Old 12-31-2012, 10:44 AM   #51
Type2
Member#: 200436
2004 Forester XT
I could NOT get the bottom two cam gears off my old engine. The ones I really wanted to (and to reuse) were the top AVCS cam gears. They weren't too big of a problem. I used a socket extension wedged against the flex plate to stop the engine from turning, but despite using a breaker bar and hanging from it there was NO way the bottom two were coming off. In fact, it started to strip the inside of the hex nut on the cam. Not good.
Type2 is offline   Reply With Quote
Old 12-31-2012, 03:42 PM   #52
kakarot09
Member#: 182375
08 Sti
Wrbm
Happens pretty often on these. You can drill the bolts without messing up the cam gear or dremel the bolts and risk messing up the cam gear. Either way you're pretty much just taking the tension off the bolt by cutting away the shoulder of the bolt. Then the gear and bolt come off easily.
kakarot09 is offline   Reply With Quote
Old 12-31-2012, 04:47 PM   #53
Type2
Member#: 200436
2004 Forester XT
Well, glad I didn't pull the pin on the timing belt... As I was swapping parts over to my new engine I realized there are a couple water lines coming from the water pump that go behind the driver's side plastic cam guard. Also, the AVCS oil line goes behind as well. Doh... ugh... So... I need to remove the timing belt, buy couple brass crush washers for the AVCS oil line and get the water pump hoses routed then put it back together. Yay for first timers!
Old 12-31-2012, 06:46 PM   #54
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
Make sure you remove the belt properly so you don't bend valves!
NW2TONE is offline   Reply With Quote
Old 01-02-2013, 04:01 PM   #55
Type2
Member#: 200436
2004 Forester XT
Any particular drill bit you recommend? I'll do some searching in the meantime.
Old 01-02-2013, 04:03 PM   #56
Type2
Member#: 200436
2004 Forester XT
Is there a special way to do this? The belt is not on tight since I didn't pull the pin on the tensioner. I'll hold the right two gears in place as best I can, but they will pop back to their resting position which is out of harm's way.
Old 01-02-2013, 04:30 PM   #57
kakarot09
Member#: 182375
08 Sti
Wrbm
I forget the size of drill bit I'll look and see. The cams shouldn't be allowed to just snap back. This can allow the exhaust and intake valves to collide on the way to their closed positions. Factory service manual says for installation the exhaust cam is rotated counter clockwise then the intake cam rotated clockwise. This is as you are looking at it for installation. Removal is intake rotated counter clockwise then exhaust rotated clockwise. This is important and people that don't follow this often end up with a valve bouncing around in the combustion chamber ruining the engine. It is best to use the cam pulley tools to hold and rotate them or if the bolts are torqued you can use 10mm Allen bolts on breaker bars to hold and rotate the cams. Have a buddy help and it's a lot easier.
Edit until I can look I think the drill bit is 7/16"
Old 01-02-2013, 04:57 PM   #58
Type2
Member#: 200436
2004 Forester XT
I was going to hold the driver side AVCS cam using my hex bit and breaker bar and using the belt to stop the bottom from spinning. That's how I put them on. It's a challenge but I'm sure I can keep it from spinning. I'll try drilling out the bolt tomorrow. I'll just keep going up in size until something works. I'm just worried I might not be 100% level and muck up the cam gear.
Old 01-04-2013, 08:18 PM   #59
Type2
Member#: 200436
2004 Forester XT
Received my new Turbo! Borg Warner AGP S200sx-RS-56. Behold the glory!
Next to my APS SR 50 56lb/min turbo (for reference the BW is 55lb/min)
Old 01-04-2013, 08:22 PM   #60
Type2
Member#: 200436
2004 Forester XT
With flash!
Old 01-04-2013, 08:22 PM   #61
Type2
Member#: 200436
2004 Forester XT
It weighs close to twice as much as my APS SR50
Old 01-04-2013, 10:32 PM   #62
kakarot09
Member#: 182375
08 Sti
Wrbm
Whatever you have to do with the cam gears. I just think its easier with a buddy the cam bolts you don't have to be completely perfect. Just go slow and keep checking it. Once you see a little gap form just hit the rest until the head comes off.
Old 01-05-2013, 08:06 AM   #63
Type2
Member#: 200436
2004 Forester XT
Thanks bud. That makes a lot of sense.
Old 01-08-2013, 12:05 PM   #64
Type2
Member#: 200436
2004 Forester XT
Going to run AN lines to my turbo. I'll probably do the whole oil-feed / AVCS line replacement discussed at iwsti
I think this top picture here is my turbo oil feed line.
I am pretty sure this is my turbo oil drain line.
If someone disagrees with my labeling let me know. I am not 100% sure on this, but I think I'm correct.
