Old 10-28-2012, 12:24 PM   #1
cohen_fetters
Member#: 300366
Default Stupid question on a shortblock swap
tried doing some research on swapping in a 2011 sti short block into an 06 sti but couldnt find anything. is this a straight drop in swap?
cohen_fetters is offline   Reply With Quote
Old 10-28-2012, 04:02 PM   #2
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Should be, don't expect to gain anything though.
drewvdw is offline   Reply With Quote
Old 10-28-2012, 04:04 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I'm pretty sure nothing has changed in the short block other than the crank. Why do you want to do this?
Old 10-28-2012, 05:52 PM   #4
Layvon
Member#: 195711
STi 04/05/06/07
The only short block you can buy is a 704.
Layvon is offline   Reply With Quote
Old 10-28-2012, 06:51 PM   #5
Supraru
Member#: 23313
99' 2.5Rs
black
Most people do this because they spin a bearing or maybe they want the nitride crank and it's a lot quicker to just swap short blocks. It's not rocket science.
Supraru is offline   Reply With Quote
Old 10-28-2012, 06:52 PM   #6
cohen_fetters
Member#: 300366
yea my block is shot that is the only reason i am asking. not looking for any gains.
Old 10-28-2012, 06:54 PM   #7
cohen_fetters
Member#: 300366
uhh sorry for being a noob. can you explain?
Old 10-28-2012, 07:05 PM   #8
Supraru
Member#: 23313
99' 2.5Rs
black
There are different castings. I believe the original 2.5 short block was a 702 casting. Over the years with changes made to the blocks they change the casting numbers when there's a difference. So if you were to order a short block from Subaru for a 2004 sti you'd get the 704 casting which is the newest "model" of that short block.
Old 10-29-2012, 12:13 AM   #9
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Casting numbers are really only for dating purposes, like batch numbers in a way. OP dont worry about it, swap it in and you will be fine.
UK-Wagon is offline   Reply With Quote
Old 10-29-2012, 08:43 AM   #10
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
701 first in 04 sti
yes straight swap
Old 10-29-2012, 10:00 AM   #11
cohen_fetters
Member#: 300366
Thanks for the help.
Old 10-29-2012, 08:42 PM   #12
iSTI
Member#: 241769
yeah its just a drop in and your done just be sure to bolt everything to its tq specs..
iSTI is offline   Reply With Quote
Old 10-29-2012, 09:32 PM   #13
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Did this almost a year ago without a problem.
Old 10-29-2012, 10:29 PM   #14
Layvon
Member#: 195711
STi 04/05/06/07
My 2004 is also running a 704.
