Old 10-22-2012, 04:16 PM   #1
subiVeritas
Member#: 179349
02 2004 WRB STI
09 ZX6R
Default Overheating Issue
Im having a overheating problem that i can't figure out. First off its a 04 sti with stage 2 cobb tune and supporting mods. The problem started this morning on my way to work when i blew a radiator hose about a hour into the trip. So i waited 3 hours on a parts store to open only to replace the hose and try and continue on my way. New hose on and refilled antifreeze and i was off only to make it about a mile and the temp gauge shot right back up and continued to peak before i got pulled over. I turned the heat on to try and cool it off but it was blowing cold air which was odd since the car was overheating. I pulled over and tried to get help then ended up having to eat a tow bill home. I replaced the thermostat as a go to cheap quick fix since it fit the symptons but no luck and i am now stumped. Any help would be greatly appreciated.
subiVeritas is offline   Reply With Quote
Old 10-22-2012, 04:33 PM   #2
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
You need to bleed the air pocket out of the cooling system. If it is blowing cold air when you turn the heat on, then there is definitely an air pocket in the heater core....
2Fast4U1DAY is offline   Reply With Quote
Old 10-22-2012, 05:09 PM   #3
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
Air pocket.
Hoon Goon is offline   Reply With Quote
Old 10-22-2012, 05:19 PM   #4
subiVeritas
Member#: 179349
02 2004 WRB STI
09 ZX6R
Thanks for the help, I'm working on "burping" the system and its been going for about 20 minutes now still releasing air, does this seen normal?
Old 10-23-2012, 10:18 AM   #5
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
absolutely.
mechatricity is offline   Reply With Quote
Old 10-23-2012, 04:13 PM   #6
MRGierut013
Member#: 328260
2005 STi, 2004 RSX
i-Vtec just kicked in yo!
Burp it!
MRGierut013 is offline   Reply With Quote
