Old 10-28-2012, 09:45 PM   #1
rvines19
Member#: 287469
2007 Impreza Wagon
Urban Gray
Default runs rough when wet
2007 2.5i wagon. I have this issue only when the car sits outside in the rain for a couple days without being started. usually when I leave the car at the outdoor airport parking lots due to my business travel. I come back to the car after it sitting for 3 days (it rained one of those days) - fire it up and it idles ROUGH, RPMS drop down, shakes like it wants to stall and strange sounding exhaust. i can give it a little gas, sounds normal and then RPMS drop down, idles rough and sounds horrible. Check Engine Light will flash a couple times - then about 5 minutes runs fine, CEL goes off.
Last time it occurred, P0303 misfire was found, but dealer didn't find any problems. Suggestions? From what i read, seems it could be
1) coil pack and spark plugs
2) harness behind battery might be getting wet
3) Mass air flow (MAF)
Before Hurricane Sandy comes tomorrow, I would like to see if i can figure it out.
Thanks,
rvines19 is offline   Reply With Quote
Old 10-28-2012, 11:33 PM   #2
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
It might be moisture building up, when I did my friends timing belt on his legacy it had a lot of moisture buildup from not being ran for a while I'm assuming, after about ten minutes of idling most of the moisture was gone from the tail pipe and clear exhaust, the car was running a little rough at first but now is running fine
alt14 is offline   Reply With Quote
Old 10-29-2012, 04:31 PM   #3
rvines19
Member#: 287469
2007 Impreza Wagon
Urban Gray
UPDATE well, lucky for me - my office was closed due to Sandy. About 11 am, i ran out to fire her up and the same problem occurred... Drove about 2 miles, with noise, lack of power, flashing CEL and then it stopped and car drove OK. I live about 5 minutes from dealership. Took her in, P0303 code -- they replaced the coil pack and wires. However, wasn't covered under warranty. Lets see if she fires up later tonight or tomorrow morning..
Old 10-30-2012, 09:24 PM   #4
GreenL
Member#: 177721
1995 Impreza L
ABP
This happened to me when I had my NA....turns out it was a ripped spark plug wire
GreenL is offline   Reply With Quote
Old 11-11-2012, 09:21 PM   #5
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Check plug wires and knock sensor
Rudgers73 is offline   Reply With Quote
Old 11-13-2012, 04:40 PM   #6
gdoggmoney
Member#: 158150
2007 Impreza 2.5i
Newport Blue pearl
Old plug wires can dry up, and not seal allowing moisture into the coil pack connections and the spark plug wells, both bad places to have moisture.
gdoggmoney is offline   Reply With Quote
Old 11-17-2012, 07:37 PM   #7
klaus_b2
Member#: 318411
mine does the same thing! exhaust sound and everything...and sometimes, even white smoke comes out my exhaust which means water. but after 5 minutes like you said she runs fine..
klaus_b2 is offline   Reply With Quote
