Old 10-27-2012, 04:20 PM   #1
IveBeenRued
Member#: 305466
2012 Sport Limited
Default Does anyone know the fuel consumption at idle?
Out of curiosity, does anyone know the fuel consumption(gallons per hour) at idle for the 2012+ Imprezas 2.0i?
IveBeenRued is offline   Reply With Quote
Old 10-27-2012, 10:32 PM   #2
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
On a warmed up engine with the A/C off, about 0.18 GPH.
Commander Keen is offline   Reply With Quote
Old 10-27-2012, 11:48 PM   #3
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
where did you get that number?
Old 10-28-2012, 12:48 AM   #4
danstheman7
Member#: 331089
2012 Impreza Base
DGM/Dark Grey Metallic
Kind of interested to find how you knew that number too.
danstheman7 is offline   Reply With Quote
Old 10-28-2012, 10:34 AM   #5
Commander Keen
Member#: 319157
At 10 MPH in neutral, the instantaneous MPG is 58.
The car will take 58 miles to consume 1 gallon.
The car will take 5.8 hours to cover 58 miles.
Therefore, the car will take 5.8 hours to consume 1 gallon.
1/5.8=0.1724 or 0.18, rounded up.
This number depends on the accuracy of the IMPG readout.
Old 10-28-2012, 11:53 AM   #6
ans2k
Member#: 315631
2012 Impreza Sport
lol that doesn't sound accurate at all.
i was trying to calculate this yesterday by taking the air to fuel ratio at idle which in most cars is 13 to 13.6 opposed to 14.2-14.6 cruising. this is why people say our cars runs rich at idle. assuming this, i took the size of the engine and divided by 13 because only 1/13 of the air filled in the car will be fuel. but it will only burn this fuel when all the cylinders have fired. how many rotations is that, 2. so it burns x amount of fuel for every 2 rotations. then you have "y" gas/rotation. then take this number times the idle rpm which would give you "z" gas/min. then times by 60 min/hour. then convert to gallons. this will give you gallons/hour. but the math just doesn't add up. logically makes since to me but i am missing something.
ans2k is offline   Reply With Quote
Old 10-28-2012, 12:15 PM   #7
Commander Keen
Member#: 319157
You are missing something - volumetric efficiency. The amount of air in the cylinders varies constantly with RPM and throttle angle, so the amount of fuel will as well.
Our cars idle in closed loop mode, so a hot idle is probably around 14.7:1.
Old 10-28-2012, 12:16 PM   #8
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
You can just plug a laptop into the OBD2 port and look at how many cc the injectors are spraying at idle...
Also, if you have an automatic, idling in D will use a lot more fuel than idling in N due to the added load from the torque converter.
.2 is probably pretty close to what you use at warm idle with no load on a 2L, about .25ish for a 2.5L
-- Dave
AcquaCow is online now   Reply With Quote
Old 10-29-2012, 08:53 AM   #9
IveBeenRued
Member#: 305466
2012 Sport Limited
Thanks guys! It looks like my impreza will likely be powering my sump-pump via a power inverter if the power goes out for an extended period of time.
Old 10-29-2012, 08:59 AM   #10
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
-- Dave
I thought CVTs don't have a torque converter...?
goregasm is offline   Reply With Quote
Old 10-29-2012, 09:38 AM   #11
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
How did you think the engine kept running in gear?
auskip07 is offline   Reply With Quote
Old 10-29-2012, 09:40 AM   #12
Commander Keen
Member#: 319157
Unless you have a powerful inverter and a tiny sump pump, I have my doubts.
Old 10-29-2012, 09:59 AM   #13
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
If you don't have a well, you should get one of those water-powered sump pumps...
Old 10-29-2012, 03:51 PM   #14
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
I'm not a car expert so I'm not gonna pretend to know anything, but google "cvt torque converter".
