Old 10-26-2012, 03:41 PM   #1
STIMULA8
Member#: 298221
2004 WRX swapped STi
Default DYNO RESULTS: 2004 STi Built Block, JDM heads, APS FMIC, AMR T60, HKS Exhaust etc etc
Dyno: Mustang Dyno (Break in Tune)
Tuner: Owner Performance Auto Solutions
Wheel HP: [email protected]
Wheel TQ: 314wtq~
Ambient Temp: 60
Elevation: 45ft above sea level
This is my new setup, post #20 describes what happened to the old 466whp/401wtq setup...the previous owner screwed me.
Ill post pic of new dyno after 5:30 when im home from work. updated
Year/Model: 2004 WRX
EMS: Stock ECU, COBB AP V2
Short Block: EJ257 Short block 99.5 bore
Heads: V7 JDM Big Port Heads PnP, radius valve and decked
Turbo: AMR T60, 10.5cm Exhaust housing
Intercooler: APS FMIC
Meth Kit: N/A
Injectors/Fuel: 850cc Denso, Perrin Rails, 93 pump
Intake/Inlet: APS 3in hard turbo inlet, APS 83mm CAI
Headers: Grimmspeed exhaust manifold with hi-flow X-pipe, PnP
Uppipe: Grimmspeed with EWG setup
Downpipe: Moore Performance, 3in, NO wastegate side
CBE: HKS 3in
Clutch: ACT 6 puck, sprung
Flywheel: ACT streetlight
Other Power Mods: (Just a total list of everything done to it)
Engine:
EJ257 Shortblock
Manley forged pistons
Gaskets/Seals/Hardware
Gates Timing Belt Kit
2011 STi oil pump
New OEM oil cooler
New Vacuum lines/hoses/OEM PCV System components
New EVAP solenoid
New Subaru Battery
Version 7 2.0 JDM big port heads (PnP)
BC cams 280
New springs and retainers
PAS switched from MBC to EBCS
Air:
APS 83mm CAI
APS dr725 FMIC
PnP throttle body with heat coating
PnP intake manifold with heat coating
TGV delete with pheloic spacers 6mm
Fuel:
850CC Denso Injectors
Perrin Fuel rail
Walbro 255
Turbo:
APS 3in Hard turbo Inlet
AMR T60 Turbo10.5cm Exhaust Housing
* 3 inch compressor Inlet
* Fully ported exhaust housing
* Fully ported compressor housing
* OIL AND WATER COOLED!
* 38mm Tial external wastegate
Cooling:
Mishimoto Radiator with Samco hoses
GMS 170 Thermostat
Exhaust:
Grimmspeed up pipe with
HKS High power exhaust 3in
Moore Performance Downpipe 3in, no wastegate side.
Grimmspeed exhaust manifold with hi flow x pipe (PnP)
Suspension:
Perrin F&R Sway bars and end links
Whiteline anti lift kit
Tokico Shocks
RCE springs (Yellow)
Whiteline Top hats
Saggy butt spacers for the rear
Whiteline rear diff lock kit
Whiteline rear sub frame bolts
GT spec F&R strut tower bars
Drive train:
JDM 6speed swap with the r180 rear differential 5x100(48,xxx miles)
Torque solution short shifter and bushings
Torque solution rear shifter bushing
ACT 6puck HD and pressure plate
ACT streetlight flywheel (15lbs)
Cusco engine and transmission mounts
Brakes:
Brembo Brakes (4-pots)
DBA F&R Rotors
Hawk HPS pads
Gruppe S SS lines
Grimmspeed Master Cylinder
Interior/Electronics:
04 WRX to 05 STI center console swap.
05 STI gauge cluster
Sparco Toreno 2 seats
Innovate Wideband A/F Gauge
Defi Oil temp, Oil pressure, and boost gauges
Pioneer AVIC D3 head unit
Alpine Type s Components Front
Kicker speakers Rear
2 10’’ Alpine Type E Subwoofers
Alpine 4 channel amp (door speakers)
Alpine mono block amp
AP version 2
Exterior:
Rally Armor UR mud flaps
30% tint with visor
De-badged
Rota Grid (Royal Silver) 18x8.5 5x100
Falken tires 235/45r/18
STIMULA8 is offline   Reply With Quote
Old 10-26-2012, 03:41 PM   #2
STIMULA8
Member#: 298221
Old 10-26-2012, 04:27 PM   #3
inursteye
Member#: 271879
Looks fun, is this on pump gas?
inursteye is offline   Reply With Quote
Old 10-26-2012, 04:31 PM   #4
ArSoN9
Member#: 285777
2004 STi-
Nice setup! Can we see some engine bay pictures?
seems a bit laggy for a 60lb/min turbo if its not hitting peak by ~5000rpms, even with the 10.5cm hotside.
