Old 09-09-2002, 08:35 PM   #1
Szm426
Member#: 11679
Default alternative to cobb stage 3 block and heads?
I want to do an engine build-up and i really like the cobb stage 3. But its very expensive, is there any other alternative wheere i can get the whole deal?anyone have experince with any stage from cobb? or hear anything about it?
Szm426 is offline   Reply With Quote
Old 09-10-2002, 07:37 AM   #4
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
Default Re: Re: Build up alternative
Originally posted by FloridaWRX
why not just post it ?
I agree. Post something. I am interested in the same issue. I went to your website, some cool stuff there but not WRX. Have you done WRX engine buildups? Examples? Customer cars?
tolnep is offline   Reply With Quote
Old 09-10-2002, 08:50 AM   #5
Subdued
Member#: 15904
05 Impreza
09 Tribeca
Question
Did anyone email MZM?
Subdued is offline   Reply With Quote
Old 09-10-2002, 10:09 AM   #6
chuckles
Member#: 2955
02 Chuck Wagon
Oh yea its white
don't be afraid to spend the money with Cobb... you'll be happy.
i did some GC8 stuff with them.. and if I could afford it I'd do the GD stuff with them too.
chuckles is offline   Reply With Quote
Old 09-10-2002, 11:28 AM   #7
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
Well.. I just got a 2003 WRX so I am investigating stuff now.. I would love to spend the money with Cobb.. but for the long block alone, before any external stuff you are talking about around 10K for the engine before its installed.... add a STI six speed upgraded turbo, ECU, intercooler and a few other goodies and now you have a 50K automobile.
What I would sort of like to do long term, is build a bigger engine from available junkyard parts (with the correct machining of parts before installation) for a lot less money.
Old 09-10-2002, 11:44 AM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Just because I know you guys don't usually get into AFI much...
http://forums.nasioc.com/forums/show...hreadid=230182
Old 09-10-2002, 12:46 PM   #9
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
A most interesting thread. When I was doing Datsun stuff, I took the time to find a good machine shop that was recommended by all the local Datsun tuners. I talked to the guys at the shop and did conservative things. I did all the assembly myself after cleaning the block for the last time and painting it (the machine shop hot-tanked it of course but I went through it one last time to remove any metal particles). I checked each thread and used taps to debur them before final torguing. And I used engine pre-lube on all parts cranks etc. I didn't have micrometers but I did have the machine shop verify each bearing and write down the clearances. I always ended up with solid motors and I saved a bunch of money because I did all the heaving lifting, assembly and dis-assembly. And I enjoyed taking my time with the re-build. I've heard stories like this before. It can be very expensive...
That's why I would like to do the same sort of thing if I build up a motor for my current car.. Save money, learn something about the motor, and have a carefully assembled motor in the end...
Old 09-10-2002, 02:34 PM   #10
Subdued
Member#: 15904
05 Impreza
09 Tribeca
I agree, I have built a few GM V8's and I don't see why I couldn't take on a Subaru rebuild also. If you utilize a good machine shop and take your time it is not that difficult. You do have to realize anything you may miss though could cause a catastrophic failure. Even if it were the machine shops fault it would be hard to prove.
Old 09-10-2002, 02:49 PM   #11
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
Helps to have a machine shop with experience in the motor you are working on. Each motor has its peculiarities and things that you want to do with a rebuild. If a machine shop has experience with racing or high performance engines with your chosen block then its just a matter of talking with them to make sure they understand what your goals are and you understand what needs (or doesnt need) to be done. Of course a local machine shop helps a whole bunch. In Atlanta there are a number of shops with experience with various V8s. I used to use Sunbelt performance for Datsun motors. They had all kinds of experience. I will have to start looking around to see if anyone has Subaru skills. Seems like all the long term experts are mostly in Australia thoug.
Cobb Stage 3 SOHC heads WRC 555 1993 - 2001 Impreza Specific Parts 6 11-20-2007 10:53 AM
Cobb stage 3 map.. or switch to utec 03WRX83 Engine Management & Tuning 5 09-09-2004 10:45 AM
Cobb Stage 3 head ChAi Normally Aspirated with bolt-on Forced Induction Powertrain 7 04-24-2004 06:15 PM
Want to build a 400WHP honda motor. What Block and Head Combintation to use. STEALTH-WRX Off-Topic 44 01-26-2004 08:10 PM
STI vs Cobb stage 3 short block ChAi Normally Aspirated with bolt-on Forced Induction Powertrain 6 11-01-2003 06:29 PM
