#: 335024
2007 Impreza
thanks for this thread, i actually looked this thread up on my phone earlier today
Tromix is offline   Reply With Quote
