Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 10-25-2012, 09:19 PM   #1
subarufan555
Member#: 255117
2000 RS
RED
Default Cant download the map from ECU!!!
I got this 07 STI I got it with bunch of Mods on it...
Took off the big/bad turbo I put everything back to stock except down pipe exhaust , front mount inter cooler. Perrin Intake.
I want to download the map that is one the ecu ( CAR RUNS LEAN 18.45 AFR IDLING!!!) CHECK ENGINE LIGHT IS ON TO lean CODE.
BUT I CANT CONNECT WITH ECU!!! I keep on getting ERROR CODE right after start down load.
Im using OPEN SOURCE Tactric cable 2.0.
Any Help will BE GREATLY APPRECIATED
subarufan555 is offline   Reply With Quote
Old 10-25-2012, 11:08 PM   #2
jthatch12
Member#: 321715
03 Big 16G WRX
Have you accessed the ecu before? Or do you know if possibly it could be locked by a tuner?
jthatch12 is offline   Reply With Quote
Old 10-26-2012, 08:44 AM   #3
subarufan555
Member#: 255117
2000 RS
RED
That can be the case...Im not sure it came in with a blown engine so I rebuild it and put it back to stock.
If indeed it is done with Ecutec or Cobb do you think if i bring it to Subaru dealer thy will be able to put the stock map on there or will I have to get a new ECU?
I Can attempt to put a stock map on it myself BUT it might lock the ECU due to Immobilisers on 07 STI's.
Is there anything that can be done IF it is Tuned with ECUTEC???
I know a way if it is with Cobb which i will tray today.
Old 10-26-2012, 09:56 AM   #4
jthatch12
Member#: 321715
03 Big 16G WRX
Subaru will charge you $90 to try to unlock it. To remove the ecutek lock on my ecu, I was able to marry and unmarry a cobb ap to my ecu. That removed the lock, I've since then gone open source
Old 10-26-2012, 10:05 AM   #5
subarufan555
Member#: 255117
2000 RS
RED
I will tray that....I have a Cobb AP on 04 STI I will go ahead and un marry it and marry it to 07 and them remove it right a way and see what happens.
Old 10-26-2012, 10:16 AM   #6
jthatch12
Member#: 321715
03 Big 16G WRX
Good luck buddy, let me know how it goes
Old 10-26-2012, 10:56 PM   #7
subarufan555
Member#: 255117
2000 RS
RED
I fixed it by marring and unmarring a Cobb AP to it. so now it is on a stock map.
But I have a few codes I need to turn off with Open source
1. The evap system code ( I have the heads holes pluged ) and pumps just sucking on Fresh air...
Then some how I got the Rear 02 sensor showing P0037 REAR O2 SENSOR LOW INPUT???It happened right after i downloaded stock map on it..Go Figure
Can I turn OFF this code and dont worry about rear 02 sensor or I have to replace it?
My main question is_____When I download stock map from the ecu With Open Source to erase the codes. DO I HAVE TO PUT THE MAP BACK ON THE ECU TO RESTART THE CAR WHILE IM MODIFYING THE MAP (FOR ANY REASON) ON THE COMPUTER???
OR IT DOESN'T MATTER I CAN HAVE THE MAP DOWNLOADED AND STILL RESTART THE CAR?
Thank You
Old 10-27-2012, 12:23 AM   #8
subarufan555
Member#: 255117
2000 RS
RED
Bump...
Old 10-27-2012, 10:28 AM   #9
subarufan555
Member#: 255117
2000 RS
RED
Bump...
Old 10-27-2012, 11:43 AM   #10
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
You need to pull the Rom "map" and erase the codes. Then you flash it back to the computer.
Is that what your asking?
wrxsubiemod is offline   Reply With Quote
Old 10-27-2012, 06:23 PM   #11
subarufan555
Member#: 255117
2000 RS
RED
My question was if i can pull the ROM map on my lap top and the while im working on it or just want to Flash it back to ECU like tomorrow Can I still Start the car and drive it and when Im ready then I can Flash Modified map to the ECU?
Old 10-28-2012, 02:18 AM   #12
z
Member#: 41762
04 STi
in ur Floriduh
When you "Pull" the rom, you're just pulling down a copy to your computer. (the rom is still on the ecu also)
You said you're on the stock map now, but you have a FMIC, Downpipe, and intake.
You *could* drive it like that after you grab your rom and while you're working on the map but you should really drive easy I would say. Stay out of boost as much as possible. You also need to tune it for those mods and not just erase the codes and reflash.
z is offline   Reply With Quote