Old 01-08-2013, 01:09 PM   #65
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Check out the Tigwerks AN oil return. Lets you run AN from the turbo to the block...very nice
aboothman is offline   Reply With Quote
Old 01-08-2013, 04:39 PM   #66
Type2
Member#: 200436
2004 Forester XT
Is THIS what you are talking about? It looks awesome.
Edit: just purchased it. Need to look for -10 AN lines that will fit. Thinking about going with the P&L kit for the AVCS/Turbo feed line
Old 01-08-2013, 06:28 PM   #67
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Get a straight 10 AN male fitting for your turbo. Get a russell push lok hose and fittings...1 foot of hose should be plenty for 2 setups. No need to get a line made for the oil return...especially for what a section of 10 AN would cost!! Besides you new to be able to make a custom length line...
As for the avcs lines you can just follow the how to you linked and do it a but cheaper if you want. As you can see I ran AN everything, and saved a LOT of money by doing the fuel and coolant lines myself. Some may not want the risk... Which is why I did not make the high pressure oil lines. For coolant tho...make them ****s yourself!!
Could get you fitting sizes and banjo fittingi thread size/pitch if you need it. Not sure what borgs run but the block I know
Old 01-08-2013, 07:45 PM   #68
kakarot09
Member#: 182375
08 Sti
Wrbm
http://i134.photobucket.com/albums/q...1327186089.jpg
That looks very nice. I think I'll do mine just like that. I already have the fitting for the block and summit is local to me so it should be pretty easy
Old 01-08-2013, 07:58 PM   #69
Type2
Member#: 200436
2004 Forester XT
Man, you are full of great info... Your setup looks great too. I am unsure what to do with my water line, since the turbo is only oil cooled. I suppose I can block off both ports, but I think the easiest would be to just run a hose connecting the two.
Where do you buy your AN parts at? JEGS?
Regarding the BW turbo, I took a look at the website and this is what I dug up (LINK):
Oil inlet: 1/4" NPT
Oil drain is the standard T3-T4 with M8 threads
It doesn't mention what the tread pitch is??? I suppose I can call AGP up tomorrow to get some straight answers. They sell accessories, fittings, etc HERE.
Regarding fitting sizes, banjo fitting thread size/pitch etc anything you throw my way is a help. The major stuff is over and it's now the little nick knacks that are keeping me up at night.
I'm hoping to get the engine in this Sunday, and I'd like to have it started with a break in tune the 20th.
Old 01-08-2013, 08:16 PM   #70
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Ya Jegs Summit or wherever. Depends whether you are a brand whore or just want the parts. It was worth the effort for me, but I hate hose clamps on any oil or coolant line lol.
Oil cooled saves you some time. Remove some clutter and just plug the hole for the turbo coolant supply. It should not affect engine coolant flow as that is basically an ancillary system. May actually improve it...and less crap to leak
ATP Turbo is a great source...a little expensive, but their site helped me piece things together. Good folks there. Same for AGP.
As for misc thread sizes etc dont forget about your local hardware store. They usually have a bolt size finder in the nuts & bolts section. I will dig up my list of what goes where tho.
I believe I used a 14mm to 6 AN banjo for either the block or turbo coolant...for anyone reading this in the future I believe I used 12mm 1.25 thread pitch -6AN fittings for the turbo coolant but that is a Garrett GT turbo.
Ya it is badass...and will never leak again!! Just make sure you guys lube up the o-ring on the Tigwerks piece well...I busted an o-ring on my first in car install and had an oil leak :/ Luckily he usually includes 2
Old 01-09-2013, 08:34 AM   #71
Type2
Member#: 200436
2004 Forester XT
For the oil drain, I picked up one of these this morning on fleabay $15 shipped:
Still looking into what thread per inch the oil inlet is. AGPTurbos aren't open yet, so can't call. I do know it's a 1/4" NPT, so I will need a 1/4" NPT --> -4 AN adapter.
Old 01-09-2013, 08:59 AM   #72
cowboy_Rob
Member#: 194062
2003 Impreza WRX
1/4 inch npt is the thread. Npt means National pipe thread which means its tapered threads so its self locking and self sealing
cowboy_Rob is offline   Reply With Quote
Old 01-09-2013, 09:07 AM   #73
Type2
Member#: 200436
2004 Forester XT
Just picked this 1/4" to -4 AN adapter up for my turbo inlet. Now I need to focus on the lines. I've watched a few YouTube videos on how to cut lines and install the ends on. Doesn't sound too scary or complicated.
Probably my favorite video on how to make AN fittings and hoses is this one below. I'd skip to the 3:30 mark
Old 01-09-2013, 11:52 AM   #74
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Wrap the stainless in electrical tape...and wrap it TIGHT!! I had best results cutting it with a dremel. Then lube it up and twist the collar on making sure you keep it flush when install the threaded piece inside of it
Old 01-09-2013, 12:57 PM   #75
Type2
Member#: 200436
2004 Forester XT
any particular place you get your SS lines?
