Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 11-01-2012, 11:28 PM   #1
Joe-schmoe88
Member#: 314722
2006 STi
Default Need help!!!!! Engine codes P2006 and P0245
Okay soo heres the deal I just spent 1400 bucks to have my 06 STi serviced and fixed by a subie dealer and before I took it in it was kinda a mess leaking fuel line leaking coolant and a broken harness any who they ended up changing the whole harness and what not some hoses and fixed my fuel leak out took 3 weeks for all this so finally I get my car back and the biggest thing of all my turbo doesn't spool at all now and my bov doesn't even go off im soo frustrated and just need some answers on whats wrong now thanks and those are the two codes that popp up which bit to say the P2006 was on already before i took it in
Joe-schmoe88 is offline   Reply With Quote
Old 11-02-2012, 12:04 AM   #2
swpshgnwgn
Member#: 150494
11 WRX
SWP Torqued Stg II
Holy run on sentence, batman. Did you google these codes?
Edit: Here: http://forums.nasioc.com/forums/show....php?t=2223802
http://forums.nasioc.com/forums/showthread.php?t=216541
And that was just using a simple google search man. Not difficult.
swpshgnwgn is offline   Reply With Quote
Old 11-02-2012, 12:26 AM   #3
Joe-schmoe88
Member#: 314722
2006 STi
Yea I researched that already but why wont my turbo spool or anything
Old 11-02-2012, 12:30 AM   #4
swpshgnwgn
Member#: 150494
11 WRX
SWP Torqued Stg II
Did it happen right after they gave you back the car? Why don't you just take it back to the dealership that you had work on it and ask them?
Old 11-02-2012, 12:37 AM   #5
swpshgnwgn
Member#: 150494
11 WRX
SWP Torqued Stg II
To explain the codes though, the P2006 is a TGV code. It's the valve that warms up your cat for emissions control. Pretty much a useless piece ****, but they go bad pretty often. Poorly informed opinion.
The P0245 is a wastegate low reading code. That makes sense considering you're saying you aren't boosting. It doesn't explain why though. Take it back to whoever you had work on it and ask them to take a look.
Old 11-02-2012, 12:45 AM   #6
Joe-schmoe88
Member#: 314722
2006 STi
Explains, a lot better thanks man and will do
Old 11-02-2012, 12:52 AM   #7
UK-Wagon
Member#: 232430
555 I haz 5 Subarus
GC8/GF/SG/GD sedan & wag
OP, dont listen to this guy simply based on his explanation of what the TGV is and does. That is simply the most random b.s I have ever read.
UK-Wagon is offline   Reply With Quote
Old 11-02-2012, 01:04 AM   #8
swpshgnwgn
Member#: 150494
11 WRX
SWP Torqued Stg II
Whoops, yeah you're right. Didn't read into it all the way.
OP, check out this link: http://forums.nasioc.com/forums/show....php?t=1791412
Seems it describes your situation pretty accurately.
Old 11-02-2012, 09:41 AM   #9
Joe-schmoe88
Member#: 314722
2006 STi
Yea seems id be better off going with tgv deletes and the P0245 would be an easy fix
Message Board Statistics All times are GMT -4. The time now is 01:55 AM.
