Old 01-03-2010, 05:17 PM   #1
Florin1
Member#: 163625
91 Legacy SS
Default Will STI heads Fit my ej22t?
Hi, i found some cheap sti heads for sale. Will they fit my 94 Legacy SS? How much better do they flow than my heads? Also, will the clutch fit from the car? It was a six speed. Thanks
Florin1 is offline   Reply With Quote
Old 01-03-2010, 05:33 PM   #2
desmo750
Member#: 111256
1992 Legacy Turbo
don't call me white...
They will bolt up to your block but your intake manifold will not bolt up.
desmo750 is offline   Reply With Quote
Old 01-03-2010, 05:45 PM   #3
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
ANYTHING is better than stock ej22t heads.
Well for the most part; ej22t heads just suck for flow.
Smoke is offline   Reply With Quote
Old 01-03-2010, 05:59 PM   #4
Florin1
Member#: 163625
91 Legacy SS
so intake will not work huh? Dang it. How about the 6spd sti clutch? Will that work?
Old 01-03-2010, 11:21 PM   #5
desmo750
Member#: 111256
1992 Legacy Turbo
If you have a 6 speed STi transmission then yes.
Old 01-03-2010, 11:53 PM   #6
Rodeoflipper1818
Member#: 193977
2007 2.5i Wagon
2004 Honda RC51
I feel like mismatching parts is not really the best idea....
Rodeoflipper1818 is offline   Reply With Quote
Old 01-03-2010, 11:58 PM   #7
EricNY
Member#: 189242
1999 GM6
Silverthorn Metallic
Works perfectly fine if done correct. Not a big deal.
EricNY is offline   Reply With Quote
Old 01-04-2010, 01:34 AM   #8
fstbckgt
Member#: 171557
Chapter/Region: HIIC
just install the sti heads with a new intake
fstbckgt is offline   Reply With Quote
Old 01-04-2010, 02:17 PM   #9
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
I'm assuming USDM STi heads.
Why bother with USDM STi heads? You should be able to find a set of JDM phase I (V1-4) heads that'll give you less headaches with the manifold and sensors.
i_c_the_light is offline   Reply With Quote
Old 01-04-2010, 02:38 PM   #10
Florin1
Member#: 163625
91 Legacy SS
Where and how much do they go for? Basically i want to flow better. I read that my ej22t heads don't flow much better than molasses.
Old 01-05-2010, 12:38 AM   #11
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
e-bay. Or you can ask around here. http://forums.nasioc.com/forums/forumdisplay.php?f=92
Old 12-06-2012, 06:53 PM   #12
MY_GC8_YOU
Member#: 329980
If you build this motor your talking about..it will be able to handle more psi than a built sti motor. Ej22 are closed deck motors and will not crack sleeves under high boost. Even if you sleeve a open deck motor you will get cylinder sleeve walk at the top of the sleeves...im looking to build a ej22 motor right now and use 2007 sti heads!
MY_GC8_YOU is offline   Reply With Quote
Old 12-06-2012, 08:03 PM   #13
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
You bumped a zombie thread for that?
Will Forester Heads Fit my EJ20? xWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-15-2007 09:37 AM
will sti struts fit my wrx fastlanerex Brakes, Steering & Suspension 5 04-23-2007 02:00 PM
will sti cams fit on wrx heads flaco357 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 03-30-2007 05:35 PM
will sti heads fit on the ej20 block? dlowman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-30-2005 08:25 PM
Will an ej20/ ej25 up-pipe fit my ej22t? lotus2843 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-17-2004 05:16 PM
