Old 11-01-2012, 10:44 PM   #1
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
Hello all,
New to modding and tuning, just bought 2008 Wrx & love the car but after reading everybody else's!!!' Feeling slow!!
Engine Bay:
AEM cold Air
Turbo smart supersonic 50/50
Tomioka Headers
GT-Spec strut tower brace
VF52 swap
Exhaust:
Invidia Q300 full 3" turbo back
Suspension:
Perrin sway bars
Tanabe 1"1/4" in racing springs.
Pro tune by: Bobby @ PRE Portland!!!
287.8whp.@ 6000
279torque @ 4700
No Injectors or FMIC yet Boost set peaks at 16lbs
Blindman29 is offline   Reply With Quote
Old 11-02-2012, 12:59 AM   #2
ppayer38
Member#: 234407
04 Self-tooned
STi
You might not have awesome peak #'s but the power under the curve and powerband are great looking... But please revise the format of your thread to meet the criteria
ppayer38 is offline   Reply With Quote
Old 11-02-2012, 01:02 AM   #3
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
Ok what criteria and what do I need to do. thank you for response.
Old 11-02-2012, 01:09 AM   #4
mpen747
Member#: 292343
how much boost?
mpen747 is offline   Reply With Quote
Old 11-02-2012, 01:16 AM   #5
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
Running and peaking 16lbs without FMIC tuned down do I don't hurt Stock TMIC
Old 11-02-2012, 01:52 AM   #6
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
need to ditch stock injectors and TMIC.
Old 11-02-2012, 08:51 AM   #7
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
Absolutely need to ditch. Just doing it in order. Going to do fuel pump and injectors next. The Turbo XS FMIC. Should be pretty solid there. Not sure what numbers ill put down. Tuner Bobby at PRE said my car would've broke 300whp easy on last tune but Top fan went out that morning so wasn't even blowing on top mount so they where being safe.
Old 11-02-2012, 09:39 AM   #8
Tripintaz
Member#: 245218
2013 STI Limited
16psi is conservative. The stock TMIC will handle 18psi just fine. Also, you don't need injectors to go to a FMIC if you are keeping the vf52 turbo.
Tripintaz is offline   Reply With Quote
Old 11-02-2012, 09:48 AM   #9
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
Ill be doing a turbo swap. I'm building up everything else to get it ready. Injectors are running almost at max right now I don't want it running at max. I agree I don't have to on current turbo but injectors aren't a bad price 600.00 to 900. Depending on which ones.
Old 11-02-2012, 10:46 AM   #10
thisisntjared
Member#: 177891
06 wrx wagon
child seat/tow hitch cgm
please dont make me turn my head sideways. anyway, what the others say makes sense, more fuel and cooler air will increase your ceiling for power.
thisisntjared is offline   Reply With Quote
Old 11-02-2012, 12:25 PM   #11
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
Originally Posted by thisisntjared
please dont make me turn my head. anyway, what the others say makes sense, more fuel and cooler air will increase your ceiling for power.
Absolutely agree. I'm working my way to there just taking a step at a time. but I do agree.
Old 11-02-2012, 12:35 PM   #12
Paul
Member#: 56203
00 RSTI Coupe
for injectors get ID1000s for <$500. They will handle 500whp on E85 with the right mods.
Id get a new intercooler first tho...the stock one on your car is really a POS
Old 11-02-2012, 12:55 PM   #13
thisisntjared
Member#: 177891
06 wrx wagon
hahah i forgot to add 'sideways'
Old 11-02-2012, 01:04 PM   #14
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
I know it's A definite POS TMIC. That's my next thing I'm getting that's big. Looking for a 2009 legacy Gt spec B transmission for Tranny swap. Also
Old 11-02-2012, 01:39 PM   #15
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Everybody starts there at one point or another.
C J is offline   Reply With Quote
Old 11-02-2012, 01:48 PM   #16
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
Haha I know. I'm a small fry right now though! Lol
Old 11-02-2012, 01:54 PM   #17
ppayer38
Member#: 234407
04 Self-tooned
STi
Just start small man do all the basic bolt on's like injectors, pump, inlet, IC, etc and youll be suprised at what the car puts down without E85 and a new turbo... The 5spd will handle the torque you just have to take care of it and not bang gears like a retard on crack...
Old 11-02-2012, 02:21 PM   #18
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
I don't launch and am careful down shifting! But love the analogy!!! Haha
Old 11-02-2012, 09:13 PM   #19
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
looks a little low compared to others on here. im running 22 psi on a stage 3 vf52 swap on my 08. im using a torqued performance map. still using stock injectors and just a stu fuel pump for now. i dont have a dyno close to me to use.
424wrx is offline   Reply With Quote
Old 11-02-2012, 09:54 PM   #20
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
22psi? Stock TMIC? What is all done to yours?
Old 11-03-2012, 10:27 AM   #21
CobbsSTI
Member#: 245242
2005 STI
E85 Power
You really do not need a fmic, on a vf52 all your gonna do is give the car more lag. The stock tmic will.handle around 20.5 psi. I'm taking it you want the fmic for looks? With wrapping your DP correctly and a turbo blanket plus a heat shield with heat reflective tape on the under side of the shield, you'll be good to go if your concerned about heat soke. I'm making 450+ HP with a Blouch Dom 1.5xtr on a Process West top mount with everything wrapped up, heat and flow is not a problem. 16psi is nothing on that top mount, turn it up to 20 or so and be done for a while. Unless you have "BIG" plans for the car by all means go with your fmic.
CobbsSTI is offline   Reply With Quote
Old 11-03-2012, 11:09 AM   #22
CatfaceType-R
Member#: 81102
The lag is very small, the knock retention with a consistently cooler charge is not a small change. This discussion has been beaten to death. A fmic is better if every aspect other than a very minute lag, crash=engine damage, and non sleeper status.
CatfaceType-R is offline   Reply With Quote
Old 11-03-2012, 11:59 AM   #23
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
Yes bigger plans not keeping VF52 at all for long doing everything else first to be ready for bigger turbo drop. But you say it can handle 20.5 psi at Max? TMIC that is? Is that with external waste gate or re circ? Because boost creep will most likely be the case with fuel cut is why I have low also. Enlighten me please.?
Old 11-03-2012, 12:13 PM   #24
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
Agreed! Beaten to death. That's why I am going front mount.
Old 11-03-2012, 07:48 PM   #25
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
nah, perrin tmic.
vf52 swap
tomei el headers and uppipe
perrin catted downpipe
borla catback
grimmspeed ebcs
perrin cai
forge bpv
grimmspeed aos
2011 sti fuel pump
bilstein cup kit suspension and rallitek sways and endlinks.
i went to the track for the first time on my life last month. i couldnt get launching down. i ran 2passes- 13.3 @ 104. im sure with some practice 12s are easily doable. injectors, fuel pump and plugs are next in the spring im thinking. very happy with the power though. beats what it was like stock 5 years ago with the td04 turbo!
