Notices
Old 09-20-2015, 12:09 PM   #1
fl1p
Member#: 407265
2015 ISM WRX
"Rolla'rex"
Default 2015 WRX v7 JDM 6spd Swap
After a long wait period, I finally pulled the trigger and swapped the stock '15 WRX trans for a v7 JDM STi trans (code TY856WB1CA). Shoutout to Wais over at Japan Domestic Imports for hooking me up with the trans and rear diff.
A massive thank you to @carnz-pj-410 for turning wrenches (see: actually doing the swap), putting up with me, and being an awesome friend.
Status: Completed
Diffculty: Medium.
Technical Knowledge Required: A lot
Notes: Time consuming, but it all fits like a glove. Lots of special tools required (esp. if you rebuild the trans)
Parts list (incl. part numbers and rough MSRPs)
  • Trans* (r180, trans, driveshaft) TY856WB1CA $2,900.00
  • Group N Shift Assy C1010FG600 $296.00
  • Shift Plate Boot 35038AG081 $23.00
  • Boot and Insulator 35016AG030 $45.00
  • 2x Clamps 35057AE000 $2.00
  • 4x Flange Pilot Bolts 010008200 $3.32
  • Cover Assy F STI** 92121VA090 $268.00
  • TiC Holy Shift Bushings $100.00
  • Beatrush Trans Mount $168.00
  • Perrin Motor Mounts (set) $369.00
  • 2x 08-14 STI Rear Axles 28421FG022 $598.00
  • Clutch Disk 30100AA920 $127.46
  • Pressure Plate 30210AA670 $131.21
  • Release Bearing 30502AA130 $109.27
  • 6MT Gasket Set 32001AA210 $85.65
  • Synchro Set 32650AA081 $86.80
  • Baulk Ring (x3) 32614AA111 $34.20
  • Synchro Set 32650AA110 $86.36
  • Synchro Set 32650AA120 $86.80
  • Lock Nut 802645010 $22.35
  • Lock Nut 802628030 $14.91
  • USDM STi Flange for r180 38358AA040 $105.42
  • '15 STi Drive Shaft 27111VA010 $592.83
  • STi Starter Motor
* You don't need the driveshaft that comes with the trans. See the last two items on the parts list.
** Optional. The stock WRX trim piece works just fine.
The following parts are optional, but are included in the above parts list. We pulled the trans apart to inspect it and replace synchros. Upgraded shift bushings etc aren't required, but it made sense to do it all at once.
  • Trans mount
  • Engine Mounts
  • All Synchro sets
Parts cost: Roughly $5,500
Photos
http://imgur.com/a/9025L
Videos
Coming Soon (tm)
fl1p is offline   Reply With Quote
Old 09-20-2015, 12:09 PM   #2
fl1p
Member#: 407265
2015 ISM WRX
"Rolla'rex"
Notable Tid-Bits (questions that got direct answers in the thread)
Originally Posted by Wannabe WRX View Post
The 2015 hub units will not bolt onto earlier Imprezas. The rear suspension bolts on the hubs differently than they do for the GD units.
Originally Posted by carnz-pj-410 View Post
this is a non-dccd trans, there are V7 DCCD transmissions and DCCDpro would work, but we chose to not use one
Originally Posted by psyclobe View Post
Yeah you need STI rear axels, front axels don't need replacing
Old 09-20-2015, 10:32 PM   #3
chrislisss
Member#: 429979
2004 Impreza WRX
Looks clean
chrislisss is offline   Reply With Quote
Old 09-23-2015, 01:22 PM   #4
paprocjo
Member#: 387947
2015 WRX - Premium
Crystal Black Silica
Can you run the dccd with this?
paprocjo is offline   Reply With Quote
Old 09-23-2015, 02:43 PM   #5
carnz-pj-410
Member#: 110994
2004 Impreza WRX STi
If you buy a DCCD trans you could set it up to work
carnz-pj-410 is offline   Reply With Quote
Old 09-23-2015, 06:17 PM   #6
SubieGuy84
Member#: 429483
Guess that answers the question's if the EJ and FA transmission are interchangeable. A lot of people were wondering because of the starter. Nice project
SubieGuy84 is offline   Reply With Quote
Old 09-23-2015, 10:27 PM   #7
J_mythsuby
Member#: 292113
'15 cwp rex
'12 DGM rex sold
Curious, can the DCCD pro not be made to work with the ver 7 transmission or do you need a Ver 8 to be able to utilize the differential controls?
