Old 11-05-2012, 07:36 AM   #26
wiggitywagon
Member#: 317988
07 WRX wag
My vote is no restrict or pill.
wiggitywagon is offline   Reply With Quote
Old 11-05-2012, 07:37 AM   #27
wiggitywagon
Member#: 317988
07 WRX wag
If the intake caused that much problem, it would have thrown a CEL and possibly gone into limp mode (limp mode limits boost psi) but it hasn't.
Old 11-05-2012, 09:32 AM   #28
Badler
Member#: 133597
Originally Posted by Leafy View Post
Yeah a bad bcs would though a cel, a un pluged bcs would throw a cell. Having the wastegate plumbed directly to the intake with no bcs in there might throw one for failing to reach the boost target. Having an IAM of 0 due to a lot of knock would make it target wg pressure but would reset the iam to 8 after pulling the battery irrc.
It doesn't throw a cel for not reaching target boost. A bad/clogged BCS doesn't always throw a CEL either.
OP, check the BCS or if you don't feel comfortable take it somewhere. You can't rule it out until you test it.
Badler is offline   Reply With Quote
Old 11-10-2012, 10:55 AM   #29
Coryaskeland
Member#: 337197
Take intercooler off and look into the inlet(part that bolts to turbo). My engine and turbo blew and plugged up the intercooler. No boost on the outlet of intercooler but lots before it. That's where I would start looking its an easy part to get off. I was able to clean mine out and it had full boost again
Coryaskeland is offline   Reply With Quote
Old 11-10-2012, 09:09 PM   #30
thisisntjared
Member#: 177891
06 wrx wagon
child seat/tow hitch cgm
is the wastegate stuck wide open???
thisisntjared is offline   Reply With Quote
Old 11-10-2012, 11:26 PM   #31
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
Originally Posted by some dude View Post
What's up with the 5" exhaust? Does the car have a stock down pipe? What about the butt dyno? Does it feel like it pulls hard or is it a wet noodle?
Ummm, im not too sure if it has a stock down pipe? As for the butt dyno it pulls but not as hard as I think it should...
Jerembo47 is offline   Reply With Quote
Old 11-10-2012, 11:37 PM   #32
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
Sorry guys ive been working my ass off lately! I am going to check for the restricor pill first thing tomorrow morning.
Old 11-11-2012, 12:15 AM   #33
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
I had the same problem from the dealer on a used 12 sti..after hours of searching picked up the restrictor pill and problem solved :P
Shortpersonbk is offline   Reply With Quote
Old 11-11-2012, 09:27 AM   #34
thisisntjared
Member#: 177891
06 wrx wagon
on a side, are you sure the exhaust is 5in? or is just the muffler tip 5?
to find the diameter of the piping without taking it off, get measuring tape around the exhaust pipe and divide that measurement by Pi(3.14). also from the pics, that looks like the stock heat shielding for the stock dp.
Old 11-17-2012, 07:57 PM   #35
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
OK so... I checked the vac line and no restricter pill.
Old 11-17-2012, 08:20 PM   #36
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
OK so it is a 3" exhaust with a 5" tip.
Old 11-17-2012, 08:52 PM   #37
coalslaw
Member#: 324808
2006 IWL Stg2
dont make the same mistake previous owner did. buy a stock intake/cobb accessport/pill restrictor. put stock intake and restrictor pill, flash to stock tune then eventually to stage 1, using octane 91 always, occasionaly do drive bit hard to heat up and seal the piston rings and do proper break in process on new engine(lucky), down the road, a turboback exhaust(bellmouth downpipe included) and go for stage 2 and tune because of the SPT intake. I cant wait to have my st2 mode on soon!
coalslaw is offline   Reply With Quote
Old 12-01-2012, 11:01 AM   #38
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
Well... I installed the restrictor pill and I do notice a little more power and I can hear the turbo spool up a lot quicker but my boost gauge is only showing about 8psi now. I am going to get some new vac lines today... Anyone know of a tuning shop in the San Diego area? And how much does a basic stock map install go for?
Old 12-10-2012, 04:23 PM   #39
coalslaw
Member#: 324808
2006 IWL Stg2
Acessport = $595
All maps for accessport= free download on cobb's website
Old 12-10-2012, 04:25 PM   #40
Leafy
Member#: 330625
2006 WRX
Originally Posted by coalslaw View Post
Acessport = $595
If he was local to me and didn't require me to drive anywhere to meet him I'd reflash him to stock for 20 bucks, or a case of beer.
Leafy is offline   Reply With Quote
