Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 03-13-2014, 01:18 AM   #1026
Corythomulka
Member#: 384359
have you run into any other issues in this build? i could imagine the wiring wouldnt be too bad but what about the firewall and trans? did everything line up well? I've always wanted a LSx swapped car, this thing is gonna be sweet!
Corythomulka is offline   Reply With Quote
Old 03-13-2014, 01:27 AM   #1027
Goneau
Member#: 362269
2006 WRX
CGM
Just skimmed through this thread and must say you do some amazing work sir! definitely sub'd
oh and lawyer up man! best thing you can do!
can't wait to see more
Goneau is offline   Reply With Quote
Old 03-13-2014, 02:57 AM   #1028
TyConway
Member#: 193189
2002 wrx
Just removed the trans mount off the firewall, I also modded for the clutch master cylinder for the reservoir to be mounted flush. I notched the passenger side frame for 4" down pipe clearance. Trans fit like a glove, like it was meant to be, shifter fit the console perfect. If injuries and money would allow, Id have it finished by now, its like 1 step forward, 3 back. But it will get there.
TyConway is offline   Reply With Quote
Old 03-20-2014, 01:13 PM   #1029
aspitfire
Member#: 59916
2004 STi
Keep up the great work man, sorry to hear about the continued issues. You are a nice guy, but sometimes you have to look out for yourself.
I will vouch that his work is amazing, he fabbed up some steering arms for my '67 Datsun Roadster and it came back better than i expected!
Keep in touch, and if you need anything you have my number!
aspitfire is offline   Reply With Quote
Old 03-20-2014, 08:06 PM   #1030
johnsea
Member#: 269720
Ty just wanted to say thanks for posting up your build and giving me a push in the right direction towards my build. My work is no where as top notch as yours but it's great to see the quality stuff you produce and give guys like me something to shoot for. Just wanted to share a picture of what you definitely helped one guy with.
Thanks again and keep up the good work.
johnsea is offline   Reply With Quote
Old 03-20-2014, 09:06 PM   #1031
TyConway
Member#: 193189
2002 wrx
Dang looking good. I want to tube my front as well but I don't think I will go that far with mine for now.
Old 03-22-2014, 05:28 PM   #1032
bridgestone24
Member#: 268817
2009 Stg 2+ HB WRX
Amazing work to you both. Ty, can't wait for the day when your beast is running. Still following this thread.
bridgestone24 is offline   Reply With Quote
Old 03-22-2014, 11:53 PM   #1033
TyConway
Member#: 193189
2002 wrx
I did this a few weeks ago, tacked together a-arm, and tried on some new from knuckles on the wrx, think it may work out, just have to do a few more mods
Old 03-23-2014, 12:59 AM   #1034
Brandon2k13
Member#: 376571
I drive a car,
and I quite like it.
This build is amazing. Kudos to you for having the know-how and drive to follow through. Certainly on another level of unique.
Brandon2k13 is online now   Reply With Quote
Old 03-23-2014, 09:51 PM   #1035
traction issuez
Member#: 86559
2005 RS Wagon
Will new knuckles be needed for your cradles?
traction issuez is offline   Reply With Quote
Old 03-23-2014, 11:47 PM   #1036
TyConway
Member#: 193189
2002 wrx
Nope, you can use stock ones. I was just trying some new stuff, Since my rear knuckles use the bolt on hub bearings, I bought a s14 5 lug conversion kit, since the 350z axles are the same spline as the s14 hub. So i converted my car to 5x114 on the front with that s14 front knuckles that are flipped, so it was easier to just run s14 parts. No redrilling and machining hubs to run 5x100.
Also I haven't forgot about you, meant to send you a text over the weekend. I never could find any machine shop to cut the parts out that I needed so I purchased a lathe for my shop. Should be here tomorrow or tuesday. Should have your setup finished with in a week.
Old 03-28-2014, 10:42 AM   #1037
turbospooled
Member#: 371535
Awesome build! Cant wait to see it done!
turbospooled is offline   Reply With Quote
Old 03-28-2014, 05:20 PM   #1038
TyConway
Member#: 193189
2002 wrx
finally got around to the sway bar install and tabs on the control arms. I cut custom aluminum spacers for the heims, so where ever the a-arms are adjusted to, you can just rearrange the spacers to realign the adjustable sway bar links.
Also don't mind the mess in the shop, having to rearrange everything so stuff is laying everywhere.
Old 03-29-2014, 12:46 AM   #1039
TyConway
Member#: 193189
2002 wrx
This is my other hobby, this was from back in January. My buddy just posted it up.
Old 03-29-2014, 01:08 AM   #1040
SexyWRXy43
Member#: 311562
Pretty sick set of hobbies you have. Seems like a pretty enjoyable life, glad some people take the time to do stuff like this. Nice vid. Also, bang up job on the sway bar mounts and a-arms!
SexyWRXy43 is offline   Reply With Quote
Old 04-03-2014, 10:58 AM   #1041
TyConway
Member#: 193189
2002 wrx
I had a question on my steering adapters, how I lengthened them. Posting pics for all to see.
Old 04-03-2014, 12:31 PM   #1042
momotaro19
Member#: 339524
02 wrx
Where is that cave, Ty? I'm in Decatur, just north of you-that looks cool!
Frank.
momotaro19 is offline   Reply With Quote
Old 04-03-2014, 11:03 PM   #1043
3mlwhly
Member#: 217648
01 2.5rs
Really digging this build... I'm always check ing it for updates... Oh and that cave was insane. I'm not sure I'd go in more than 50 feet
3mlwhly is offline   Reply With Quote
Old 04-04-2014, 07:44 AM   #1044
TyConway
Member#: 193189
2002 wrx
Frank.
Its in Hayden. In the video there are two different caves and the last visit was to a mine shaft in bradford Al. Theres a good bit of caves in Huntsville, The NSS headquarters is in Huntsville.
Old 04-04-2014, 09:31 PM   #1045
forced1nyc
Member#: 312130
2013 Outback
Please make sure to finish this project...
forced1nyc is offline   Reply With Quote
Old 04-07-2014, 08:10 AM   #1046
TyConway
Member#: 193189
2002 wrx
I woke up to a storm this morning and headed to the shop this morning at 4:30AM to find the ditch behind my shop overfilled and washed out. My neighbor had a water line ran to her house and a guy dug the hole through the bank of the ditch. But it wasn't packed back down and the pipes going under the drive way were semi blocked. But when I got to my shop had almost a foot of water flowing through it. Numerous items and tools are soaked, I opened all my roll up doors and it got the water level down. Rain has stopped for now but have another line of storms coming in a few hrs. Never had it flood this bad. I took pics of everything that I could, gotta see if insurance is going to cover anything. Makes me sick thinking about what all could be ruined.
Old 04-07-2014, 09:01 AM   #1047
SexyWRXy43
Member#: 311562
Right when I feel like your luck is turning around... That is terrible. Hopefully everything will get sorted out. I want to see those pics. I'm interested.
Old 04-07-2014, 01:57 PM   #1048
Type2
Member#: 200436
2004 Forester XT
Wow. You've had a string of bad luck. This is just crazy.
Type2 is offline   Reply With Quote
Old 04-07-2014, 05:16 PM   #1049
aspitfire
Member#: 59916
2004 STi
Man sorry to hear about yet another set back for you. I hope for the best, and that insurance will cover what was lost.
Old 04-07-2014, 06:02 PM   #1050
TyConway
Member#: 193189
2002 wrx
Got lucky and the rain held off the rest of.the.day... Just gotta dry everything out
