Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-20-2013, 05:44 PM   #776
cronic
Member#: 9749
Need to make one for the BRZ
cronic is online now   Reply With Quote
Old 10-20-2013, 08:20 PM   #777
TyConway
Member#: 193189
2002 wrx
dont know anyone with a brz.... i know chasebays did a harness for one. going to chasebays tomorrow and see if we can come up with a pnp harness for the lsx in a wrx.
TyConway is offline   Reply With Quote
Old 10-20-2013, 09:05 PM   #778
johnsea
Member#: 269720
Wiring specialities out of CT makes one. That's where I'll be picking one up.
johnsea is offline   Reply With Quote
Old 10-20-2013, 09:24 PM   #779
cronic
Member#: 9749
Do you have any experience with his LSX standalone harness? A couple years back I read some negative reviews on it but not sure if he made changes.
It looks really nice and it'd be nice to use on my swap vs the gmpp standalone harness
Old 10-20-2013, 09:36 PM   #780
TyConway
Member#: 193189
2002 wrx
Yea I usually build them myself out of stock ls1 harness.
I also had issues with his first ls1 stand alone harness. Some of his pinout locations were wrong when he made the first ones. They were all corrected. The main reason I think he had issues was b/c at the time he was moving shops and the guy doing the harnesses pinned the coils and injectors backwards. No biggie once I looked at it and saw the issue.
Old 10-20-2013, 09:39 PM   #781
TyConway
Member#: 193189
2002 wrx
A plug and play harness for a wrx with a ls1 swap? There is a lot of companies building lsx universal harnesses.
Main reason Id like to get a pnp harness built is b/c from what i found on my car, you have to have the factory ecu hooked up to allow other functions in the car to work. So this would save a huge headache when it comes to wiring in a universal harness when running stock gauges. I'm running all speedhut gauges in mine, so that wont be a concern to me.
Old 10-20-2013, 09:48 PM   #782
cronic
Member#: 9749
Do you know if all this is resolved?
I'm not here to bash other compaines either but, what's wrong with Chase? nothing really. What's right with their LS harness? nothing really. Here is a quick assesment, factually based, of course. You don't have to build your own harness, you can mod a stocker... but if you want a new one, maybe you should buy one from someone who has a working knowledge of a GM engine. How do I know he doesn't know how a GM engine is laid out? Just look at the LS1 harness he has on his website. You would think the picture would showcase his best work, right? [img width=800 height=532]http://www.chasebays.com/content/values/748/main.jpg[/img] First thing that stands out to me is that none of the connectors that require a secondary lock, actually have one. CKP is the wrong connector. O2s are the wrong connector. No reverse lights connector. Knock sensors, VSS and reverse lockout are on the wrong side. Harness looks to be set up for F body PCM, but has a connector for a Vette oil pressure sensor, which any swapped car will not use. No AC circuits. Why are there 2 branches for the driver side injector/ignition bank? Looking at his subharnesses, he doesn't have one pictured for the FD. ??? but looking at the others, Single speed fan operation with a relay that will literally melt if you tried to power a Taurus fan. Relays are ziptied together??? He also lumps all of the key-on power circuits into one circuit. What does that mean? If your O2 heater wire (for example) melts to your exhuast (which is probably the most common wiring mistake for swappers), and pops your ignition fuse, you can call the tow truck. If your power circuits are separated, if the same situation happened, you would loose your O2 heaters. If your engine is already warmed up (and I'm guessing it is, since the headers were hot enough to melt wire insulation), you'll never know, until you get home and let the O2s cool off. Same goes for any other power circuit (except for the PCM circuit). The engine may run bad with one popped fuse, but at least it will get you home and you'll be able to scan for codes. GM uses 5 (non emission) circuits for their harness ignition power. I use 6. My point is that if I were to need a harness for a Honda swap, Chase would be the first I call. LSanything swap? Not so much. Have a peek here. http://www.norotors.com/index.php?topic=5167.0
Old 10-20-2013, 10:38 PM   #783
TyConway
Member#: 193189
2002 wrx
I will ask him tomorrow in person and go over it with him and see what is going on. Its been 2 yrs since I've messed with his ls1 harness.
