Old 10-31-2012, 03:17 PM   #1
slimshade1
Member#: 320515
98 impreza obs
green
Default Good idea or bad idea?
Is it a good or bad idea to take my cats off. I just dont want them anymore i dont need emissions where i live. i have 188xxx miles and the only mod i have is a magnaflow axle back
slimshade1 is offline   Reply With Quote
Old 10-31-2012, 03:26 PM   #2
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
Environmentalist: Leave them on. Save the trees.
Hoon Goon: Ditch them, but keep them in a safe place in case you need them for inspections years down the road. OEM replacements are $$$$$.
Note: This is bad advice. Leave your emissions equipment alone. EPA is your daddy and knows best.
Hoon Goon is offline   Reply With Quote
Old 10-31-2012, 03:43 PM   #3
slimshade1
Member#: 320515
98 impreza obs
green
i dont have emissions where i live
Old 10-31-2012, 05:34 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
No emissions in Gilbert? I could have sworn I had to when I lived there...over 10 years ago. Either way, running sans cats would be louder, so there's that to consider. Some say you won't notice any power gain. You could give back to the community and do some dyno tests.
Old 10-31-2012, 05:41 PM   #5
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
If you eliminate the cats, you'll need a track pipe and a resonator. If you just knock out the catalyst element, you'll create an expansion chamber and lose hp.
I tried a track pipe, and it through off how my car ran (already heavily modified) so I opted to not run it until i can get a tune.
cal_look_zero is offline   Reply With Quote
Old 10-31-2012, 06:07 PM   #6
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
It just seems like a lot of work for a whole lot of nothing, as in no real power benefits.
I also hate the smell of catless
chazly413 is offline   Reply With Quote
Old 10-31-2012, 06:35 PM   #7
slimshade1
Member#: 320515
98 impreza obs
green
I just moved to heber overgaard and haven't updated this yet
Old 11-01-2012, 03:00 PM   #8
travis175
Member#: 336727
if you have no need for them where you live, then do it man
travis175 is offline   Reply With Quote
Old 11-01-2012, 08:14 PM   #9
Foenetik
Member#: 335785
2008 Impreza 2.5i
Honestly, if you have stock piping diameter your really not going to gain much. Yes youd free up some flow but your still going to be restricted overall by the oem piping size. I dont personally feel its going to justify the cost of replacing them with straight pipe for the little gain youd get.
Foenetik is offline   Reply With Quote
Old 11-01-2012, 10:38 PM   #10
KelConquer
Member#: 321498
1998 Legacy W. EJ25
Have you ever seen the inside of a catalytic converter..? There's more than "some" airflow to be freed up there...
Do it. I replaced my 2nd and 3rd cats with 2.25" piping and my lower end definitely increased just enough to notice.
KelConquer is offline   Reply With Quote
Old 11-01-2012, 10:43 PM   #11
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Just knocking the cats through will decrease HP and Gas mileage
EvileyeZ88 is offline   Reply With Quote
Old 11-01-2012, 10:46 PM   #12
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Subaru cats flow surprisingly well for OEM. Plus, it's not like the stock engines produce THAT much flow that the cats are prohibitive.
I'm sure anything helps, but it's like tucking for aerodynamics on a Vespa scooter.
Old 11-01-2012, 10:51 PM   #13
chazly413
Member#: 151079
2005 2.5RS RBP
Yes, I'm sure the engineers who designed the exhaust system completely disregarded that honeycomb in their design parameters.
I agree with you if we're talking about adding a good bit of power, but it's designed to flow with minimal restriction for a stock system.
Old 11-02-2012, 12:17 AM   #14
Foenetik
Member#: 335785
2008 Impreza 2.5i
Oh. You got me. Never saw the inside of one. Your probably right then.
Old 11-02-2012, 01:27 AM   #15
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Hey, if it works on a Trek...
Counterfit is online now   Reply With Quote
Old 11-02-2012, 02:03 PM   #16
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
My vote is bad idea.
(1) There will be little to no gain in performance.
(2) Your exhaust will stink.
(3) You'll trigger a cat efficiency CEL.
(4) While there may not be a local requirement for emissions testing in your area, your car is still required to have emissions equipment on it. That's a federal requirement courtesy of the EPA. Cats that are no longer functional or are missing are (per the EPA) required to be replaced with an equivalent cat. Moving to a new location doesn't change that federal law.
Old 11-02-2012, 02:16 PM   #17
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
An Ej22 with 188k mi on it? You'll gain back maybe 2hp, and that is if you do it properly with all new piping. You won't even feel the difference.
Old 11-02-2012, 02:30 PM   #18
slimshade1
Member#: 320515
98 impreza obs
green
i was told its a good idea on rs25....
Old 11-02-2012, 04:12 PM   #19
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Well then, that settles it. Chop those bitches out!
Old 11-03-2012, 09:53 PM   #20
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
It will be more responsive without the cats and you will gain a little fuel mileage but it could mess up your tune.
Old 11-04-2012, 02:44 PM   #21
slimshade1
Member#: 320515
98 impreza obs
green
so ill just have to get it retuned??
Old 11-06-2012, 01:57 AM   #22
Eyedoc Orlando
Member#: 146216
2007 Impreza 2.5i SE
Newport Blue Metallic
$400,000 fine = bad idea
Cats dont reduce power these days, leave them on
Eyedoc Orlando is offline   Reply With Quote
Old 11-06-2012, 09:33 AM   #23
EvileyeZ88
Member#: 233501
99 outback sport
Tune??? On a na with 188k????
Just leave the cats in place, your going to cause yourself more headaches than its worth.
I had to remove the cats from my system on my 99 obs because they were disintegrating, rattling and shooting out the tail pipe.
I even did the spark arrestor trick to defeat the cel
After doing so I noticed decreased gas milage, the car felt more sluggish, sounds like Ass, and stinks to high heaven.
The only way to get a better sound and more power is to have an UEL header fabbed up (sound) and have a custom header back exhaust made (power)
If you want power you got the wrong car for it. You need turboZ
Old 11-06-2012, 10:05 PM   #24
Blase M
Member#: 84955
2000 impreza rs
blue
Cat-less will be loud and smelly. Probably not worth it on your 2.2. However, if you do it right, with stainless steel exhaust manifold and the cat section (either track pipe, or high flow cat), you'll at least have an exhaust that will outlast the rest of your car...
Blase M is offline   Reply With Quote
Old 11-20-2012, 09:34 PM   #25
Elmerfudgeboost7
Member#: 333979
2012 e85 wrx
If you take off your cats your killing penguins, what did they ever do to you?
Elmerfudgeboost7 is offline   Reply With Quote
