#126 |
Member#: 338539
Incredible project, definitely subscribing this one!
#127 |
Member#: 331355
South East
Vehicle:2003 Legacy Outback black and blue |
What part of birmingham are you located? I would love to see this in person
#128 |
Member#: 140073
South East
Vehicle:2005 LGT Red |
Diff is looking nice in there. Have you figured how you are going to get axles made up. The R200 is one of my options as well
#129 |
Member#: 193189
Vehicle:02 wrx silver |
#130 | |
Member#: 193189
Also the 350z R200 is not the same as other r200's found in other cars. The 350z / g35 R200s are larger, and everything inside and out, ( even housing) is larger. I have a R200 out of 240 and the 350z R200 is just a beefed up HD unit. Going tomorrow to dig around my friend salvage yard. An nissan armada has a 9" ring gear diff. May have to see how much larger that differential is physically. But my 350z Diff barely has enough clearance from the axle hubs and the control arms, and it should hold up to the power no problem. Been looking a other v8 swapped 350z's with turbos and they are running mid 10's and acutally ripping the differentials out of the mounting locations and not hurting the differential. |
#131 |
Member#: 184151
International
Vehicle:2000 STI RA Limited Blue |
That tie rod spacer scares me. I would definitely reinforcing it somehow. A company called 6gun made a roll adjustment kit a few years back and had several break. Their kit was a 50mm drop, yours looks like more than that.
Check out this thread to see what I'm talking about. http://forums.nasioc.com/forums/show...highlight=6gun Sick build by the way! I can't wait to see it in action. |
#132 |
Member#: 184151
International
![]() Something like that would be ideal. |
#133 | |
Member#: 140073
South East
I see, I have been working with Moser as they made the axles for the V8 Miata we are working on. I also have a R200 from an 08 350z from one of my friends cars sitting at the shop and it had the rear cover stud broken off due to wheel hop
#134 |
Member#: 331355
South East
Im located in the trussville/clay/pinson area so if you ever need help just hit me up.
#135 | |
Member#: 193189
![]() ![]() Its only 3/8" thick at the small point, i know the load is applied at a different angle on that, but I still don't have any concerns with my spacer. I saw the thread about the breaking part, I actually bought some similar for my rx7, they are cast and very brittle. More than likely that car that was pictured, was autocross and hit a hole or slid off the track, then you would expect damage like that. Last edited by TyConway; 11-28-2012 at 01:53 PM. |
#136 | |
Member#: 193189
Probably due to the very soft bushings, Im going to upgrade mine and put another stud on the oppisite side of the cover. |
#137 |
Member#: 193189
got 1 turbo manifold semi mocked up.... just to get the turbo placement, also still got 1 runner to add on.
#138 |
Member#: 210633
Vehicle:02 wrx |
do you have enough space to run the downpipe through there? also it doesnt seem you have much space for a wastegate unless you tuned it down to the bottom. seems like you are gonna have some fun with that =)
#139 |
Member#: 283298
Vehicle:2007 STi UGM |
Subscribed!
Could just run the exhaust out of the quarter panel ![]() |
#140 | |
Member#: 193189
Pictures just make it look tight, theres actually a lot of room Last edited by TyConway; 11-29-2012 at 04:46 PM. |
#141 |
Member#: 193189
#142 |
Member#: 193189
#143 |
Member#: 210633
Vehicle:02 wrx |
ooooo so you are doing a twin scroll set up, now it makes sense, i thought you were going twin turbo. why not just throw a 42r instead of that precision?
#144 |
Member#: 236952
Vehicle:2010 WRX Spark Silver |
I thought twin scroll needed equal length headers though? There's no way to have equal length with the available space and the turbo in that location.
#145 |
Member#: 34773
South East
Vehicle:2009 WRX WRB |
You're My Hero.
#146 |
Member#: 193189
#147 |
Member#: 193189
#148 |
Member#: 337195
NWIC
Vehicle:2002 WRX Maroon/black |
lookin good dude. wish i was in the area id totally do grunt work around your shop just to get a chance to help with this and gain some knowledge lol
#149 |
Member#: 268190
TXIC
woah i think this is the best subaru ls build. plus you are probably the first to put a turbo on it as well. MOAAARRR.
#150 |
Member#: 193189
