#1 |
Member#: 301089
NESIC
Vehicle:2011 WRX 5 door TP stage 2 |
PTP has released a new Subaru turbo blanket for us, made from the Lava materials that they sucessfully use in their other products.
With an outer layer made from actual pulverized volcanic lava rock (continuous-filament basalt) formed into fabric and woven into a tight mesh weave, these turbo blankets are internally insulated with high temperature calcium magnesium silicate wool, overlaid with a high temperature silica fabric for increased durability and for improved thermal resistance. The Lava Turbo Blankets are designed to withstand the harshest of conditions. PTP Subaru Lava Turbo Blankets are designed to fit all stock Subaru WRX/STI turbochargers. They also can fit many other after market turbochargers with internal wastegates. DISCOUNTED LAVA BLANKET $$115.99 HERE--------> http://forums.nasioc.com/forums/show....php?t=2498473 Subaru WRX Turbo Blanket - Lava Heat Tolerance: Interior Surface: Max Temperature Rating: 2300 Deg F/ 1260 Deg C Continuous Use Limit: 1800 Deg F/ 982 Deg C Exterior Surface: Direct Contact Limit: 1800 Deg F/ 982 Deg C Radiant Heat Limit: 2500 Deg F/ 1371 Deg C ![]() comparison to the original turbo blanket ![]() ![]() As you can see the new lava blanket is slightly larger than the original blanket. This size difference is really great and now covers the downpipes flange and has much better coverage with this slight size increase.
#2 |
Member#: 301089
NESIC
The testing portion for this new lava blanket is running the wrx until operating temperature is reached, than running the car for an additional 15 minutes. The infrared shots are taken when the car is running in a 68F room. The car has done the majority of the idling outside at around 55F before being brought into the 68F garage.
![]() these next infrared shots are of the original ptp turbo blanket. ![]() the original blanket is 174F GRIMMSPEED heatshield temp with DEI gold foil 95F ![]() Now here are the infrared shots of the new PTP LAVA Turbo blanket ![]() GRIMMSPEED heatshield with DEI gold foil, and PTP LAVA turbo blanket ![]() 174F-136F=38F difference between the original and new LAVA turbo blanket. the heatshield difference is 95F-63F= 32F Last edited by HeroCrank; 04-16-2013 at 04:01 PM. |
#3 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
Wait, what?
At what temperature are you warming this car up at? You said the testing is in a 68F room, yet the heat shield is 63F, so clearly the car was warmed up/driving in a cooler environment than this. How does this environment compare to the one when the original testing was done? |
#4 |
Member#: 301089
NESIC
So, after receiving, installing, and testing of the new LAVA turbo blanket, I am very impressed with this product. The quality of the blanket is top notch and performs very well. The total temperature difference is 70F compared to the original turbo blanket. The original blanket msrp is 84.99 while the LAVA blanket carries a msrp of 139.99. That is a difference of 55.00. So for 55 more dollars you can eliminate 70F more than with the original blanket, which equates to about 1.27 per degree F. Now when your looking at trying to bring your underhood temps down, every degree counts and this is an easy way to pick up those extra numbers that you are looking for.
![]() Last edited by HeroCrank; 04-26-2013 at 11:32 AM. |
#5 | |
Member#: 301089
NESIC
ah the car was running outside at 55F than brought into the 68F garage as to not fill the area with exhaust. |
#6 |
Member#: 336204
Vehicle:1979 Z28 Camaro Burgundy |
That seems like a very good product, I may have to buy that for my Subaru when I buy it. Thank you!
#7 |
Member#: 328133
Vehicle:2006 Subaru Forester Repo grey |
Arg. so this comes out a month after I bought the original ptp blanket...I feel like I just bought last year's iPod.
![]() P |
#8 |
Member#: 51961
RMIC
#9 | |
Member#: 51961
RMIC
#10 |
Member#: 303849
Vehicle:2004 Forester Xt Silver stg2 |
i just buy the blanket too
now i want the lava rock one too |
#11 | |
Member#: 301089
NESIC
#12 |
Member#: 301089
NESIC
#13 |
Member#: 301089
NESIC
its the same outside temp for both. no radical changes in weather up here yet. the difference in turbo temps that your probably refering to are from slight differences in idle times, but all are very close to being the same. I have images that support that a 10-20F varience in turbo temps doesnt change the outside blanket and heatshield numbers by more than 1 to 5 degrees F. sometimes getting the right infrared shot takes time but all results are definitley accurate and one can expect similar ballpark results when taking any environment differences into account.
#14 |
Member#: 301089
NESIC
#15 |
Member#: 1130
Vehicle:2013 STI Hatch DGM |
Will the wrx blanket fit an sti? It's on a 2013...
#16 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
#17 | |
Member#: 301089
NESIC
I thought the results were awesome, I was surprised how much better the lava blanket is. I will get you the pics after some agressive driving this week. |
#18 |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
Next time you shoot that heat sheild put a piece of tape somewhere on it and compare the temp of the tape to the temp of the heat shield itself.
#19 |
Member#: 152036
E. Canada
Vehicle:2004 Sti PSM |
Do think that will fit a 20g turbo ?
#20 |
Member#: 301089
NESIC
#21 | |
Member#: 51961
RMIC
You wouldn't stick three pots of water outside, measure a 10 deg drop in each, and say that the outside temperature dropped by 30 degrees would you? Add another pot and it's now a 40 deg drop. When you start doing that, the numbers become meaningless. It's really detracting from the validity of your tests for anybody who knows what they're looking at. I promise you, anybody who looks at the numbers and sees what you've done to get that "70F" number will start to question the legitimacy of the rest of the test setup. Especially since no outside temperature is listed for the tests, just the 68F room in which you're doing the tests, which, since the car is spending almost no time in there, doesn't matter. If the outside temp really didn't change at all, and the idle time is the same in both tests, then those are impressive results. Last edited by the suicidal eggroll; 11-09-2012 at 10:00 AM. |
#22 | ||
Member#: 261612
It should fit any stock location Subaru turbo (ie. uses the Subaru style downpipe). Quote:
![]() But I do agree that it's misleading. Unless there was some standard of X measurements in Y different locations that everyone used, then it could be meaningful. But there's not. Still great results. |
#23 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
#24 | |
Member#: 51961
RMIC
![]() Agreed |
#25 |
Member#: 228059
Vehicle:2010 WRX Spark Silver Metallic |
Those cameras typically have an adjustable emissivity value, correct? Out of curiosity, what did you have it set to for testing?
