Tire & Wheel Forum sponsored by The Tire Rack |
10-24-2012, 11:35 PM | #1 |
Member#: 97732
RMIC
Vehicle:2004 STi 65 Nova 8.80@151 |
245/40/17 on a 17x8 +45
Looking at getting this tire set up on a set of rpf1's.
Just want to be sure I won't have any rubbing issues with them. Since they'll be my summer set up I'd like to run as meaty of a tire as possible with out having to do all the fender rolling nonsense.
10-24-2012, 11:42 PM | #2 |
Member#: 234407
Vehicle:04 Self-tooned STi |
I'm running 245/45/17 on a 17x8 +48 or 45 drag dr-31 on Coilovers and am 13" from center wheel to fender with 1.75 camber on all 4 corners. No rubbing issues at all with bumps and hard cornering...
If its a WRX it is a tall tire but for an STi it's a good size.. Ill be going to a 255/xx/17 next and raising the rear 1/2"... maybe some 5mm spacers. |
10-24-2012, 11:53 PM | #3 |
Member#: 97732
RMIC
I'll be on an 04 sti. I'm running dpec's with a mild drop so the same dimensions as the stock struts with the perches etc.
I read through the entire fitment thread and didn't find a thing unfortunately. |
10-25-2012, 12:56 AM | #4 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
10-25-2012, 04:32 AM | #5 |
Member#: 239270
NWIC
Vehicle:2005 Saab 9-2x Aero silver |
10-25-2012, 09:05 AM | #6 |
Member#: 97732
RMIC
10-25-2012, 09:10 AM | #7 |
Member#: 72891
Vehicle:2018 STI 99 2.5RS 2dr - 2017 XV |
You will rub in the rear unless you roll the rear or add negative camber.
10-25-2012, 10:10 AM | #8 |
Member#: 97732
RMIC
Hm two people say I won't rub and one says I will.
10-25-2012, 10:25 AM | #9 |
Member#: 51684
I'm running SSR Type C that are 17x8.5 48mm offset with 245/40/17. Had to roll the rear fenders.
10-25-2012, 10:52 AM | #10 |
Member#: 97732
RMIC
My main reason for asking is a buddy of mine just bought an 05 with the exact set up I've mentioned in the first post, there's no rolling done to the fender well.
What's the largest tire I can run on a 17x8 +45 and be safe from rolling / modifying fenders? |
10-25-2012, 10:58 AM | #11 |
Hoodbridge!
Moderator Member#: 560
Vehicle:2006 STi, 16 Outback Crystal Gray, Silver |
The '05+ has slightly more room in the rear fender because of the small flares. The '04 doesn't have that. A simple roll of the rear fenders will allow you to run these tires. Why not just do it? If you don't want to roll, stick with a 225/45-17.
10-25-2012, 11:15 AM | #12 |
Member#: 97732
RMIC
Thanks for the info..I'll look into finding someone local that can roll the rears if I go that route.
10-25-2012, 11:29 AM | #13 |
Member#: 51684
I had a set of RPF1s for a short time that was 17x8 and 45mm offset. They came with 225/45/17 and from the look of it, I probably could've ran a 235/45/17 and still clear.
10-25-2012, 11:52 AM | #14 |
Member#: 97135
NWIC
10-25-2012, 12:00 PM | #15 |
Member#: 97732
RMIC
Which I am..not much but I am
10-26-2012, 11:03 PM | #16 |
Member#: 40579
Vehicle:2002 WRX Stage 2+ Tuned by IA Performance |
I run 245/40-17s on my +45 RPF1s with D-Specs/RCE Blacks and it never rubs, even during autoX.
10-26-2012, 11:27 PM | #17 |
Member#: 97732
RMIC
Looks like I'll just have to get the wheels and tires mounted and see what happens. I found a guy who can roll the rears if need be.
10-30-2012, 12:44 PM | #18 | |
Member#: 167278
NWIC
Vehicle:2018 WRX STI DGM 2011 WRX WRB |
Im running a set of 245/40/17 general as-03's on the 17x8 +45 rpf-1's as well only time i have a slight rub is when i have adult passengers in the back, but for the most part its gutted and dont have a single rubbing issue. and im on cobb springs, but also have other suspension stuff done as well. |
10-30-2012, 01:26 PM | #19 | |
Member#: 72891
10-30-2012, 02:56 PM | #20 |
Member#: 97732
RMIC
The majority of my buddies are huge dudes luckily their big asses don't fit in the back of my car so I never get stuck driving. I'll just get the rears rolled by the local shop and forget about it. Rolling the rears is only going to cost 20 bucks per side so it's not a big deal.
10-31-2012, 08:22 AM | #21 |
Member#: 167278
NWIC
on the black trim that comes on the back wheels arches. no concern to the tire it self since it is rubber and i don't have adult passengers in the back of my car often.
so if i were to remove them then no. most dont have that trim anymore anyway. with them on yes. if you plan on going wider later, then i would recommend your route and rolling them anyway and then you won't have to worry in any case, trim or not. Last edited by Rabid_Machina; 10-31-2012 at 08:29 AM. Reason: details |
