Old 11-07-2012, 10:02 PM   #76
TyConway
Member#: 193189
2002 wrx
would have sum more but i cant find my digital camera... also was hoping to have a rolling chassis this week, but got down to my last control arm and i noticed i had a left hand thread heim.. instead of a right hand. So gotta wait for the correct heim to come in. But everything is coming along slowly.. hang in there, i'll get some good pics up.
TyConway is offline   Reply With Quote
Old 11-08-2012, 09:48 PM   #77
eastwoodsn352
Member#: 334442
2008 WRX STI
Man, This looks awesome!
eastwoodsn352 is offline   Reply With Quote
Old 11-08-2012, 11:51 PM   #78
TyConway
Member#: 193189
2002 wrx
Thanks!
Old 11-09-2012, 11:56 AM   #79
Paidfor
Member#: 267815
Be in awe
dont hate .)
Hey im a few hrs away from you buddy.........id love to see this thing in action
Ive got a 04 STi thats just beggin to have this done.
Paidfor is offline   Reply With Quote
Old 11-09-2012, 08:42 PM   #80
stock-tswagon
Member#: 117257
Which dimension of the LSX does not fit with an AWD driveline? It has been a battle trying to find actual dimensions of both engines with auxiliaries bolted on. Kennedy engineering makes an adaptor that has been used in old Porsche conversions.
stock-tswagon is offline   Reply With Quote
Old 11-10-2012, 10:33 AM   #81
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Although this is not my thread, I'm pretty sure the front axles would be pushed too far back from the front hubs due to the added length of the v8 over the flat 4. A quick measurement of block depths with timing assembly attached PLUS the adapter plate would net the rough distance the Subaru trans would have to move back. If viewing from the bottom of the car (car in the air) the front axles on a stock Impreza go straight out to the hubs. Now imagine the transmission is pushed another 10" back and the front axle would then have about a 36-42 degree angle to meet with the hub. I would guess the exaggerated angle would not be good for the setup for articulation. I'm not a drive line expert, but that is my thought/bet/$0.02.
After thought: the transmission tunnel would need to be redone since things are very tight to start with (6MT especially), including the entire lower firewall. The heater core lies directly behind the firewall on top of the tunnel so it would not fit again.
Stephen Clark
IA Performance
phone: 520-882-2821
www.iaperformance.com
www.facebook.com/iaperformance
IA Performance is offline   Reply With Quote
Old 11-10-2012, 02:19 PM   #82
TyConway
Member#: 193189
2002 wrx
Stephen Clark
IA Performance
phone: 520-882-2821
Thanks for clearing it up for everyone... yea there is no extra room to move the ls engine around... its very tight... have to take in consideration of the steering rack, transmission placement so the shifter will work,and then height of the engine, and clearance of the oil pan... also with the clutch master cylinder mounted on the opposite side of the brake master cylinder, the clearance between the head and the clutch master cylinder also comes into play... theres been nothing easy on this build. My main thing is keeping my steering geometry right. I want a good driving car.
Old 11-10-2012, 04:40 PM   #83
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Stephen Clark
IA Performance
phone: 520-882-2821
Yoar doing it wrong,
Keep the transmission / axles where they are and push everything forward.
Handling would suck, cooling it would be a PITA, but it would work
Old 11-11-2012, 12:26 AM   #84
TyConway
Member#: 193189
2002 wrx
yea, just cut the core support out and take the front bumper off, move the radiator somewhere, yea it would work great...haha
lol please no more awd crap... if someone wants it, spend the money and do it yourself, then you will find out.
Old 11-11-2012, 01:56 PM   #85
uberspeed
Member#: 87871
I agree. This is the same reason that Audi went through such efforts to shorten their 4.2L V8 in the B6 S4. It is said to be 10" shorter than an LSX. They were able to do this by moving the timing components to the back of the engine and going with siamese bores. You could get this to fit in a Subaru with AWD I bet but there would be little point in doing so of course.
Stephen Clark
IA Performance
phone: 520-882-2821
uberspeed is offline   Reply With Quote
Old 11-12-2012, 04:33 PM   #86
lgt2000
Member#: 140073
2005 LGT
Red
Would he be willing to make more? I am putting in a 6.0L with a T56 in my Legacy and I dropped the rack about an inch and have been looking for something like this
Awesome project by the way. I love seeing other Subaru LSx projects especially since it gives me good ideas for my fabrication.
Originally Posted by TyConway View Post
This is a part my friend machined out for me. It replaces the lower ball joint. Reason being is I'm running heim joints on my custom made A-arms that work with my cradle setup, and also the length and mounting position of my A-arm will fix the steering geometry caused by lowering the rack and pinion. But this made my day when he sent me a pic of it machined out. Now if my Dom tubing would come in so i can fab the control arms!!!
Also the heims im using are Heat Treated 4130 Chromoly Heims with Kevlar liners, very tight tolerance and very strong,radial static rating of 18,000 lbs or so. Way more than the factory ball joint would ever hold up to.
lgt2000 is offline   Reply With Quote
Old 11-12-2012, 05:40 PM   #87
03boxer4
Member#: 66622
2002 WRB wrx - Sold
Big White Jeep Unlimited
Fap Fap Fap Fap
03boxer4 is offline   Reply With Quote
Old 11-12-2012, 07:01 PM   #88
TyConway
Member#: 193189
2002 wrx
Wont work with factory control arms and also it doesn't correct the steering geometry.
Old 11-13-2012, 08:55 AM   #89
lgt2000
Member#: 140073
2005 LGT
Red
Ahhh thats too bad but your subframe and LCA's are going to look awesome when completed
Old 11-13-2012, 08:58 PM   #90
RallyBot 6.0
Member#: 337195
Maroon/black
i keep finding myself searching this thread for new pics and info. can you please hire a group of elves to get some damn work done. lol.
RallyBot 6.0 is offline   Reply With Quote
Old 11-13-2012, 10:08 PM   #91
TyConway
Member#: 193189
2002 wrx
Work has been getting done... just had a bunch of customers cars and I also work another job. Really haven't taken any pics. Ill go take some since my internet got hooked up yesterday.
Old 11-13-2012, 11:07 PM   #92
SpinningAllFours
Member#: 332829
This build is nuts! You are one insane man.
SpinningAllFours is offline   Reply With Quote
Old 11-14-2012, 01:34 AM   #93
TyConway
Member#: 193189
2002 wrx
Old 11-14-2012, 01:35 AM   #94
TyConway
Member#: 193189
2002 wrx
Old 11-14-2012, 01:38 AM   #95
TyConway
Member#: 193189
2002 wrx
control arms are 1.25" OD and .250 wall. Really overkill but nice to work with. There are three weld passes on the piece. 1 Fusion, then 2 filler passes. fully welded up.
Old 11-14-2012, 01:40 AM   #96
TyConway
Member#: 193189
2002 wrx
Old 11-14-2012, 01:43 AM   #97
TyConway
Member#: 193189
2002 wrx
Old 11-14-2012, 01:47 AM   #98
TyConway
Member#: 193189
2002 wrx
Fuel Cell Time
Old 11-14-2012, 01:52 AM   #99
TyConway
Member#: 193189
2002 wrx
Control arm randoms ... 1/4" wall Dom 1.25" OD
After the first fusion weld pass
Old 11-14-2012, 08:24 AM   #100
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Subscribe
Swine is offline   Reply With Quote
