Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Old 10-22-2012, 07:47 PM   #1
ghostdog
Member#: 317893
2013 Sti Se
Orange
Default 2012 wrx dp install
So I'm installing a invidia downpipe on my wrx, and I bought a grimmspeed turbo heatshield. But what about the shield that is underneath on stock downpipe. It doesn't fit with my invidia downpipe. Does it for somehow or do I no need it?
ghostdog is offline   Reply With Quote
Old 10-22-2012, 08:53 PM   #2
hutch959
Member#: 267463
im not positive... but i think that needs to come off. did on my sti
hutch959 is offline   Reply With Quote
Old 10-22-2012, 09:27 PM   #3
ghostdog
Member#: 317893
2013 Sti Se
Orange
Any problems since its been removed?
Old 10-22-2012, 09:45 PM   #4
BigRob74
Member#: 305107
2012 wrx
360/386 E85
you dont reuse any of the heatshields from the factory downpipe. just wrap the dp in some DEI wrap, get a turbo blacket and use the gs heatshield, you will have better protection than oem..
BigRob74 is offline   Reply With Quote
Old 10-23-2012, 07:50 AM   #5
white240hatch
Member#: 95556
2012 WRX 5dr
i had to remove all factory shields on the downpipe. i just ran the heat wrap all the way down to the end. proably better then the facotry metal ones any how.
white240hatch is offline   Reply With Quote
Old 10-23-2012, 08:15 AM   #6
Ying
Member#: 166490
2011 WRX
You mean the existing turbo heat shield? You can trim it with shears or a dremel and make it fit, but a turbo blanket and that Grimmspeed heat shield should be enough in my opinion. Sorry if that's what what you're speaking of. I haven't gotten to the DP on my 2011 yet. Soon.
Ying is offline   Reply With Quote
Old 10-23-2012, 11:18 AM   #7
bacalhau16
Member#: 297565
2011 WRX hatch
I installed my dp on my 2011 without re using any shields. I do have my dp wrapped in heat wrap, but nothing is on my turbo at all currently. I am looking to heat wrap that as well however.
bacalhau16 is offline   Reply With Quote
Old 10-23-2012, 05:18 PM   #8
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
That lower heatshield that is attached by two little 10mm bolts under the downpipe flange?
You'll want to have that on because it gives you one attachment point on the left side lower part of the grimmspeed heatshield. Without it you risk rattling annoyance.
HeroCrank is offline   Reply With Quote
Old 10-23-2012, 10:16 PM   #9
ghostdog
Member#: 317893
2013 Sti Se
Orange
Yeah I figured it out last night when I actually got to the install. Thanks for the help though