Are you planning on replacing the AMR T60r? does it have the SLR wheel? Do you have a dyno readout with boost plotted? I want to see how the turbo spools up
Keep up the good work! Awesome car!
ArSoN9 is offline   Reply With Quote
Old 10-27-2012, 11:13 AM   #5
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Just curious on what kind of boost #s it took to get there? And what type of fuel?
looking good.
wrxsubiemod is offline   Reply With Quote
Old 10-29-2012, 09:57 AM   #6
STIMULA8
Member#: 298221
looking good.
its pump 93, and target boost was 22psi
yeah i can post a couple engine bay pics, but they aren't the prettiest. needs some work re-routing the hoses and replacing clamps and such.
i dont plan on replacing the t60 no, also the t60 isnt rotated, lol but i wont replace it because this was just a conservative tune on pump gas. the IDC's of the 850cc was maxed out, and the maf had to be replaced from a 70mm to a 73mm then to an 83mm, voltage was maxed out as well. with some corn and some ID1300cc injectors i should have much better spool and substantial gains. plus with corn i can bump up the boost a litttle, because of the lower knock point. i can safely run 26psi with e85 on my build.
yep
Old 10-29-2012, 10:06 AM   #7
STIMULA8
Member#: 298221
Old 10-29-2012, 02:13 PM   #8
dub kllr
Member#: 129996
97 RHD STi
Ghey
sick set-up dude! nice #'s on a Mustang dyno. the 265awhp #, was that the stock STi engine?
Also, your injectors are holding you back. I would opt for 1000cc's and swap that turbo out for an FP black and make some serious #'s. GL with your set-up man, i bet the car RIPS.
dub kllr is offline   Reply With Quote
Old 10-30-2012, 12:32 AM   #9
rexblake
Member#: 178426
2010 S4
Gray
Your going to want larger injectors than 1300s if you plan on running corn with that turbo. Prolly have to do some serious fuel system upgrades as well.
I'm glad your liking the set up, but I still have yet to see an AMR turbo that's worth a damn.
rexblake is offline   Reply With Quote
Old 10-30-2012, 09:42 AM   #10
dub kllr
Member#: 129996
97 RHD STi
Ghey
^THIS. Didn't want to be a douche but this guy is 100% correct. Most of you Subaru guys waste your time with INCREDIBLY over-priced and inefficient turbos. If you really want to step your game up, get a BW/Bullseye turbo, clock it to make it fit a rotated set-up and then smoke everyone else because those things make INSANE power.
Old 10-30-2012, 10:34 AM   #11
STIMULA8
Member#: 298221
I believe so yeah. I know the IDC was maxed out as well as the MAF and intake. they had to upgrade to an 83mm.
yes with corn i plan on doing a fuel system overhaul. looking for a good deal on some 2000cc's and ill have to prove ppl wrong i guess.
Honestly, i like the AMR t60, whats so wrong with it? I made REALLY good numbers, at only 22psi. and it was very conservative. my injectors duty cycle that was maxed out is what held me back, the turbo is capable of 30psi all day, especially with the 10.5cm hotside, PnP and its oil and water cooled, i would want to rotate the t60, then all I need is a bigger fuel system is all. just sayin, everyone is held to their opinion, but i personally love my AMR
Old 10-30-2012, 11:04 AM   #12
dub kllr
Member#: 129996
97 RHD STi
Ghey
I'm not saying it's a junk turbo, I know it's a quality product. However, I just don't think it's the turbo to go with for optimum power. Especially considering the price. I see these AMR turbos, FPs, APS set-ups, and TONS of crap Blouch turbos but no one bothers going REALLY big and getting an S362 or bigger. Billet wheel technology is amazing. And now we even have the Batmowheel!
