Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 10-26-2012, 08:26 PM   #1
swpshgnwgn
Member#: 150494
11 WRX
SWP Torqued Stg II
Default 2011 Stock? WRX
Hi all,
Just got back into a WRX and started logging today. I bought the car used and wanted to do some logging to make sure everything looked good. Thought it was stock, then I saw the log and started thinking otherwise.
https://docs.google.com/spreadsheet/...WpIVURqc1QzWUE
First time doing this, so I probably logged FAR too much information, but by the looks of this data, is this a stage 1 map? Dealership I bought it from told me it was stock.
swpshgnwgn is offline   Reply With Quote
Old 10-26-2012, 09:14 PM   #2
TS7XREX
Member#: 287450
2011 Impreza WRX
Satin White Pearl
Most people aren't going to go through that long of a log, including me. But if you want to try again do a single pull from 2500 rpms to redline if you can do so safely, and post that.
TS7XREX is offline   Reply With Quote
Old 10-26-2012, 09:24 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
18 psi? Yeah, that ain't stock
Old 10-26-2012, 09:36 PM   #4
swpshgnwgn
Member#: 150494
11 WRX
SWP Torqued Stg II
Apologies. I deleted a lot of the first part of the log to get to the main portion I was talking about.
Edit: Which it looks like I didn't save before uploading. I'll fix that.
Edit2: Fixed.
Old 10-26-2012, 09:46 PM   #5
TS7XREX
Member#: 287450
2011 Impreza WRX
Satin White Pearl
You should pull the rom from your car and compare it to the stock rom found on romraider. It would be fun and you can learn a lot about it that way.
Edit* http://www.romraider.com/forum/viewt...hp?f=33&t=5384
Here is some good info on how to make a useful datalog
