Old 11-02-2012, 01:20 AM   #1
WRXSteye20008
Member#: 175565
2014 Sport Premium
Satin White Pearl
Question Losing oil on drivers side of engine, unknown cause [Photos Inside]
So my engine is up there in miles 123,857 and recently have been losing oil. About 1.5qts in 700 miles, no good. My first thought was the pistons, but wanted to rule out a turbo seal and removed the TMIC and it wasn't that. No blue/white smoke and I hit boost fine. There is a hint of burning oil. I am limping the car when I need to drive it. I am going to IAG on Monday for a compression test. I did a leak down test and everything is okay. Yesterday, I hit the engine with purple power to degrease it to see the fresh oil today and I noticed a lot of oil/water running from beneath the car.
So today after putting the TMIC back on I went under the car and saw a lot of oil running down the drivers side of engine near the rear timing belt cover. It starts around the oil tube, runs down the block, past the coil packs and puddles in the tray. I am maybe thinking a the cam gear gasket, but what do you guys think from referencing these photos?
Seems to be right on par with this: http://forums.nasioc.com/forums/show...5&pagenumber=2
Puddled oil on bottom tray
Bottom of drivers side front timing belt cover
Laying on ground on drivers side looking up, oil collecting on block
I see one thread, I wasn't sure it was backing itself out or not
WRXSteye20008 is offline   Reply With Quote
Old 11-02-2012, 01:23 AM   #2
Dillinja666
Member#: 332644
07 STI
It's white
Looks like cam seal or valve cover. Kinda hard to tell in the pic, plus it hurts my neck looking at it.
Dillinja666 is offline   Reply With Quote
Old 11-02-2012, 09:59 AM   #3
WRXSteye20008
Member#: 175565
2014 Sport Premium
Satin White Pearl
It hurt mine taking the photo with little ground clearance
Old 11-02-2012, 08:15 PM   #4
xbmxxx
Member#: 275155
2005 STi
Satin Black
Yep. When I saw the timing cover I was going to say cam seal, but then the later pictures make it look like a valve cover. Is there oil on the side of the valve cover? the plug tube seals tend to go bad also, but I cant see them in the pics.
xbmxxx is offline   Reply With Quote
Old 11-02-2012, 08:53 PM   #5
C0rnFed
Member#: 264322
07 Ethanol Fed WRX
only real way is to get in there and pull all the covers off and start removing some things to get an accurate answer
C0rnFed is offline   Reply With Quote
Old 11-02-2012, 09:14 PM   #6
WRXSteye20008
Member#: 175565
2014 Sport Premium
Satin White Pearl
I will take a look tomorrow and report back, I am glad it is external oil leak rather than internal. I know cam seals at $5 from Subaru, I have to look to see how much a valve cover is.
Old 11-02-2012, 09:37 PM   #7
xbmxxx
Member#: 275155
2005 STi
Satin Black
was there oil on the inside of the inner timing cover?
Old 11-03-2012, 12:56 AM   #8
WRXSteye20008
Member#: 175565
2014 Sport Premium
Satin White Pearl
I do not recall off hand, I want to say a little towards the bottom, but nothing like the outside.
Old 11-03-2012, 04:41 PM   #9
Elbert Bass
Member#: 283429
Wouldn't hurt to check the top of the head towards the front. There is an oil line and a couple banjo bolts as well as an oil control solenoid for the intake camshaft. Those could be a source for leakage as well.
Elbert Bass is offline   Reply With Quote
Old 11-03-2012, 11:09 PM   #10
WRXSteye20008
Member#: 175565
2014 Sport Premium
Satin White Pearl
I checked the car, a little inside, mostly at the bottom of the timing belt cover. Elbert, I will also check that as well. The car goes in the shop monday to be on a lift to have a look. I decided to do a compression test/leak down test with a friend and will post those results as well.
Old 11-03-2012, 11:14 PM   #11
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Get better at pouring youre oil into the filler neck!! thats what happens when you spill some or miss the filler tube and dont clean it up
UK-Wagon is offline   Reply With Quote
Old 11-08-2012, 02:23 PM   #12
WRXSteye20008
Member#: 175565
2014 Sport Premium
Satin White Pearl
Haha you nailed it! Small VC leak, but the result was.....
#4 piston FUC#$^@#^$%$%K!!!!!
