Welcome to the North American Subaru Impreza Owners Club Friday April 18, 2014
Old 11-02-2012, 10:31 PM   #1
polaks
Member#: 305714
Default Seafoam
I have a 1996 subaru sti ej20k and I was wanting to seafoam it... I tried searching and couldnt find exactely where to pour the seafoam... If someone could point out where I need to pour it that'd be great, photos or videos would be best! thanks alot
polaks is offline   Reply With Quote
Old 11-03-2012, 12:13 AM   #2
AgentJ17
Member#: 306411
1995 STi RA
3-cyl conversion...
Any vacuum line coming off the center of the intake manifold.
AgentJ17 is offline   Reply With Quote
Old 11-03-2012, 12:29 AM   #3
polaks
Member#: 305714
ahah thats what im scared of im not possitve which it would be and I dont wanna screw anything up, ill have to look around a little more
Old 11-03-2012, 02:34 PM   #4
Chaz2.5
Member#: 168181
1999 EJ205 RS coupe
2013 BMW X3 28i
Undo the vac line running to the bpv and go through that! That's what I use.
Chaz2.5 is online now   Reply With Quote
Old 11-03-2012, 06:59 PM   #5
coalslaw
Member#: 324808
2006 IWL Stg2
i posted this info on a Canadian Subaru forum regarding about seafoam, Please read link below. it includes a picture of where the vaccum hose is located:
http://www.toronto-subaru-club.com/f...ml#post1402379
coalslaw is offline   Reply With Quote
Old 11-03-2012, 11:36 PM   #6
AgentJ17
Member#: 306411
1995 STi RA
3-cyl conversion...
Don't worry about which one, as long as it goes to the center of the IM. The vacuum from the engine will draw the fluid into the engine, not anything else. BPV is also what I used.
Old 11-05-2012, 12:47 AM   #7
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Unplug an existing hose from the IM. Plug in your own hosein to the intake mani port.. No need to pour. With the engine running let engine vacuum draw the seafoam into the engine. It will suck it right up. If you have no vacuum in the line sucking up the seafoam you know your doing it wrong.
TommyAtomic is offline   Reply With Quote