J_mythsuby is offline   Reply With Quote
Old 09-23-2015, 10:30 PM   #8
carnz-pj-410
Member#: 110994
Old 09-24-2015, 08:52 PM   #9
J_mythsuby
Member#: 292113
'15 cwp rex
'12 DGM rex sold
Gotcha! Thanks for clearing that up.
Old 09-24-2015, 09:04 PM   #10
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Why not just sell the WRX and get an STI? Then you'll get the Brembo's and everything else.
Fierysun is offline   Reply With Quote
Old 09-24-2015, 09:39 PM   #11
carnz-pj-410
Member#: 110994
because this is what he wanted to do. also this way he has the FA20
Old 09-29-2015, 11:25 AM   #12
fl1p
Member#: 407265
2015 ISM WRX
"Rolla'rex"
I wanted the FA platform, not an EJ (hate me all you want). Also, getting an STi still wouldn't have gotten me the trans that I wanted. This way, even if I get a big brake kit, I still come in under the cost difference of the STi and have all the benefits without the cons.
Regarding DCCD, yes you can hook up a DCCD trans. This particular trans is non-DCCD - I didn't care about it/not worth the headache of hooking it up.
Old 09-29-2015, 11:27 AM   #13
fl1p
Member#: 407265
2015 ISM WRX
"Rolla'rex"
As noted in the OP, the starter has to be changed out for an STi starter (rather, a starter that matches the trans). The stock starter on the '15 wrx is the same one as is on the FA Impreza (it doesn't work with this trans).
Old 09-29-2015, 02:49 PM   #14
SubieGuy84
Member#: 429483
Yeah I noticed that. Is the that the starter does not extend out far enough or the teeth are of a different size?
Old 09-30-2015, 07:59 AM   #15
fl1p
Member#: 407265
2015 ISM WRX
"Rolla'rex"
I've just realized that my second post with more details never got posted.. I just moved to the NOVA region. Sorry for the confusion.
To answer your question, the stock starter has a differently designed shroud around the gear. This shroud was catching on the fly wheel. I have a photo that shows the difference.
Once I get Internet sorted out here, I'll upload the second and third batch of photos and get my formal writeup posted
Old 09-30-2015, 10:35 AM   #16
SubieGuy84
Member#: 429483
Gotcha, I can't wait to see all the info. I'm thinking of dropping the 15 WRX trans in an older chassis, so this is very helpful
Old 10-14-2015, 11:12 AM   #17
08subi2.5
Member#: 431844
Nice work looks awesome!
08subi2.5 is offline   Reply With Quote
Old 10-14-2015, 11:46 AM   #18
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
cool project, nice work
Old 10-26-2015, 03:53 PM   #19
wicked2002wrx
Member#: 368510
Sedona Red Pearl
very cool! I would love to see this, do you go to any meets?
wicked2002wrx is offline   Reply With Quote
Old 11-04-2015, 11:50 AM   #20
anjuna
Member#: 401977
IDFK Wat
bish whet
i like diz.
anjuna is offline   Reply With Quote
Old 11-13-2015, 09:36 AM   #21
fl1p
Member#: 407265
2015 ISM WRX
"Rolla'rex"
From time to time. I've been to the meet in Towsons, but I'm stupid busy so haven't gone lately. That said, I'm always down to get a beer/lunch/what ever and talk cars / make friends!
Old 11-14-2015, 07:30 PM   #22
CursezZz
Member#: 414974
2005 VF39 6MT WRX
Crystal Grey Metallic
fl1p is a turd who doesn't even lunch his sex sped
CursezZz is offline   Reply With Quote
Old 11-15-2015, 08:14 PM   #23
carnz-pj-410
Member#: 110994
fl1p needs to come back home
Old 11-22-2015, 07:32 PM   #24
Subadrew15
Member#: 430773
He mentions you can use a 08-15 drive shaft. I wonder if its a typo. What year drive shaft did you use exactly?
Subadrew15 is offline   Reply With Quote
Old 11-22-2015, 07:48 PM   #25
carnz-pj-410
Member#: 110994
We used a 2015 STi driveshaft, I feel like a 8-14 would work as well.
