Old 10-30-2012, 08:15 PM   #1
indywagon
Member#: 215814
2010 Tundra
Red
Default EJ18 Wiring Harness
I have a 93 coupe w/ a EJ18 and manual tranny. Trying to make a reliable running car "chump car" however missing wiring harness. I have been looking online and in junkyards for one. I am wondering what other models can I cannibalize from, will any EJ18 work? Also would like to go to 96 or later if possible so I can have OBDII.
indywagon is offline   Reply With Quote
Old 10-30-2012, 08:20 PM   #2
GreenL
Member#: 177721
1995 Impreza L
ABP
I would just go to a junkyard and get another OBD1 harness. Way to much work and research needed for OBDII.
Also while you are at the junkyard pick up an EJ22E. You can then put your 1.8L intake manifold on the EJ22 and it is a direct swap!
Or if you want even more power, get the EJ22E...put your 1.8L heads on the 2.2 block....use your 1.8L intake...and you have yourself a nice little high compression motor that will be fun a peppy.
GreenL is offline   Reply With Quote
Old 10-30-2012, 08:30 PM   #3
indywagon
Member#: 215814
2010 Tundra
Red
^^^^ I like the thought of the EJ22 but with the race format there is a price limit I have to stay under.
