Old 10-20-2012, 04:19 PM   #1
K2e2vin
Member#: 308481
2005 Legacy GT
Default Cam timing teeth; VR vs. Hall position
Does anyone know if the cam on the timing teeth between the JDM EJ20 VR setup and the USDM EJ25 Hall setup are "synced" the same? As in, if you were to use a signal converter(similar or the same thing as what standalones use to convert VR signal into a digital signal) would the trigger timing be the same?
K2e2vin is offline   Reply With Quote
Old 10-20-2012, 07:38 PM   #2
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
That is a good question, I don't thing anyone has done enough signal processing to know for sure.
Might be a question for some of the manufacturers than make cams for both.
lukeskywrx is offline   Reply With Quote
