Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 10-28-2012, 12:21 PM   #1
Ilovecugars
Member#: 299442
2005 Forester XT
Default Tourque plate blueprints
Hi guys
I'm going to do up a cnc program to machine myself a torque plate to help me do more of my engine builds myself. Does anyone have a good blueprint of the head of the block, ie bore dia, spacing and bolt pattern for head studs?
Any help would be great!
Thanks
Ilovecugars is offline   Reply With Quote
Old 10-29-2012, 08:51 AM   #2
bebesito21
Member#: 176128
5862 ...baby boosted
Why not use a head gasket?
bebesito21 is offline   Reply With Quote
Old 10-29-2012, 03:06 PM   #3
Ilovecugars
Member#: 299442
2005 Forester XT
That would work to transfer over to a piece of steel to make by hand and just drill it all out. However I am looking for all the distances from bolt holes to bores positions so I can write a program to have a cnc drill and machine it all in one run. I was hoping someone would have the numbers rather then have to probe a case half.
Old 10-29-2012, 05:26 PM   #4
TIGWERKS
Member#: 256615
Probing a case half in the mill or using some calipers won't take long. If you can make the program I'm sure you could measure.
TIGWERKS is offline   Reply With Quote
Old 10-29-2012, 06:20 PM   #5
RockNRace03
Member#: 322678
measure with a caliper and you should be able to get it nearly spot on. or have someone with romer/farrow arm digitize it for you?
RockNRace03 is offline   Reply With Quote
Old 11-06-2012, 02:39 AM   #6
Mister Tanker
Member#: 237759
2003 WRX Wagon
Built ej205 478whp 417wtq
Pm me your email. I have a program for an ej205 plate I made earlier this year. Mastercam x5 and x6 files.
Mister Tanker is offline   Reply With Quote