Old 10-20-2013, 11:42 PM   #784
cronic
Member#: 9749
Please do.. Because if it is all sorted out I will buy one right now..lol
Old 10-21-2013, 11:09 PM   #785
TyConway
Member#: 193189
2002 wrx
Chase was out sick today, but I'll let you know when I get to talk to him.
Old 10-22-2013, 07:03 PM   #786
moss
Member#: 10197
you buy a BRZ or something ?
moss is offline   Reply With Quote
Old 10-22-2013, 07:03 PM   #787
TyConway
Member#: 193189
2002 wrx
Got down to Chasebays today... I can certainly tell his business has grown... quadrupled in size and products in the shop. The lsx harness has been revised since the first one we used and any issues with the connectors were updated. Also we went over the harness and it seems as a Plug and play harness is do able... Its gonna require running the stock ecu and an ls1 ecu. You have to tie the two together for everything to function inside the car. So more than likely he will be able to offer a Plug and play setup for the wrx chassis.
Old 10-23-2013, 12:19 PM   #788
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
Cool. Ty could you pm me a diagram of what the stock ecu has to run if its not engine related? I am wiring a vipec in to my wrx to run a dual avcs motor as standalone. I still want my cruise and dash, etc. to work.
Thanks,
James.
slowgenius is offline   Reply With Quote
Old 10-23-2013, 12:52 PM   #789
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Sweet! When will this be available? I'm wanting to do a ls wagon very soon! Also how do you plan on tuning the ls?
dburgoon is offline   Reply With Quote
Old 10-23-2013, 04:01 PM   #790
cronic
Member#: 9749
No...better...lol Just think the BRZ would be more fun with an ls...
Yea that is exactly what I am going to do. Run the GM as a standalone harness and leave the "other" ecu in place.. Mount the coolant temp, oil pressure etc in the GM block and all that will plug right in to the stock harness.
Basically the GM harness runs all the engine functions, and "other" runs all chassis functions.
Old 10-23-2013, 09:27 PM   #791
TyConway
Member#: 193189
2002 wrx
on Hptuners, I have the hptuners pro software.
Old 10-23-2013, 10:22 PM   #792
omiotek
Member#: 272090
hpt is the way to go for that. for our hybrid computers we use ls edit..
omiotek is offline   Reply With Quote
Old 10-23-2013, 11:56 PM   #793
SkullV
Member#: 357798
2003 WRX
I miss my HPtuners. Being able to do so much, so easily was such a nice thing to have. Then I went to VW where you couldn't touch anything (until very recently). Haven't messed around with the Subie yet. Can't wait to see this thing up and running!
SkullV is offline   Reply With Quote
Old 10-24-2013, 03:10 PM   #794
cronic
Member#: 9749
Wish HPT had map switching though. Kind of annoying to be locked into one map.
Old 10-24-2013, 08:50 PM   #795
TyConway
Member#: 193189
2002 wrx
Thanks,
James.
I'll see what i can do...
Old 10-25-2013, 10:44 AM   #796
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Did you ever hear back from the company after the interviewing day?
Rene2.5RS is offline   Reply With Quote
Old 10-25-2013, 01:22 PM   #797
TyConway
Member#: 193189
2002 wrx
Yea, offered part time... turned it down. not driving there 5 days a week or more for only 4 and 5hr shifts.
Old 10-25-2013, 01:36 PM   #798
CptTripps
Member#: 371033
This is a great thread.
Ironic for me. I'm pulling a Chevy V8 OUT of my Porsche 914 and replacing it with an EJ20.
CptTripps is offline   Reply With Quote
Old 10-25-2013, 02:04 PM   #799
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Don't blame you. Sucks that it happened that way. Here's to the new venture!
Old 10-25-2013, 02:09 PM   #800
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
Thanks man! With your talent and experience, im sure you will be able to get steady work. If a company cant appreciate that then that is thier loss.