Old 10-30-2012, 12:09 PM   #13
STIMULA8
Member#: 298221
Yep, i agree fully. But remember this car is also my DD haha so i think im good where im at for now. but in the near future, i want to get her on some corn and ID2000cc, and up the boost! im hoping for whp numbers to be in the 525-550 range and wtq numbers in the 560-580 range
Old 10-30-2012, 02:57 PM   #14
dub kllr
Member#: 129996
97 RHD STi
Ghey
DD? good LORD you've got some balls...
Old 10-30-2012, 03:02 PM   #15
STIMULA8
Member#: 298221
hahahahaha yep, i drive it everyday. why is it so hard to believe?
Old 10-30-2012, 03:39 PM   #16
Chandy69
Member#: 16087
02 WRX
Back seat with your mom
So I pretty much have all the same mods plus a few more. as you i put down 517whp but with with a 20G turbo on E85 going from 800 to 1200 cc injectors made all the difference.
Also a difference in my MPG.. I such bad mileage i cant even say
Chandy69 is offline   Reply With Quote
Old 10-30-2012, 05:08 PM   #17
dub kllr
Member#: 129996
97 RHD STi
Ghey
not hard to believe sir, just impressive. kudos to you for DDing your race car.
Old 10-31-2012, 02:06 PM   #18
STIMULA8
Member#: 298221
thank you kind sir its for sure a blast, and i might consider getting a beater for winter, im from buffalo so the winters here are super fun, but i dont want my gem in the salt, especially with no undercoating since the car is from MD.
Old 10-31-2012, 02:10 PM   #19
STIMULA8
Member#: 298221
nice power!! I want to get tuned to e85, its only $2.75 a gal here, and with corn you need to bump the fuel up, so 1300cc or 2000cc injectors would do the trick, plus i can bump the boost up tuned @ e85 you can run higher boost levels without going near the knock point because of how much cooler it runs. i hope my mileage wont be too bad.
Old 01-22-2014, 03:11 PM   #20
STIMULA8
Member#: 298221
old thread bump, car spun a bearing back in 2012. long story short the previous owner of the car sold it to me with the wrong Fu**ing dipstick. He had a WRX dipstick in the car, it had a STi shortblock, JDM v7 heads, sti oil pan, aftermarket oil pickup (unknown brand).
So basically with the WRX dipstick on a hybrid motor doesnt add up. the WRX dipstick is 3/4'' longer than the STi dipstick. So therefore was reading higher than what it actually was reading. So it starved the engine and cost me 7k. the PO is on here but i wont say his name (lucky bastard)
car got rebuilt @ PAS. (performance auto solutions) Fresh short block, but downgraded the h-beam rods to stock sti rods, downgraded the ACL bearings to stock, and now i have a stock bore shortblock with drop in manley pistons.
Ill update the mods list in post #1, and post a pic of the new dyno graph on the low boost break in tune for the fresh motor. new motor setup has 2200~ miles
Old 01-22-2014, 03:25 PM   #21
STIMULA8
Member#: 298221
heres a current picture of the motor bay, hoses are a lot cleaner routed and color matched unlike the other setup. i still need to remove the power wire from my sound system im selling.
Old 01-22-2014, 04:52 PM   #22
Chandy69
Member#: 16087
02 WRX
repost the pics. I'm curious..
That totally sucks about the dipstick. But owning a overly modified car I certainly need to double check what I to not to make that same mistake.
I started a binder with a log of mods & receipts copies of alignments and manuals. It was the only way to keep track if i was not messing up with something as simple as a dipstick
Old 01-24-2014, 02:13 PM   #23
STIMULA8
Member#: 298221
Ill repost, and i found the new dyno graph with the break in tune on low boost.
it does suck unfortunately, and i always check the oil when i first bought it, and i noticed that it didnt burn a lot, maybe 1/2 a quart in an oil change interval. so i didnt think anything of it, till one day explosion. I have a huge folder of everything purchased for this car, from the smallest of mods to the whole new block.
Old 01-24-2014, 02:15 PM   #24
STIMULA8
Member#: 298221
Before
After
theres the motor bay when i picked it up from PAS with the new setup. doesnt look like they did much, but the AOS lines, and the EVAP lines were all re routes, and look much cleaner under the IM. the huge fuel lines for the rails arent everywhere anymore. Amp power wire needs to be tucked as well
Old 01-24-2014, 02:32 PM   #25
STIMULA8
Member#: 298221
New dyno plot from PAS, break in tune. Im at 2200 miles now, protune time yes!
