Old 11-14-2012, 11:04 PM   #26
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
amazon.com
hookedontronics.com
Rexxyou is offline   Reply With Quote
Old 11-14-2012, 11:06 PM   #27
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
Originally Posted by IA Performance View Post
The key thing when looking for speakers will be figuring out if you prefer warm or sharp high notes. This will most likely dictate which type of material the tweeters are made out of. I used to be drawn to MB Quart, but now find the highs to be a bit 'bright'. My current Forester has a set of JL Audio from the prior owner, which I enjoy. The best bet is to try and find a shop that you can hear the various Warm and Bright speakers, then make a decision. If this is not an option, then definitely ask as many questions as possible on the forums.
As for fitment into the Subaru, you will most likely need a set of speaker spacers (as many have referenced above). Note: The "free" ones from crutchfield are horrible and require metal sheers to get them to work (the rear doors at least). A few options to consider:
1) These can either be easily made with a jig saw and MDF (be sure to paint it when done) or you can purchase aftermarket units.
2) Purchase a set of adapter plates. We sell them, as do others. Our units are made out Injected Molded Reinforced Fiber Resin, which is more dense than MDF and ABS. Each kit is made in the USA using recycled materials. Guaranteed 100% satisfaction, or your money back. Simply click on the image to see all of the offerings for the 2006-7 models.
[email protected]
like to add...
they also sell them at all best buys for 10 bucks each... you just need a set for the front and the back takes a 5 1/4 easy... almost as easy as the search button worked for me 5 years ago when i had the same question
Old 11-15-2012, 12:02 AM   #28
s1eepR
Member#: 335330
2008 Impreza 5DR
Right, but what kind of numbers should I be looking at?
I've gathered 6.5 front, 5.25 rear (ideally)
Now ohms?
Watts?
That's what confuses me.
s1eepR is offline   Reply With Quote
Old 11-15-2012, 12:19 AM   #29
Ultimateone
Member#: 48025
15 Mustang GT
Originally Posted by phenryiv1 View Post
I disagree. My Polk dB651 coaxials sound better than my OEM speakers, and I had the "premium" speakers that all '11 WRX models received. THe dB651 coaxials were an upgrade.
I'd recommend Polk dB6501 components in the front, a pair of metra wiring harness, and a pair of speaker mounting adapters (http://www.subaruaudio.net/subaru-speaker-spacers/)
Under your $150 budget and much better than stock.
If you want to upgrade all 4 speakers for around $150, get Polk dB501 for the rear, Polk dB651 for the front, and 2 sets of wiring adapters and 2 paier of mounting adapters. Still right around $150.
I have the same car as you and have been thinking about updating my fronts but want to still have that decent bass the stockers give. Any recommendations that could give me great bass around the 100 mark?
Ultimateone is offline   Reply With Quote
Old 11-15-2012, 12:20 AM   #30
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Now ohms?
Watts?
The majority of speakers your looking at are going to be 4 ohms. The wattage will range from low to high. Aim for a set of 6.5 components. What matters is that you amp your speakers for the correct wattage. If the RMS range for the set is 70 per side, then amp them for 70-80 RMS. Don't worry too much about the peak power rating.
You can fit a large selection of sizes with spacers. With a 3/4" spacer you can fit some deep speakers.
Also, I wouldn't worry about your rear speakers at first. Start with components in the front and work from there.
fancyfootwork15 is offline   Reply With Quote
Old 11-15-2012, 12:29 AM   #31
BoboTheMonkey
Member#: 224615
2004 WRX
San Remo Red
Replace the fronts first. It is a huge difference. I got the Boston 6.5 inch speakers and the difference from stock is amazing. The stock speakers are sooooo bad.
BoboTheMonkey is offline   Reply With Quote
Old 11-15-2012, 12:46 AM   #32
s1eepR
Member#: 335330
2008 Impreza 5DR
Thanks guys. However, I don't want to revisit the issue since I'm going to have a shop install it, one labor charge is the goal. So an amp that does 100-100+ % of the RMS range and 6.5 front, 5.25 rear. Correct?
Any recommendations on amp?
Thanks so much in advance.
Old 11-15-2012, 08:06 AM   #33
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Your '08 has 6.5" all around. My recommendation about the dB501 in the rear had to do with the OP having a 2007, which runs 6.5" in the front and 4" in the rear, stock. With adapters, he can fit 5" dB501 coaxials and some 5.25" coaxials.
In your case, you can run 6.5" all around.
phenryiv1 is offline   Reply With Quote
Old 11-16-2012, 03:51 PM   #34
Kroller2012
Member#: 306284
2003 wrx
Go with infinity refferences 6.5 they run at about a 2ohm load and will be louder and of better quality then the polk db that run at 4 ohm load.
also i could sell you the kicker upgraded speakers which is the premium sound option for when you buy your car for 200. they are woven fiber and will beat any paper cone. Email me @[email protected]
Kroller2012 is offline   Reply With Quote
Old 11-16-2012, 04:06 PM   #35
XERO287
Member#: 253541
2011 WRX 5DR Premium
*facepalm*^
XERO287 is offline   Reply With Quote
Old 11-16-2012, 04:16 PM   #36
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Originally Posted by XERO287 View Post
*facepalm*^
Yeah, I was going to type out a long reply but that pretty much covers it.
