Old 10-25-2012, 12:49 PM   #1
vic-gc8
Member#: 298909
1995 STi VII type-RA
White, on white wheels
Default Clutch not disengaging, pressure plate?
So. Driving my dad home from dropping his car off for its 60k service my car starts to judder lightly, and the clutch engagement point moved to like 1/4 inch from the floor when the engagement point has been about half way. At this point it then became very difficult to get into gear and when it did get into gear the car would shudder, somewhat violently. Even with the clutch on floor it took two hands to get it out of gear. And then the pedal started sticking to the floor and not returning.
Problems i think it could be and would appriciate assistance in narrowing them down.
Transmission - dont think so as the car rows thru gears without issue when the car is off,
Some part of the clutch -pressure plate most likley, maybe master cylinder if i am really lucky...
Any other thoughts or expriences similar to this to help trouble shoot would be great
vic-gc8 is offline   Reply With Quote
Old 10-25-2012, 12:51 PM   #2
blessthekellen
Member#: 273859
MY98
WRX
Start simple.
Bleed your clutch first, see if that helps.
blessthekellen is offline   Reply With Quote
Old 10-25-2012, 02:17 PM   #3
vic-gc8
Member#: 298909
no luck. i'd like to at least have an idea of what it might be so i can have an idea of what parts i might or might not need to start looking for? ahh the joys of JDM
Old 10-25-2012, 02:39 PM   #4
sethy
Member#: 318156
2001 RS
Rubber clutch line ballooning?
sethy is offline   Reply With Quote
Old 10-25-2012, 02:48 PM   #5
vic-gc8
Member#: 298909
not that i can see
Old 10-25-2012, 06:39 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
bad master or slave cylinder
Old 10-27-2012, 12:16 AM   #7
Ammata
Member#: 155819
2004 Impreza WRX
I've got the same problem......but my car will still go into gear, my mechanic told me pressure plate, your problem is somewhat different
Ammata is offline   Reply With Quote
Old 10-27-2012, 01:39 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
If bleeding does not help and clutch 'feel' is very light, maybe clutch lever detached from released bearing?
Marnix is offline   Reply With Quote
Old 10-27-2012, 07:07 PM   #9
Ammata
Member#: 155819
2004 Impreza WRX
Yea........ummmmm just tried to do a pull on the highway on my car and clutch slipped so I think imma just do a new clutch
Old 10-30-2012, 02:38 PM   #10
chadwickog
Member#: 310912
2001 2.5 rs
BRP
this.
chadwickog is offline   Reply With Quote
Old 10-30-2012, 05:23 PM   #11
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
This is the correct answer. My RS did it, all of them do at some point. Go ahead and replace them both when you do it. Should be less than $120 for both from an auto parts store.
GGSimpreza is offline   Reply With Quote
Old 10-30-2012, 05:53 PM   #12
Ammata
Member#: 155819
2004 Impreza WRX
Would the clutch slip if its not getting enough pressure from the master cylinder? My clutch disengages 3/4 of the way up and feels weaker than when I first had it installed
Old 10-30-2012, 11:43 PM   #13
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
Well if it's not a full out leak, it may not be acting consistently, so its hard to tell. I thought you said it stuck to the floor though, moved only 1/4"?
Old 10-30-2012, 11:59 PM   #14
xhengmanx
Member#: 144425
I had to replace my little brothers clutch fork. He was driving around and then clutch pedal fell to the floor. would come up very slowly and only came up like an inch or so if that and would not engage or disengage. Had it towed to the dealership i work at and inspected and found right away the clutch fork was broken like a wishbone. replaced the clutch fork and throw out bearing and now its as good as new.
xhengmanx is offline   Reply With Quote
Old 10-31-2012, 12:01 AM   #15
xhengmanx
Member#: 144425
I also thought it could have been the flywheel prior to the clutch fork breaking because the car would have what felt liek major clutch shudder which is a common issue with flywheels that get resurfaced and is to thin or light weight flywheels.
Old 11-01-2012, 08:32 AM   #16
chadwickog
Member#: 310912
2001 2.5 rs
BRP
I would start with the slave and master cylinder as these will be your cheapest fixes, and are likely an issue.
The slave cylinder sits right on top of the transmission behind the intake manifold. If your clutch is sticking, you can look at the slave cylinder and see if the piston is pushing up against the 'fork' sticking out of the transmission. It should be a tight connection and you won't be able to move it. If it isn't, and you can grab it and move it around, then your slave cylinder is bad.
I'd at least start there.
