Old 10-30-2012, 12:50 PM   #1
l1m1tedsc00b
Member#: 316208
Default cold start problem
Hi guys I have an 06 wrx wagon which I purchased over the spring. now that its getting cold in my state (last night it dropped below freezing) I'm curious as too why my car hesitated to start and when it finally fired I got a squeel coming from the motor. I'm going to change my fuel filter out this weekend and hopefully that helps witht the hesitation but I have no clue as to what the squeel could be coming from
l1m1tedsc00b is offline   Reply With Quote
Old 10-31-2012, 09:48 PM   #2
Ajschirack
Member#: 310489
2012 WRX
Plasma Blue Pearl
The squeal is you timing belt, pretty common with subarus it seams like, it usually is heard where the belt is tight and temp is chilly, nothing that will cause any problems, you could stop by a shop and they may adjust it for you for free if ur lucky.
Ajschirack is offline   Reply With Quote
Old 10-31-2012, 10:19 PM   #3
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Squeal is not necessarily the timing belt, could be but not always. It could be ANY belt on the vehicle, so count in A/C and power steering as well. As for adjusting, you can adjust both A/C and Power Steering (also check for wear like cracking or crazing), however you cannot "adjust" the timing belt to make it not squeal. I have no clue where Ajschriack even got this.
A hesitation during cold to me, suggests a battery going bad. Extremely common. Colder temps=more power from battery needed to turn vehicle over.
OP what are the miles on the car? And also where are you located? (aka fill out your profile) Have the battery tested, possibly replaced. And depending on miles, have the timing belt replaced. As for the fuel filter, it is incorporated with the pump in the tank. Once again, depending on miles you might not need it at all. And to replace it is a bit of a chore.
Old 11-01-2012, 07:56 AM   #4
faSTI666
Member#: 180204
2005 FXT Stg II 1/2
SSM
Belt tensioner...
faSTI666 is offline   Reply With Quote
Old 11-01-2012, 08:43 AM   #5
Leafy
Member#: 330625
2006 WRX
The belt only squeals on cold start? Sounds like its perfectly tensioned. Its just at that point where its tight enough to not slip in most conditions so it'll have less bending load on the bearings making for less friction. Of course I'm used to racing a car where that 0.05 hp matters.
Old 11-01-2012, 01:29 PM   #6
StealthTL
Member#: 206912
2006 Forester XT
/\ What Leafy says.
A second or two of squeal is caused bythe heavy load on your alternator, after just starting and voltage being relatively low. You could just tighten the alternator belt adjuster, but I wouldn't.
Your battery may be on it's last, if this just started happening - start shopping for a fresh one.
StealthTL is offline   Reply With Quote
