Old 11-04-2012, 08:27 PM   #26
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Fuel is needed to maintain RPM above or at idle. If you're in neutral, nothing drives your engine but the combustion.. so you use the 0.25gallons/hr for that. If you have a MT, and are coasting, the wheels drive the engine. The ECU realizes it needs no fuel to make the engine turn, so it cuts the fuel intake to zero. On long downhill in-gear coasts you can actually see the coolant and oil temp drop below nominal values, as the engine spins cold..
Old 11-04-2012, 09:58 PM   #27
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Proof?
goregasm is offline   Reply With Quote
Old 11-04-2012, 10:04 PM   #28
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by goregasm
Proof?
You can feel when the fuel is reintroduced, there is a tiny jolt. Most manuals this happens at 2000 rpm, not 100% sure on this one
Old 11-04-2012, 11:58 PM   #29
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Using a scan tool, I've seen as low as 1100 on mine.
Commander Keen is online now   Reply With Quote
Old 11-05-2012, 06:50 AM   #30
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I should really hook mine up
Old 11-05-2012, 02:32 PM   #31
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I have many logs that show my injectors shut off when I coast in-gear... definitely no fuel used until you get back down to about idle RPMs..
AcquaCow is online now   Reply With Quote
Old 11-05-2012, 02:42 PM   #32
53x12
Member#: 206332
Question I have always had is in regard to coasting in gear vs. coasting in neutral in regards to distance one is able to go before needing to hit the gas pedal. From my experience being in gear adds more "drag" and I feel like the car won't roll as far or as quickly. When in neutral it will roll faster and farther even if it uses 0.25 gallons/hr. Wonder what the difference comes out to be if there is any difference when you account for that?
53x12 is offline   Reply With Quote
Old 11-05-2012, 03:24 PM   #33
Commander Keen
Member#: 319157
DFCO (deceleration fuel cut-off) produces infinite instantaneous MPG and will raise your average as long as you're moving.
If you see a red light up ahead, DFCO makes perfect sense. You'll want to pick a high enough gear that you're not slowed too quickly, but a low enough gear to maximize the amount of time the RPMs spend above 1100 or so.
I think using 40-70% throttle up hills in 5th and 0% on the way down gives better MPG numbers and more stable speeds than the feather-the-throttle method.
Old 10-18-2013, 08:07 PM   #34
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
So sitting here in the 60f weather. ECU reports between 7.4 and 8.0cc of fuel per minute. Let's say 7.8 and be liberal.
That's 0.12 gallons per hour. **** me that's low.
Edit: now that it's completely warmed up its at 0.107gph. ****. Me.
Old 10-18-2013, 08:32 PM   #35
lymphomaniac
Member#: 334451
2013 Impreza2.0i CVT
DGM (sedan)
I wonder how idling the engine until the blue light goes off before driving compares to the fuel consumption of driving the vehicle with the blue light on until it goes off?
lymphomaniac is offline   Reply With Quote
Old 10-18-2013, 11:49 PM   #36
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Probably the same.
