Old 10-29-2012, 03:40 PM   #1
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
Default Late EJ20G fuel cut?
My car is a 99 RS with a late ej20G swap.
I'm getting a fuel cut or hesitation when I'm at WOT in 3rd gear. At first I thought it might just be overboosting because I was in the process of setting my Hallman Pro MBC when i started having these problems. But I turned the boost down to 9psi and I'm still having the problem.
Is this fuel cut? Also, I just went a step colder on my plugs. They are NGKs set to .030, not sure if that could be causing the issue since I'm still on the stock tune.
I've read threads on fuel cut. I don't have an intake, but I do have a cone filter replacing the box since I never had the stock air box for the turbo motor. I also took off the plastic cover for the vent which is right above the cone filter. I am getting a lot of flow from the intake, which could be causing the MAF to freak out.
I'm gonna go back to NGK BR6ES plugs and see what happens in the mean time. Cheers.
GGSimpreza is offline   Reply With Quote
Old 10-29-2012, 05:58 PM   #2
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Check your ignition coils to make sure they are not cracked. Common issue on the G series motor.
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 10-29-2012, 07:15 PM   #3
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Kirill
Late G ran wasted spark so unlikely.
i_c_the_light is offline   Reply With Quote
Old 10-29-2012, 07:18 PM   #4
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
OP is the stock BCS still plugged into the harness?
Old 10-29-2012, 07:22 PM   #5
RallySport Direct
Member#: 33174
We are Open Late!
My bad, didnt notice the part about the late EJ20G
Kirill
Old 10-30-2012, 12:50 AM   #6
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
Haha exactly.
I just bought the motor from a JDM supplier, no stock BCS. They didn't have it.
Old 10-30-2012, 06:04 AM   #7
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Find one. As long as it's just plugged in but not controlling anything that SHOULD fix it.
Old 10-30-2012, 11:01 AM   #8
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
Or if I put the correct resistance in instead?
Old 10-30-2012, 01:31 PM   #9
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Try it.
Old 01-01-2013, 09:46 PM   #10
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
I tried it and it was fixed for a bit, but went back to having the issue. Further diagnosis is on the thread about 5000 rpm EJ20G power loss.
Any suggestions? Up the resistance? I took out the 22 ohm resistor and it was fine.
Old 01-04-2013, 07:38 PM   #11
Stangy
Member#: 329676
1999 GC8 R-STI
Check your injectors. Or fuel pump..sounds like fueling issue.
Stangy is offline   Reply With Quote
Old 01-05-2013, 04:16 PM   #12
dscoobydoo
Member#: 57152
---- Subaru fleet
garage ( 5 and counting)
What is your ECU for this swap?
dscoobydoo is offline   Reply With Quote
Old 01-05-2013, 09:04 PM   #13
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
I have the 2S ECU.
