Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 10-23-2012, 10:43 PM   #1
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Default Ewg question
So i am going to go with a ewg set up soon and i already have a 3 port hooked up and also have a greddy profec b in my car but not hooked up. Could the use of my mbc and 3 port ebcs work for a hybrid set up wit the ewg. This is on stock turbo 06 sti and main used for ewg is to control boost better cuz with just the 3 port im slightly overboosting.
Coreycarlile911 is offline   Reply With Quote
Old 10-23-2012, 11:25 PM   #2
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Its actually a profec type s
Old 10-24-2012, 08:02 AM   #3
07pearlwht
Member#: 212576
2007 impreza wrx sti
pearl white
There is a way to make the hybrid system work, although I've never seen it done with the manuel boost controller you have. And yes it will work with the ewg.
If you're over boosting with the 3 port, you need your WGDC adjusted
07pearlwht is offline   Reply With Quote
Old 10-24-2012, 08:26 AM   #4
wrxlaunch
Member#: 181298
02 , Vf43 Inside..
12 seconds at a time
3port isn't the reason It's overboosting... It's the tune. With the mbc u won't hear as much bleeding from boost control...
wrxlaunch is online now   Reply With Quote
Old 10-24-2012, 10:52 AM   #5
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Ya idk I had cobb tune it for me and also have maps they made for me that adjusted wgdc and still it always spikes up to 20+. So they said next step is ewg.
Message Board Statistics All times are GMT -4. The time now is 09:32 AM.
