#151 |
Member#: 333446
NESIC
Vehicle:2013 Impreza SL CVT DGM |
#152 |
Member#: 333446
NESIC
actually - it's looking like you don't really need to jack the car up to change the oil. this guy just gets the car on some 2x4s and reaches under there.
http://blogs.insideline.com/roadtest...il-change.html does this seem like it's pretty doable? I'm wondering if he's reaching from the front or from the side to get to the drain... Last edited by M45; 11-27-2012 at 10:03 AM. |
#153 | |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
#154 | |
Member#: 322264
Just part of my process that I don't want to eliminate by not sliding under the car. FWIW. |
#155 |
Member#: 346408
Vehicle:2013 Outback |
I purchased a 12 pack of filters and washers from Subaruonlinarts.com. I believe the cost was around $75.
#156 |
Member#: 346793
NWIC
Vehicle:2002 RS swap WRX PSM |
fumoto valve or quick oil drain valve which i think is what there company calls them now, but its deeefinetly the way to go. First time doing the oil change i accidentally over filled but a 1/4 quart and jus throw a small pan under it, flip the lever, let it drain for 5-10 secs, click it back. Done. I can do full oil change in 10 - 15 mins depending how long it takes to drain since its a smaller hole its draining from. but no having to replace crusher washer.
