Old 10-26-2012, 05:40 PM   #1
Blubullt02
Member#: 221344
2002 impreza wrx
wrx rally blue
Default 1996 EJ25D mixed up HLA valve buckets
Using my friend's account to post because he's helping me with my motor.
1996 Legacy GT. That means Phase I EJ25D with HLA 91+octane heads, etc etc.
Even though these heads have hydraulic valve lash adjusters, are the buckets specific per valve? They were mixed up the last time the car had a head gasket done. I've been told yes and no, and I'd really rather find out before I spend hours rebuilding a different set of heads or measuring and then buying expensive buckets. Keep in mind I'm not talking about mixing up the actual HLAs, JUST the buckets on top.
Thanks in advance.
Blubullt02 is offline   Reply With Quote
Old 10-26-2012, 06:02 PM   #2
eg33GC
Member#: 206851
99 V4
EJ20K RS
the bucket is the hla is the bucket, i think you may have shim and bucket and confusing them for hla?
eg33GC is offline   Reply With Quote
Old 10-26-2012, 06:24 PM   #3
Blubullt02
Member#: 221344
2002 impreza wrx
wrx rally blue
Buckets...?
Just realized these pics don't show the top. It's perfectly mirror-flat aside from slight discoloration where the cam lobes touch.
Old 10-26-2012, 06:40 PM   #4
Blubullt02
Member#: 221344
2002 impreza wrx
wrx rally blue
Better pic
EDIT: finally found out these are actually the HLAs themselves. I was thinking these were just buckets that sat on top of the HLA. After hours of searching through various sites I also found out they are all exactly the same.
Message Board Statistics All times are GMT -4. The time now is 12:50 AM.
