Old 10-22-2012, 08:10 PM   #1
fullCircling
Member#: 290547
Default 97 Legacy - FULL '08 STI Conversion possible? (stock ECU, VCD, 4 ch ABS, si-drive)
I want to run all of the stock '08 sti systems in a '97 legacy. VDC, si-drive, 4 channel ABS, etc. I'm good with wiring, and I'll be doing it in pieces if its possible. So, is it possible?
The first stage is to get the bare minimum in the car to PROPERLY run the '08+ STI ECU with dual AVCS heads.
What's the minimum I'd need to convert to properly run dual avcs with the stock ECU? Can any of the systems that are ECU (VDC, si-drive, ABS?) controlled be disabled by a competent tuner until I install them?
This is a serious discussion, I'm not some kid who has no idea of the amount of labor involved. I got time and resources to get 'r completed. Any real help would be appreciated.
-Jon
fullCircling is offline   Reply With Quote
Old 10-24-2012, 05:42 PM   #2
robduf
Member#: 171837
1999 2.5 RS
Orange-Black
I think you are going to run into the same issues us Impreza RS owners have when doing a conversion to STi. Harness is so different that you are have to do a full swap or a lot of rewiring. Like staying up till 3am all week crying because nothing is working right lots. I believe you have an OBDI (that changes to OBDII in 1998) That could be an issue for your areas emissions requirements, you’ll want to do some research there.
Thinks to investigate:
• Custom brake lines for the ABS have to use the STi’s system for this.
• Rear suspension shock mounts might be too small for the new STi rear end.
• Custom peddle mounting for fly by wire
• You’ll need to use the STi Dash that will need to be custom fabricated.
• You aren’t going to be able to use the STi gas tank and evaporator system, which will toss a CEL, will need custom work.
• You’ll need to do some custom pipe work because the exhaust is longer on the Legacy.
This is me just talking out of my ass about it; all my swaps have been done on 1999 to 2001 RS from 2004-2007 donor cars.
I’d love to see it work out. Do you already have a 08 donor car picked out?
robduf is offline   Reply With Quote
Old 10-26-2012, 03:09 AM   #3
fullCircling
Member#: 290547
nah, im prob not gonna get a donor car until later. im gonna do the work in stages.
phase 1: gonna build a dual avcs 257 motor first, build a custom wiring harness for it and the stock 08+ ecu, and install the bare minimum to make the ecu run the dual avcs correctly. get a tune, and get whatever i can disabled on the ecu so there's less to install to get the car to run. i may even run higher compression cp pistons, so i can get away with running it n/a until i piece together the turbo stuff.
phase 2:find a rolled or totalled 08 shell with no motor (possibly one that still has a trans), and start swapping stuff like the 4 channel abs system, suspension, dccd bits, cluster, si drive etc.
ultimately, i want a very capable, somewhat sleeper car that can tackle anything. mud, rain, snow, DDing, autox etc. a low key subaru that is cheaper on insurance, but will perform just as well as a new sti. full sti si drive and dccd controls, complete w/ sti cluster in the same legacy dash, the newer 4 channel abs system, and front and rear helical lsds. then maybe later on if i come across a better, newer shell i'll swap it all over. i'll make all of the wiring easy to work on and transfer to another car if need be.
that's the plan anyways, and you know how those usually go...hahaha
Old 10-26-2012, 03:17 PM   #4
MMY MSL
Member#: 335135
2007 WRX
WRC blue
From what I've read the 08+ STI uses a canbus computer system that is markedly different from the 04-07 STI, the ECU requires readings from a number of sensors placed around the body of the car constantly to run properly. If the sensors are missing, or not reading properly you are probably going to have all kinds of CELs and gremlins on your hands. While wiring it might be possible, unless you're a professional with a lot of spare time and knowledge I can't see why you'd opt to tackle this.
Personally I also don't see enough benefit from the dual AVCS to justify all the extra risk and headache that the swap might constitute vs a single AVCS ej255 or ej257. And this statement: "ultimately, i want a very capable, somewhat sleeper car that can tackle anything. mud, rain, snow, DDing, autox etc. a low key subaru that is cheaper on insurance, but will perform just as well as a new sti." doesn't seem to indicate a need to try something more complex than a built EJ25 with an upgraded turbo. If you're sold on the DCCD system, look at DCCDpro, it's an aftermarket controller available in manual or automatic for the 04-07 STI 6 speeds.
Also I believe 96+ USDM cars are all OBDII.
That's my 2 cents.
MMY MSL is offline   Reply With Quote
Old 10-27-2012, 12:02 PM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
Not worth going for an 08 in a 97 legacy, the 07 STi subframes front and rear will bolt up to your 97 with no issue where as the 08+ is very different and will not bolt up in the rear at all making it not possible to use the rear suspension/hubs etc that is also needed to work with the ABS Canbus system.
Save yourself a lot of headaches and just go 07 Sti at the newest IMO.
Ben
Old 10-29-2012, 12:25 PM   #6
05subysti
Member#: 268190
2005 STi
^^^ he is right. just go with an 07 sti power and drivetrain. youll also have the best gear ratio as well.
05subysti is offline   Reply With Quote
Old 11-23-2012, 05:03 PM   #7
fullCircling
Member#: 290547
I just picked up a set of dual avcs heads out of a 2010 LGT, anyone know what ECU I should use?
Old 11-23-2012, 05:07 PM   #8
fullCircling
Member#: 290547
...aftermarket or oem. whatever will run the dual avcs properly
Old 11-23-2012, 07:01 PM   #9
PHATsuby
Member#: 13617
2001 Legacy GT back
No offense but do you have an actual strategy and know how these parts will fit together?
The 2010 LGT has a drive gear on the heads to drive the oil sump for the turbo since it is mounted below the engine, just curious if you know if that will matter or if it's easy to block off because it may cause headaches that would be avoided with 08 STi heads.
I think aftermarket is the only way to go at this point really, it will be quite an ordeal to get the canbus system working and if you are mixing and matching parts that could add other twists.
Ben
Old 11-23-2012, 07:31 PM   #10
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
The 08 STI ECU uses Immobilizer. It will not work without the other modules present and the keys meant for the system. AS well as the ignition cylinder with antenna. You would have to swap the entire wiring from a donor car. The GR chassis is greatly different than the earlier GD or GC's. It will make the swap extremely difficult. It is much more cost effective to swap in an 04 STI engine and driveline. If you want the dual AVCS you can get an aftermarket controller to control the exhaust cams along with the 04 ECU. You can swap in the abs from an 04 STI as well. You may need to make custom brake lines to fit the legacy chassis. The SI drive is just a silly gadget so not worth the hassle of installing, all it does is change the throttle profile.
jake
KONKILR is offline   Reply With Quote
Old 11-24-2012, 02:35 PM   #11
fullCircling
Member#: 290547
No, I'm still coming up with a strategy by posting threads like this. See, you've just informed me about the oil scavenging system on the heads, someone else has I know that an '07 sti subframes will bolt right up, and yet another has said that si drive isn't worth adding.
See? It's coming together, I got this. Thanks for the help guys.
