#1 |
Member#: 23062
Vehicle:2002 Impreza WRX Silver |
i am considering upgrading my stock '02 WRX intake. However i was worried taking in water. I live in Mass and when it rains here, which is not that often, it really comes down. When i saw the AEM cold air intake with the air bypass valve it looked like a god send. However when i went to look up the part number it was listed as N/A. Does anyone know if there is an air bypass for the AEM cold air intake for the '02 WRX? If there isn't, like i suspect does anyone know when AEM plans on releasing it?
Thanks.
#2 |
Member#: 21704
Vehicle:Sold my WRX 8/21/2009 :'( |
I have the AEM CAI (love it!), not sure, but I think the reason that you can't use the bypass valve is because there isn't room enough for it. It's a tight fit as it is, and with the extra 2" or so that the valve would add, I think the intake piping would run into the outside fender. The instructions that come with the CAI specifically tell you *not* to use the bypass valve. Hope this helps.
#3 |
Member#: 12434
Vehicle:2002 Impreza WRX Aspen White |
From what I have heard its not the room thats a problem.....it is the turbo sucking the valve open when it shouldnt be. Oh yeah....it sucks too...I had one on my N/A Eclipse and the valve broke in half and almost sucked the foam inside the throttle body...that has supposedly been fixed though. I wouldnt worry to much about water though...i think that subject is way over rated. Im on my second car with a CAI and have had 0 problems. Hell, I removed the piece on my bumper in my Eclipse and when it was raining the filter would be in direct contact with the rain. You would really have to drive in some deep water to suck that much in.
#4 |
Member#: 16495
South East
Vehicle:2013 BRZ Sterling Silver Metallic |
Search here in FFI for the words AEM & bypass.
The foam coating on the valve has been know to get SUCKED into the piping and then foul out the turbo. If you're living in a high water area, consider a short ram/pod filter for more piece of mind. Hydro lock is a VERY expensive lesson. Shaun |
#5 |
Member#: 23062
The problem with the bypass breaking up and being sucked into the turbo and clogging the throtal body housing has been fix. So that is no longer a concern... Why wouldn't AEM just shorten the pipe by two inches if the it was a little big that way the bypass would work. Something tells me that there has to be a better reason than room. The turbo sucking it open when it shouldn't be seems more likely.
#6 |
Member#: 14970
BAIC
Vehicle:1997 GF8 multi |
I heard on www.subarureviews.com that the AEM actually decreases HP and Torque. I have an Injen Race Div. and its a great performer, but I hate that BOV sound EVERY time I shift. It gets annoying. Air Intakes increase HP by leaning out the air/fuel ratio. Just do a pannel filter until you upgrade your ECU.
About the Air Bypass thing, They sound like they work, but I woudn't trust one to not take in any water. Rich P.S. Any intake with a tube size of 2.5" 2.75" or 3.0" can get a bypass valve spliced into it, from what I read on www.injen.com |
| Thread Tools | |
| Display Modes | |
| FS: '05+ Legacy GT/Spec-B Cobb SF air intake and air box | DrnknZag | NWIC Private Classifieds | 14 | 06-02-2010 03:47 PM |
| KS: WRX/STI AEM Cold air intake and Short Ram for sale | MPOWERD | Private 'For Sale' Classifieds | 3 | 10-08-2004 01:04 AM |
| AEM cold air intake and HKS Hi-Power exhaust | JonnyP | Private 'For Sale' Classifieds | 3 | 02-09-2004 04:55 PM |
| air intake and blow off valve | 04subaru | Factory 2.0L Turbo Powertrain | 8 | 09-24-2003 09:11 PM |
| AEM cold air intake and Turboxs HRFL | Blue02REX | Private 'For Sale' Classifieds | 2 | 09-10-2003 02:07 AM |
