Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 11-03-2012, 03:23 PM   #1
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
Impreza WRX 07 WRX TR Boost issue only 6 psi?
Hello, I purchased an 07 wrx from the dealership and it has been pushing only 6 psi boost. I am no mechanic but I do have mechanical skills being in the navy. The car is pretty much stock except for the 5" exhaust. Ive been reading posts on here for over an hour now. I have checked most of the vacuum lines, well the ones I can see on the turbo, MBC, inter-cooler and stock BOV. They are nice and tight. I have reset my ECU and still only 6psi. I'm thinking either my boost gauge is degraded or installed in the incorrect spot. Im not sure if I am getting waste gate only. I have taken some pictures. Also does anyone know where I can find a vacuum diagram? Maybe that will help. Thanks! Let me know if I should post some more pics?
^^^^^This one shows where the boost gauge was tapped^^^^^
Jerembo47 is offline   Reply With Quote
Old 11-03-2012, 05:04 PM   #2
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
If u adjust boost with mbc does the boost go up or down???
Is it tuned?
wrxlaunch is offline   Reply With Quote
Old 11-03-2012, 05:07 PM   #3
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
No MBC only stock boost controller.
Old 11-03-2012, 05:07 PM   #4
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
And I've never had a tune.
Old 11-03-2012, 05:10 PM   #5
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
Sorry I had an MBC on my old subie. Not this one
Old 11-03-2012, 05:41 PM   #6
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
On here it says mbc... sounds like u running on wg spring pressure.
Do a smoke test to make sure u don't have a leak.
Old 11-03-2012, 05:45 PM   #7
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
My bad I didnt mean to put MBC I meant stock boost controller.
Old 11-03-2012, 05:52 PM   #8
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Bcs may be bad.
Old 11-03-2012, 09:44 PM   #9
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
I cleaned the BCS and MAF sensor with maf sensor cleaner in accordance with this http://www.scoobypedia.co.uk/index.p...ontrolSolenoid
And still only 5-6 psi. Im going to try a leak test as soon as I can get the required equipment. Maybe get a new BCS or EBC Also I am going to get a new boost gauge and vac lines. If any one can think of anything else I can try please let me know. Thanks for all the input so far...
Old 11-03-2012, 09:52 PM   #10
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Ebcs, new vac lines without the pill and a tune or tweak and problem should be solved
Old 11-03-2012, 10:52 PM   #11
Leafy
Member#: 330625
2006 WRX
You are on WG spring pressure something is throwing the car into no boost mode because the ecu is not commanding a higher pressure. I bet its not tuned for that intake, running lean, knocking and the iam is at 0. To test this, disconnect the battery and press the brake pedal, then reconnect the battery. If you make more boost than 7psi on the first WOT run, stay out of boost on your way home and DO NOT drive the car again until you either get a tune or get a stock intake back on it.
Leafy is offline   Reply With Quote
Old 11-04-2012, 04:47 PM   #12
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
I have already rest the ECU by disconnecting the battery and it made no difference. This is the way the car came from the dealership. This is my daily driver that I have been driving in this condition for the past 6 months.
I had to get the carb sticker from the dealership so I could pass Cali emissions. The car runs great and is fast. Im thinking where they tapped the boost gauge was in an incorrect location. It is tapped off of the BOV. Would that make a difference in the reading?
And I do realize I spelled gauge wrong on the pic just too lazy to change it.
Old 11-04-2012, 05:06 PM   #13
stephens
Member#: 124581
What kind of boost gauge do you have and when you let off the gas what vacuum does it go to?
stephens is offline   Reply With Quote
Old 11-04-2012, 09:00 PM   #14
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
It is a glow shift gauge and when at idle it reads about 22 or 23 HG
Old 11-04-2012, 09:38 PM   #15
Leafy
Member#: 330625
2006 WRX
Thats a fine spot to pull the boost gauge from. For some reason the car is on waste gate pressure. You need to figure out why.
Old 11-04-2012, 09:48 PM   #16
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
maybe i just need a basic tune? I know Cobb will charge $500...
Old 11-04-2012, 09:53 PM   #17
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
The wife just informed me the dealership said the previous owner blew the original engine and they installed a new engine about 1000 miles before I bought it...
Old 11-04-2012, 09:59 PM   #18
lastsnare
Member#: 169539
2004 WRX sedan JBP
2013 BRZ GBS, 2000 2.5RS
I had a problem running at wastegate spring pressure after I swapped turbos (going from VF39 back to stock TD04). The newer turbo had the vacuum lines already on it, so I used those. Turns out, those lines were missing the restrictor pill. I fished the pill out of the old lines, inserted in the correct vacuum line, and voila, hitting correct boost again.
If you haven't already, make sure that you have the restrictor pill in there, and in the correct line. If it's not in there, you could easily have this exact problem.
If the 06 is the same as my 04 as far as restrictor pills goes, this might fix your problem. If I goofed that up, my apologies.
Use this diagram for reference (where the pill goes):
lastsnare is offline   Reply With Quote
Old 11-04-2012, 10:02 PM   #19
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
Can you see or feel the pill inside the vac line? like a bulge or something? Cause I was feeling and looking to see if I could tell which line it was in and I could not tell.
Old 11-04-2012, 10:09 PM   #20
lastsnare
Member#: 169539
2004 WRX sedan JBP
You should be able to feel a little hard ball in there yes (that's what she said), but you might not be able to see it. It doesn't matter where in that one vacuum line it is, as long as it's in the right line. The vacuum lines might be fairly stiff, but if you squeeze it hard with your fingers along the few inches of its length, you should be able to feel something. Worst case scenario, you could carefully slide off the little metal clips, pull the line off of the nipples, and poke something through it, like a piece of wire, to see if there is actually a pill inside, or if it's missing.
Old 11-04-2012, 10:47 PM   #21
Badler
Member#: 133597
BCS may be bad. Look on here how to test it with a battery. No CELs?
Badler is offline   Reply With Quote
Old 11-04-2012, 10:53 PM   #22
Leafy
Member#: 330625
2006 WRX
Yeah a bad bcs would though a cel, a un pluged bcs would throw a cell. Having the wastegate plumbed directly to the intake with no bcs in there might throw one for failing to reach the boost target. Having an IAM of 0 due to a lot of knock would make it target wg pressure but would reset the iam to 8 after pulling the battery irrc.
Old 11-04-2012, 11:19 PM   #23
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
No CEL's no Knock. Testing the BCS requires stripping the wires and I dont really feel comfortable doing that..., Unless im not reading the correct way to test?
Old 11-05-2012, 05:22 AM   #24
some dude
Member#: 100300
06 WRX
CGM
What's up with the 5" exhaust? Does the car have a stock down pipe? What about the butt dyno? Does it feel like it pulls hard or is it a wet noodle?
some dude is offline   Reply With Quote
Old 11-05-2012, 06:58 AM   #25
tunertype
Member#: 335033
2009 wrx
Dark Gray Metallic
It's not gonna be all that slow at 6psi boost. My car is under 6psi boost almost everywhere accept full throttle accel.
Some gauges are much cheaper than others. If it's an electronic gauge it could also have a delay so if your not in say 3rd or 4th and WOT for more than a few seconds at above 3krpm you might not see a high boost.
tunertype is offline   Reply With Quote