Old 11-16-2012, 04:19 PM   #37
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Agreed.
Old 11-16-2012, 04:28 PM   #38
s1eepR
Member#: 335330
2008 Impreza 5DR
Lols, I am having them.
edit: aw shucks, Patrick I deleted my entire inbox to make space, you said db651 front, db6501 rear and did you mention an amp?
Thanks, Dave
Old 11-16-2012, 07:32 PM   #39
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Thanks, Dave
I did not mention an amp. I would say that pretty much anything with 60+ watts per channel (4 channels) would do it. Add a 5th channel if you want to run a sub off of the same amp.
Shoot me a PM if you need adapters from me (you need them from SOMEWHERE, but if you want them from me, send me a PM). And about those headlights. I could possible do the retrofit for you, but it is not really difficult. Takes time, but not tough. Search the exterior subforum for tips, and don't just follow the hidplanet directions- they have an error in the dis-assembly instructions.
Old 11-16-2012, 08:49 PM   #40
XERO287
Member#: 253541
Old 11-18-2012, 01:42 AM   #41
DraconisWRX
Member#: 162108
Having tried the infinitys, I would say stay away, had a set of 4" Refs throw my Kenwood KDC-X995 into protect mode and the 6.5" 2 ways do the same with an Alpine CDA-9886. My advice is to stick with a true 4ohm speaker unless you are planning on running a 2ohm Amp.
DraconisWRX is offline   Reply With Quote
Old 11-18-2012, 03:19 PM   #42
Kroller2012
Member#: 306284
2003 wrx
Theres something wrong with your amp, possibly a phasing issue or grounding issue. Ive been around car audio for 10+ years. Replacing speakers alone will not mess with a head unit for protection mode unless wired incorrectly
Old 11-18-2012, 03:23 PM   #43
Kroller2012
Member#: 306284
2003 wrx
DO some research. adding a new headunit, speakers amp and subs take only time and not much knowledge. Ive been around car audio for 10+ years and know the corect way of how to do everything. send me a private message of what you want done and i will recommend products. also car audio places will more then likely over charge you for everything.
Old 11-25-2012, 12:33 PM   #44
DraconisWRX
Member#: 162108
Then explain to me how polk,alpine, and kenwood speakers all worked just fine with the 2 decks mentioned? I don't have an external amp just the internal amp that is built in the the unit.
Also there are threads all over the place about the infinity speakers not working properly with most aftermarket decks.
Old 11-25-2012, 04:45 PM   #45
DarkProphet
Member#: 299707
2011 Wrx 5-Door
I'm with Kroller2012 on this one,
Infinity speakers are fine. Not my first choice, but they are fine.
The problems that you found on the internet regarding infinity not working with aftermarket units is in regards to people with "infinity" OEM systems, and they try to add an aftermarket head unit to the mix. The problem is that they are not bypassing the stock wiring/ amp. They then blame infinity speakers for the problem. The real problem is improper OEM integration.
This is NOT related to when people have an aftermarket head unit and add infinity speakers too.
DarkProphet is offline   Reply With Quote
Old 11-26-2012, 10:51 AM   #46
DraconisWRX
Member#: 162108
I'm not referring to that in the slightest. I am referring to Aftermarket H.U. With AFTERMARKET Infinity Reference speakers that are listed in their own documented specs as 2Ohm speakers but labeled on the box as "4Ohm Compatible"
Old 11-26-2012, 10:54 AM   #47
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
It's a long shot, but the Safety issue could have been from the speaker terminals grounding out on the metal door frame. I've seen this in the past with the rear Impreza doors and would suggest running electrical tape around the metal speaker hole before mounting speakers. Also, take note to where the speaker terminals when installing. This is a long shot, but it may help someone on here with the same issue.
Stephen
IA Performance is offline   Reply With Quote
Old 11-26-2012, 11:01 AM   #48
IA Performance
Member#: 25194
Dark Gray
Originally Posted by Rexxyou View Post
like to add...
Yes, there are many universal options out there for speaker fitting kits. The product we make here in the USA is specific to Subaru, whereas many of the universal brand X kits we've tried using do not line up with the factory holes. Our kit is designed for the weekend warrior that is equipped with a screw driver and not a drill. As with anything, there are options and opinions.
Stephen
Old 11-26-2012, 04:31 PM   #49
flukey
Member#: 182961
2005 outback,LLB,3.0
blue
Has anyone just bought the oem upgrade premium speaker kit and installed them?
I am sure that on the 2012 model impreza anything must be better than stock.
Just wondering if this easy to install kit is worth the money and is it really a half decent upgrade. thanks in advance.
flukey is offline   Reply With Quote
Old 11-26-2012, 05:00 PM   #50
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Don't waste your money. All speakers have the same concept for installing.
