Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 10-27-2012, 07:39 PM   #1
cbazq271
Member#: 330175
Default replacing oem turbo
Hi, I just replaced my turbo on my 05 sti with a oem replacement. My question is, do I have to do anything to prep the turbo after I bolt it on, before I start the car. Like do I need to pour a little oil into the turbo, through the oil free hole , so the turbos not starting dry? Thanks, Chad
cbazq271 is offline   Reply With Quote
Old 10-27-2012, 07:48 PM   #2
424wrx
Member#: 171948
08 wrx prem sedan
vf52 swap. bilstein susp
ive read to floor the throttle or pull the fuel pump relay while cranking. when i swapped mine for a vf52 3 years ago, i just squirted oil into the top oil feed on the turbo. then just let it idle a while and checked for leaks. also clamp off your coolant lines and then you wont need to drain the coolant. it worked for me.
424wrx is offline   Reply With Quote
Old 10-27-2012, 10:25 PM   #3
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
You need to prime the turbo. I wouldn't "floor it" but instead, disconnect the fuel pump relay in the pass. side kick panel, crank the motor a good couple of times, then reconnect and start it.
Old 10-27-2012, 10:41 PM   #4
cbazq271
Member#: 330175
Thanks, I will do this. Do you think also putting some oil in the turbo before starting is a good idea, or is it not needed.
Old 10-27-2012, 11:00 PM   #5
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
"flooring it", despite the implication, will cut fuel in the DBW models during cranking. It's a quick and easy way to turn over the engine without starting or having to pull any fuses or relays. It's better than pulling the fuel pump relay IMO since the injectors won't even fire.
I've done it myself, it works.
Here's the Cranking IPW Throttle compensation on the 05 STi:
Anything over 90% throttle cuts fuel entirely during cranking.
Old 10-27-2012, 11:14 PM   #6
Member#: 51961
2005 STi
2012 WRX
Anyway, pull the fuse/relay or floor it, doesn't matter. Put some oil in the feed to the turbo, spin it by hand to get a little bit running through the bearings, do whatever you want to do to keep it from starting and crank the engine for 10+ seconds at least 3 times to get the oil flowing through the turbo, then start it up and let it idle for a while, and continue on with the rest of the break in procedure.
Old 10-28-2012, 12:23 AM   #7
ProfessWRX
Member#: 323379
06 WRX
That is cool. My 06 wrx has the same table/values. Good to know.
ProfessWRX is offline   Reply With Quote
Old 10-28-2012, 10:39 AM   #8
424wrx
Member#: 171948
08 wrx prem sedan
this is what i was implying. no need to pull any fuses or relays.i just primed mine like i said and reinstalled the top oil line. started the car and done. that was 3 years ago so i guess i didnt damaged the journal bearing.
Old 10-29-2012, 08:47 AM   #9
cbazq271
Member#: 330175
I have my old turbo off and the new one on. does anyone have a idea of how much my old turbo is worth. The only reason I replaced it, was I know theres 150,000 miles on it and wanted to change it just to be on the safe side. It was working fine and build great boost. I don't know have to really check a turbo, but I tried to wiggle the rotors on both sides of the turbo and they feel nice and solid. would like to sell it for some money, rather then just throughing it away.
Old 10-29-2012, 11:33 AM   #10
sc00ter
Member#: 117767
2007 WRX Limited
OBP - VF48
With that mileage, if there is minimal shaft play you could probably get $150-$250 out of it.
sc00ter is offline   Reply With Quote
Old 10-29-2012, 01:40 PM   #11
cbazq271
Member#: 330175
Ok, well then the first $100 takes it. I will list in the for sale section.
Message Board Statistics All times are GMT -4. The time now is 07:52 AM.
