Old 10-30-2012, 08:53 PM   #1
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Question Time for a one piece drive shaft? '12 WRX - All bushings and mounts, still sloppy.
So, in an endless quest for perfection, I've installed literally every single drivetrain bushing and mount available for my 2012 WRX; engine mounts, pitch stop, gearbox bushings, trans mount, STS kit & bushings, rear diff inserts and subframe inserts.
When I let off the throttle, make an imperfect shift, etc though, I STILL get that awd 'bounce', slack, clunking, etc, (different from true internal gear slack, which I feel when rolling in 2nd, for instance).
Will a one piece drive shaft fix this? Or should I buy the $35 drive shaft bushings? (I hear they don't do anything because of the giant 'donut' gasket.)
I love my modded WRX, and much more than when it was stock; it's taut, it's responsive, it's crisp, etc but really only when you get it perfect, otherwise the car bucks and bounces and will even do so when you just let off the gas
blehhh is offline   Reply With Quote
Old 10-30-2012, 09:52 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
some of that is yer t00n....but some is also that crappy ds....get a cf one
Old 10-31-2012, 11:36 AM   #3
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
While a CF DS would be quite prime, I don't know how I feel about shelling out $1500 for a DS. Anyone have an aluminum one? Do they get rid of that bounce?
Old 10-31-2012, 11:51 AM   #4
Geeoff
Member#: 106439
06 WRX TR
'05 Matrix XRS
The DSS CF shaft is only $1000. One of my favorite mods for sure.
Geeoff is offline   Reply With Quote
Old 10-31-2012, 12:23 PM   #5
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Looking around online, you're definitely right. It is more like $1000. *sigh* Next spring... next spring.
Old 10-31-2012, 12:30 PM   #6
connorlug
Member#: 275276
2007 FXT
CGM
Damn dude you must hate stock cars the things brand new! lol
connorlug is offline   Reply With Quote
Old 10-31-2012, 12:37 PM   #7
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
I've been playing video games for too long, I think. I'm used to immediate throttle response, cars that feel like a solid chunk of engine, and no perceived drivetrain slack or body roll or anything. Just acceleration, deceleration and turning lol.
My mods have all added up to a serious improvement over stock though. I used to cringe at the thought of driving my WRX in the morning because of how much play there was in... every single thing about it. It felt like the whole car was held together with a series of ham sandwhiches.
Now it's taut, responsive, solid, smooth, etc except for when you get it wrong or let off the throttle.
Old 10-31-2012, 03:39 PM   #8
skets
Member#: 170698
2003 WRX V-Limited
I'm looking forward to hearing the answer to this because I am in exactly the same situation and like you I think the $400 aluminum driveshaft will be more than enough (dont see the need to drop a grand on the CF one).
skets is offline   Reply With Quote
Old 10-31-2012, 03:58 PM   #9
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Glad to hear that I am not the only one experiencing this and willing to pay to have it eliminated. I was really hoping the Group N engine mounts were the last lose end, but I guess not. Even after the drive shaft, I suppose there will always be the true internal mechanical slop, as well as the sprung clutch. I hope I can live with those!
Kind of relieved to know that there is yet another step to be taken to further improve driveability.
Old 10-31-2012, 06:41 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
d00000ds....im thinking that this whole 'rubber banding' thing is in the tune....the throttle needs to be retuned so it wont do this most likely
it is IMPOSSIBLE to take ALL the slop outta this driveline as the whole awd thing means LOTS of parts that gotta work together and that involves some inevitable slop in the system
i think that if it isnt a tuning issue, ya need a differnt car....or learn how to drive it so it wont DO that
Old 10-31-2012, 07:03 PM   #11
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
I can drive it so that it won't, it just takes a lot of precision for a DD, which gets most of its mileage while you're half awake, or coming off a long day at the office. I still rip on it, and I'm up for that when the road beckons, but my mad driving skillz are in tatters during a commute.
To be honest though, driving home today was fine and I do feel the difference that the engine mounts have made. The bouncing, rubber banding issue, (at this stage in the game) is something that I'm blowing way out of proportion in my mind.
Old 11-01-2012, 11:53 AM   #12
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
It is not the "tOOn"...once you let off the throttle the injectors shut, and as soon as whatever air is passing through the intake has been used the engine is out of the equation. A front mount makes the issue more pronounced, especially when you stab the throttle, but most of what is experienced is exaggerated by the drivetrain.
