Old 10-28-2012, 04:18 PM   #1
Pablopakman
Member#: 336372
97 impreza wagon
red
Default 97 impreza wagon 2.2 to 2.5
Disclaimer: I know these threads exist and have researched them all. I am just looking for confirmation before dishing out $1000+ for a new engine.
The story: i have a 97 impreza wagon that had a swapped ej22 engine from a 96 legacy (allegedly). After 2 years of owning it and commuting 80mi a day, the timing belt skipped a few teeth on the crank and now will not run even after fixing the timing. So now i am looking for a new engine And am seriously considering an ej25. I know about their head gasket issues (just did head gasket and clutch on wife's 99 forester) but i really would like that extra 30hp. Especially if its a jdm engine with 50k (again allegedly).
Question to you: will the following engine work for my swap? http://www.sunrisejdmmotors.com/engi...83&page=1&F=ME
Has anyone bought from Sunrise before? Does anyone know of some place closer, cheaper, more reliable? I have heard bad this about Osaka jdm and Tiger jdm engine. Also, can this be done successfully without having a ej25 doner car?
I am located in south east PA. Any info on this will be helpful. Thank you for your time.
Pablopakman is offline   Reply With Quote
Old 10-28-2012, 08:30 PM   #2
jeffsnyder
Member#: 10039
you need a phase 1 dohc 2.5 engine.
swap intake manifolds, to eliminate wiring issues and go
jeffsnyder is offline   Reply With Quote
Old 10-28-2012, 09:52 PM   #3
Pablopakman
Member#: 336372
97 impreza wagon
red
Thank you, is the linked (above) engine a phase 1 engine? What is the visual difference between 1 and 2.
Thanks again, this helps greatly.
Old 10-28-2012, 10:29 PM   #4
alt14
Member#: 271928
2007 Impreza 2.5i SE
I believe 96-99 legacy outback's used phase one and on that link it says 96-98 so I think it should be a phase one
alt14 is offline   Reply With Quote
Old 10-28-2012, 11:35 PM   #5
Pablopakman
Member#: 336372
97 impreza wagon
red
That sounds about right, i will call and ask to be sure (if they even know).
Has anyone dealt with Sunrise in the past? Any good or bad experiences?
Old 10-29-2012, 10:18 AM   #6
jeffsnyder
Member#: 10039
all phase 1 are dohc engines
Old 10-29-2012, 11:36 AM   #7
alt14
Member#: 271928
My friends 93 legacy I just did the timing belt on is a phase 1 sohc
Old 10-29-2012, 06:34 PM   #8
corytrevor
Member#: 175931
May I ask why the DOHC 2.5 is necessary?
I'm in the same position - 97 Impreza needs a new engine. I found a 99 Forester (2.5 SOHC) that I'd like to use the engine from. I already have dual-port headers, and can use whatever other parts from the Forester (intake manifold?) that are needed. Is there any other compatibility issue I'm not aware of?
corytrevor is offline   Reply With Quote
Old 10-29-2012, 08:37 PM   #9
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Ecu is different
J.Gibbs is offline   Reply With Quote
Old 10-29-2012, 08:42 PM   #10
corytrevor
Member#: 175931
Originally Posted by J.Gibbs View Post
Ecu is different
I see. Does that mean the whole wiring harness is different as well, or could the ECU be swapped from the donor car?
Old 10-29-2012, 08:44 PM   #11
alt14
Member#: 271928
Probably the wiring is different too
Old 10-29-2012, 09:02 PM   #12
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Correct wiring is different. Easier to just swap in a stock replacement
Old 10-30-2012, 10:56 AM   #13
alt14
Member#: 271928
I thought so, thanks for verifying
Old 10-30-2012, 12:39 PM   #14
corytrevor
Member#: 175931
This sucks for me, but yes, thanks for the info. Good to know before trying it...
Old 10-30-2012, 01:56 PM   #15
corytrevor
Member#: 175931
Are all 2.5 DOHC engines phase I as well?
Old 10-30-2012, 04:28 PM   #16
jeffsnyder
Member#: 10039
all 2.5 doch N/A engines are phase 1 from my understanding of it
Old 10-30-2012, 06:22 PM   #17
alt14
Member#: 271928
I'm pretty sure the newer forester's are dohc, the phase III are dohc
Old 10-30-2012, 06:38 PM   #18
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
The newer Foresters aren't EJ engines.
Counterfit is online now   Reply With Quote
Old 10-30-2012, 06:50 PM   #19
alt14
Member#: 271928
Never mind your right I just saw, for some reason I thought I saw dohc on the x model when I was looking at getting one in 08
Old 10-30-2012, 08:51 PM   #20
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Phase one dohc engines are found in subies from 96-98 with the 2.5L engine. In 99 they swapped basically everything over to the sohc. Completely different engine
Old 10-30-2012, 09:35 PM   #21
GreenL
Member#: 177721
1995 Impreza L
ABP
I am not sure if the 2.2L intake will bolt up to the 2.5Ldohc.
However, just get a Ej25D (DOHC) and drop it in with everything. It will run find on the 2.2L ECU. You can use a 98RS ECU if you find one.
GreenL is offline   Reply With Quote
Old 10-30-2012, 11:41 PM   #22
corytrevor
Member#: 175931
Will the 2.5's ECU have any advantages over the 2.2 when running a 2.5 motor?
Old 10-31-2012, 12:57 AM   #23
jeffsnyder
Member#: 10039
correct for imprezas wrong for legacys
99 legacys were dohc engine yet in 2000 they switched to sohc
Old 10-31-2012, 01:00 AM   #24
jeffsnyder
Member#: 10039
as far as what i read they will.
cross reference the intake manifold gasket, they should match
Old 11-01-2012, 10:40 PM   #25
corytrevor
Member#: 175931
I found an EJ25 DOHC complete with everything. How much of everything should really go with it? Mine includes a lot of the wiring, coil pack, injectors, and throttle body. Is everything compatible? I already noticed there are some additional fuel/vacuum rails on the passenger side that my old EJ22 top end does not have at all.
Message Board Statistics All times are GMT -4. The time now is 05:48 PM.
