Old 10-22-2012, 01:14 PM   #1
vnikulin
Member#: 134247
2012 STI
Default high speed jerking in auto cdiff mode
really need help on this please
just started noticing that in "auto" c-diff mode while driving on freeway the entire car jerks, almost feels like you hit a bump sort of, even passenger can feel this. i deal with this situation now just by switching to lock manual mode and moving cdiff all the way down.
took my car to local dealership and was not able to replicate the problem because in NYC you just can't drive steady for few minutes on parkway 70mph without hitting any bumps or getting pulled over however mechanic that went with me told me that this doesn't sound like cdiff because if it was mechanical problem that i would've heard grinding or noise of some sort at any speed and if it was due to failing sensor i'd get "service engine" light .... can anyone suggest what this might be? clutch? (mechanic did suggest that clutch pedal was high)
thanks !!
vnikulin is offline   Reply With Quote
Old 10-22-2012, 07:42 PM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
thanks !!
I would suggest searching in the correct forum (transmission/driveline). You will certainly find many threads about center diff binding/jerking but usually it's during slow tight turns. Is this on an STi or a swap with DCCD system?
Old 10-22-2012, 08:23 PM   #3
vnikulin
Member#: 134247
2012 STI
sorry, i tried searching for cdiff jerking etc but nothing came up, this is 2008 STI, all stock ...
i came across some articles suggesting problems during slow speeds but this is completely opposite, all happens during 70mph+
