#1 |
Member#: 149674
SCIC
Vehicle:2006 LimitLess STI SGM |
NEW PICS IN #4 POST
So here it is so far. I wanted to wait untill it was finished, but I am just waiting for other parts to be finished up. That and I am getting very excited. GOALS: 600+awhp, 9k rpm, around 9-10sec at the 1/4, BUT WE WILL SEE. IF YOU THINK I SHOULD LOOK INTO ADDED OR DIFFRENT PARTS LET ME KNOW Parts for build: Benson's Sleeved Block, 99.5 bore MPS Custom High Compression JE Pistons for 2.34l Carrillo Rods 2.0l crankshaft with Heat treated journals, Nitride treatment, CRYO treatment and micro polished journals ACL rod bearings, KING main bearings Balanced and blueprinted 11mm MPS modded oil pump GSC S2 cams GSC springs and retainers GSC +1 intake and exhaust valves mild port/debur heads Coated combustion chambers Coated exhaust runners Cosworth head gaskets ARP case bolts ARP CA625+ head studs TigWerks AN oil return KillerB oil pan / pick-up / windage tray and much more just cant remember off the top of my head ![]() ![]() ![]() ![]()
#2 |
Member#: 149674
SCIC
![]() ![]() ![]() ![]() ![]() Last edited by ...CHUCKLES...; 10-27-2012 at 02:44 PM. |
#3 |
Member#: 149674
SCIC
More pictures...
These are of the FAB, welding, and completion of the headers and VF39 adapter. Ray over at Ray-Bon is f-ing God when it comes to welding he is the guy thats going to do my Haynes230 headers. Also the custom adapter for the oil temp sensor. ![]() ![]() ![]() ![]() ![]() Last edited by ...CHUCKLES...; 11-24-2012 at 09:45 PM. |
#4 |
Member#: 149674
SCIC
Latest Pics of motor in car and just about to rock and roll.
I still have to fab my downpipe/exhaust, reloom my harness, powder coat and heat coat parts. This is going to take just a little longer than expected, reason mostly because I have now decided to do MUCH better brakes. Will update when I have fired the motor and breaking it in and yes that is a rotated VF39 with a 4" intake. ![]() ![]() ![]() ![]() ![]() Last edited by ...CHUCKLES...; 01-20-2013 at 06:38 PM. |
#5 |
Member#: 149674
SCIC
LAST reserve for pics
#6 |
Member#: 56203
Vehicle:00 RSTI Coupe |
I like how you mounted the FPR gauge and used hard fuel lines instead of braided SS.
Nice work!! |
#7 |
Member#: 151703
NWIC
Vehicle:2002 wrx 6speed son! WRB |
Just curious, how much is did your engine build cost?? Im lookin to do the same setup. What turbo are you gonna run?
#8 |
Member#: 149674
SCIC
Know that I personaly did not build the block, heads or long block. I did however fab the intake manifold and machined some parts.
So far in just parts for the long block+intake I have about 13 grand and about 3ish grand in services. Total of between 15-17 grand for everything so far. Also know that I bought ALL new stuff, only things that are used are 703case halves and head castings only. + I did not mentioned a lot of outher stuff like injectors, AN fittings, outside process costs and shipping costs which should all be taken into account. Also know that I am still not done. Just rember this hobby is like a BOAT. B-reak O-ut A-nother T-housand I am willing to live with that... |
#9 |
Member#: 165104
SCIC
Vehicle:E85 bug-i sti swap Phatron tuned |
Good God man.
Looking very nice. Love the custom bits |
#10 |
Member#: 149674
SCIC
As for the turbo I will be running 4 diffrent turbos.
VF39 - I will peg this bitch out. Looking for 475-500 on E just to see if I can do it and for motor break-in GTX3076r/with tial housing for road racing. Looking for 400-425 on E strictly for road racing FP Black HTA looking for 550ish on E, just wondering about this turbo. FP HTA 3794r looking for around 650ish on E |
#11 |
Member#: 112759
Vehicle:02 Srp STi... R ur Boltz to long???? |
What headers/exhaust manifold will you be running?
#12 |
Member#: 149674
SCIC
I will be running some custom UEL 304 sch 10 headers at first, but once I finish with my super alloy HAYNES 230 headers (should weigh around 5-7 lbs) then I will be running those.
#13 |
Member#: 131280
BAIC
Vehicle:2004 Impreza WRX WRB |
Wow looks great! Can't go wrong with MPS, great guys and amazing work! Gonna have some fun with that 9k rev!
#14 |
Member#: 166427
South East
Vehicle:03 wrx |
Is that a 2.0 block and how much for the block?
#15 |
Member#: 327495
Vehicle:2012 Impreza WRX 5DR Plasma Blue |
I'm scared
#16 | |
Member#: 81102
![]() That will also be quite the "break in" Good luck, nice parts. |
#17 |
Member#: 149674
SCIC
^^^ what I ment by that was after I have broke in the motor, I will try to crack 475-500 on the 39. I also understand that it is an improbable task, but aah why it try I have the time. Also this would not be for practical use.
#18 |
Member#: 138994
Vehicle:2006 WRX Ltd SGM 6MT and such |
#19 |
Member#: 149674
SCIC
^^^First I shaved the mani for reversing then I cut the purge tank off of the intake mani also applying a velocity stack for the TB. Then I machined a clamp for the FP gauge and welded to the mani as you stated. As for the FPR yes it is mounted to the manifold using a bracket I made and welded 4 treaded post on the manifold to hold the bracket.
#20 |
Member#: 59993
International
Vehicle:Ass, grass or cash no one rides for free!! |
Very very nice build.
#21 | |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
That really turned out great. If I have to touch my fuel lines again I'm going to try bending my own hard lines. It looks like it would be tough to get just right, but when done right it looks fantastic. |
#22 |
Member#: 158864
beautiful
600+ at the wheels... gt4294? |
#23 |
Member#: 149674
SCIC
^^^ Yep 600+ at the wheels.
Forced Performance HTA 3794r Turbo At least that's what I will try for... |
#24 |
Member#: 326128
Nice build bro!!
#25 |
Member#: 64397
SCIC
Vehicle:2006 WRX STI Steel Gray |
If you are going to road race the car why do you need 600+whp. Seems like the FPBlack would be a perfect fit, to give you HP and be Road Raceable. I think those crazy numbers are possible on the stock turbo. I mean you will just spike it up there and taper off, but cool to show people it can be done. I know the evo guys have hit 500+ on the stock turbo.