Old 10-30-2012, 06:07 PM   #15
IveBeenRued
Member#: 305466
2012 Sport Limited
Good news guys. My power is back up, my basement is dry, and I have some relatively accurate numbers for you. My 2012 Impreza Sport Limited idled for 22.5 hours and consumed 3.544 gallons of fuel (including the 5.7 miles that it took me to go back and forth to the gas station). So including a few miles, my consumption rate at warm idle was .1575 GPH.
I had the car idling in my garage(with proper ventilation and a CO monitor running) with a 750/1500 watt RMS/Peak inverter hooked up and it kept my sump-pump running flawlessly. The pump would cycle on for 35 seconds every 5-6 minutes and would peak at 646 peak watts at startup then drop down to 344-362 watts for the remainder of the cycle.
My neighbor to my right has a flooded basement because his brand new generator failed and he had no backup system. Even though I have no backup system my basement is bone-dry thanks to my Subaru.
On a side note my Impreza also saved our Beta fish from freezing by running his 15 watt heater continuously via the same power inverter.
Old 10-30-2012, 06:23 PM   #16
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Time for an oil change
Old 10-30-2012, 07:00 PM   #17
cnlson
Member#: 310098
2012 Impreza PremCVT
Dark Cherry Pearl
not likely. I ran our subie in march for about 20 hours of that we idled (caught in a snowstorm) from 10 pm to 6 am keeping warm and then drove from 6am to 12pm then waited 4000 more miles for an oil change and the oil sample came out fine. we averaged 29mpg also on that trip with the idling included.
as a side note, you just about don't have to worry about CO poisoning anymore because car exhaust is so clean now.
cnlson is offline   Reply With Quote
Old 10-30-2012, 09:58 PM   #18
Commander Keen
Member#: 319157
It looks like your pump averaged 34W throughout the night. It's funny to think that small amount of power made the difference between a dry basement and a flooded one.
Low idle fuel consumption is another benefit of the boxer. I haven't seen an inline four that could idle as smoothly and slowly as our engines do.
Being able to idle three days straight on a full tank has its survival value.
Glad you pulled it off, and thanks for the numbers.
Old 10-31-2012, 07:58 PM   #19
subiTWO
Member#: 273054
2012 Impreza CVT HB
Good news guys. .
This is awesome...
subiTWO is offline   Reply With Quote
Old 11-01-2012, 12:29 PM   #20
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Idling in neutral or park?
That seems pretty good for an overestimation. Nice.
Thats pretty close. I didnt think this was too accurate at first.
Old 11-01-2012, 01:07 PM   #21
IveBeenRued
Member#: 305466
2012 Sport Limited
It was in park the entire time. I turned everything off that I could including the screen on the radio.
Yeah I was pleasantly surprised at the consumption rate. I always have at least 20 gallons in a monthly rotating stockpile so even if I came home on an empty tank I could power my sump-pump for more than 5 days straight.
Old 11-01-2012, 02:27 PM   #22
myrt1987
Member#: 323103
2012 Limited 2.0i
I only say overestimate because of the miles you drove to gas station. (we all know how great these cars are in short trips) Thanks for reporting.
This makes me wonder if shifting to neutral while stopped at a red light saves gas.
Old 11-01-2012, 11:24 PM   #23
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
I got around a litre per hour which is roughly 0.25 galons/hr.
Measured around 100 km/h coasting, 1l/100 km instantaneous consumption, so 1l/h.I have a MT, so for coasting I just depressed the cluch - which does reduce the drag with respect to being in neutral, but I don't believe it's significant. Might measure again to check...
Old 11-01-2012, 11:54 PM   #24
Commander Keen
Member#: 319157
Coasting in gear uses zero fuel.
Old 11-02-2012, 11:45 AM   #25
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Really!? So that means I can stop shifting into neutral when coasting down hills? I thought I was saving gas but I guess all I was doing is wearing my breaks faster.
jr0bb5 is offline   Reply With Quote