The car bounces for the exact reason you think it does, drivetrain slop. Especially in the carrier bearing.
I used to experience it, and then I installed a 1 piece. Then I switched back to the OEM, and later back to the 1 piece again. I also have every bushing available as I too hate drivetrain slop ad wanted a firm responsive car.
There are pros and cons to a 1 piece...especially if you pick up an aluminum piece. They are expensive as well. I would recommend looking into a steel 1 piece with good quality yokes and replaceable ujoints.
Before anything, however, see if you can find a car that has one to drive and see if it has the same behavior. In my opinion, and experience, it is the cause of your issue, but it is a different car...
aboothman is offline   Reply With Quote
Old 11-01-2012, 12:28 PM   #13
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
I just wish there were a way to lock the carrier bearing in place. That outrigger and the rubber connecting to the carrier bearing allow such a huge amount of transverse play in the drive shaft.
Old 04-24-2013, 11:34 AM   #14
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Welp, finally pulled the trigger on a PST Carbon Fiber Driveshaft a few minutes ago. I'll let you guys know how it turns out... Car is fully tuned on Stage III now, and the two-piece driveshaft is really spoiling the fun.
Old 04-24-2013, 02:49 PM   #15
Rally2
Member#: 132023
2005 STI
blue
Interesting thread, definitely let us know what the 1 piece c/f shaft does for drivetrain slop and throttle response
Rally2 is offline   Reply With Quote
Old 04-24-2013, 04:30 PM   #16
BigAir
Member#: 200496
2008 WRX
Obsidian Black
Yes, I'm interested as well. 08 wrx. I'm near my "point of no return" for modding vs putting back to stock and getting an sti (for the 6sp and differential). Some of those bushings were a pain in the #ss to install. As I slowly move this car more toward track duty with bushing and suspension improvements, I would like to see about increased "driveability" and responsives with a CF one piece drive shaft. First event is this weekend
The Kartboy pitch stop I just installed made a difference in how my car starts out from a stop and responds to throttle. I've been dreading tackling the engine mounts, but will get to it.
BigAir is offline   Reply With Quote
Old 05-01-2013, 12:52 PM   #17
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Well it's here, and it looks pretty good, and yes, it's quite light. The paint is sanded off the u-joints here and there, but the CF looks perfect. Hopefully get it installed this weekend.
Old 05-01-2013, 06:19 PM   #18
Blktrax
Member#: 220971
2002 WRX 213K Mi.
Original Motor and Turbo
Are you going to ....
http://www.advancedclutch.com/6240018
No doubt losing the carrier bearing is going to help, but an un-sprung clutch disc is going to affect on/off throttle transition more severely.
Blktrax is offline   Reply With Quote
Old 05-01-2013, 08:43 PM   #19
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
That's what I'm afraid of... I'm really hoping what I feel isn't the clutch, and that the DS fixes it.
Old 05-01-2013, 10:18 PM   #20
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Sooo, I'm pretty sure this is wrong, right?
Old 05-01-2013, 10:51 PM   #21
Blktrax
Member#: 220971
2002 WRX 213K Mi.
Yea, that's not going to work on a Subaru rear diff, they're all 4 bolts unless modified.
http://www.driveshaftshop.com/import...ber-driveshaft
Old 05-01-2013, 11:00 PM   #22
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
PST packaged it wrong then...
Old 05-01-2013, 11:07 PM   #23
Blktrax
Member#: 220971
2002 WRX 213K Mi.
*edit* likely mis-packaged, see pics below.
I see the pic there... I wonder if its a discontinued product...
http://www.pstds.com/carbonfiber.htm
Other than whats on the link above, it says call to order a custom drive-shaft, and that part/application isn't listed.
I Digress rallysport direct has that part number listed for the WRX and the picture appears to be correct.
http://www.rallysportdirect.com/PST-...ber-Driveshaft
Old 05-01-2013, 11:53 PM   #24
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
e-mailed the retailer. Hopefully they can take it up with PST. I'm curious what car this is for...
Old 05-01-2013, 11:58 PM   #25
Rodwrx23
Member#: 170948
I absolutely love my DSS cf shaft. I got tired of staring at it online and saying "next year" for several years in a row. I got a sweet deal on it too from IIR
Rodwrx23 is offline   Reply With Quote
