Old 11-08-2012, 04:22 PM   #26
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
ahhh so the sound IS the same just much louder (i did notice that in the video that it was louder) i was thinking it was suppose to sound deeper or something in sound. ok good to know! yes louder is good. thanks! ill have to try this once i get my foglights in if subarupartswarehouse ever decides to ship them to me.
Originally Posted by gfxguy View Post
Tonally they're similar to the stock horn, just much louder. Most recordings probably clip/compress the volume. My son didn't react when I was testing out the oem horn in the garage, but when I tried the supertones for the first time he shouted from the house "what was THAT?" . Testing them even with short bursts in a closed garage is borderline painfully loud.
Blackmamba24kb is offline   Reply With Quote
Old 11-08-2012, 04:37 PM   #27
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Originally Posted by flyboy1100 View Post
There has to be some other ground nearby to use
There's the oem horn ground (where it's attached to the frame), but either way I'm going to have to create a new ground harness so I may as well just go straight to the battery.
gfxguy is offline   Reply With Quote
Old 11-08-2012, 05:28 PM   #28
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I don't like that idea. I suppose it didn't make much difference, but usually you don't bring straight to the battery for anything
flyboy1100 is online now   Reply With Quote
Old 11-09-2012, 04:29 AM   #29
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Originally Posted by myrt1987 View Post
lol i think he meant the crazy driver was the idiot.
Oh that makes sense.
pkL is offline   Reply With Quote
Old 11-17-2012, 09:16 PM   #30
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
got my horns installed today, here is how it turned out. I made my own bracket out of a piece of 1/8" steel I had laying around and made my own harness. took around 3.5 hours including waiting for paint to dry and building my harness.
the factory connector can be cut off an old horn and used for the harness, it is just plastic and when you cut/melt away enough plastic there is a nice metal ring that can be soldered too, which is what I did.
there is a cover on the fender to the right of the battery that i removed and mounted my relay there, it should be completely out of the elements in that location.
Old 11-17-2012, 09:47 PM   #31
Brian Vantana
Member#: 314834
2012 Impreza
Dark Metallic Grey
Nice work.
Brian Vantana is offline   Reply With Quote
Old 11-20-2012, 08:34 PM   #32
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Looks great! I like the bracket, did you remove the bracket that comes attached to the horns (the one they tell you not to remove)?
Old 11-20-2012, 09:44 PM   #33
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
where does it say to not remove them? and yes i removed them
Old 11-20-2012, 10:17 PM   #34
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
1 (D) in the instructions. "The bracket is part of the horn assembly. Tighten or loosen the nuts of the bracket or bending the bracket will change the functionality and you will loose the warranty." (Bad grammar/spelling theirs.)
I doubt it matters much, other than voiding the warranty.
Old 11-20-2012, 10:23 PM   #35
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I didn't read the instructions....
I'm not sure how removing the bracket changed the functionality, they are still 80% louder than stock
Old 04-08-2013, 01:34 PM   #36
Angelus911
Member#: 89967
2012 Impreza Sport
Any tips on how to remove the brackets that come on the horns? Those nuts will not budge, and I need to remove them in order to use the Subimods bracket that I got.
Angelus911 is offline   Reply With Quote
Old 04-08-2013, 01:40 PM   #37
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
vise with rubber pads, thats what I used
Old 04-08-2013, 03:06 PM   #38
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
sgoldste01 is offline   Reply With Quote
Old 06-15-2013, 10:28 AM   #39
QAboy
Member#: 21711
2012 2.0i Premium
Ice Silver Metallic
So I just pulled my bumper (doing some other work too) and I'm seeing one horn near the bottom center of the radiator as well as smaller one under the passenger headlight. Main horn and alarm? Any input would be great!
QAboy is offline   Reply With Quote
Old 06-15-2013, 10:22 PM   #40
CLL_OBP
Member#: 310435
'12 Sp Limited
M1 EP 0W20 104,640 miles
^The one on the bottom is Hi frequency and the one under the passenger headlight is the Low frequency.
CLL_OBP is offline   Reply With Quote
Old 11-21-2013, 09:09 PM   #41
USAFAndrei
Member#: 352158
2012 Impreza
Metallic Grey
USAFAndrei is offline   Reply With Quote
Old 11-22-2013, 12:41 AM   #42
CLL_OBP
Member#: 310435
'12 Sp Limited
Originally Posted by USAFAndrei View Post
Nice logo and trim. Are you @ Hanscom by chance?
Old 11-22-2013, 03:09 AM   #43
USAFAndrei
Member#: 352158
2012 Impreza
Metallic Grey
Yup. You at Hanscom?
Old 11-22-2013, 05:54 AM   #44
CLL_OBP
Member#: 310435
'12 Sp Limited
No, civil service on Pope / Fort Bragg but I am prior USAF and USAFR.
Old 11-22-2013, 05:57 AM   #45
USAFAndrei
Member#: 352158
2012 Impreza
Metallic Grey
Nice. It's nice to be at hanscom. I've lived in this area for 13 years so I know it well. What was your afsc?
Old 11-22-2013, 09:48 AM   #46
CLL_OBP
Member#: 310435
'12 Sp Limited
I can appreciate living in one area for a while. Moving all the time gets old after a while. I was a 3E1 (HVAC) and later crossed trained into 6F0 (FM).
How did you replace the emblem on the grill? I tried on the OEM grill and that sucker is on there pretty good.
Old 11-22-2013, 03:39 PM   #47
USAFAndrei
Member#: 352158
2012 Impreza
Metallic Grey
They are just overlays. The carbon fiber vinyl is really strong. The stuff doesn't move around or peel at all. I've had them on for a year now and I drive my car a hell of a lot. You can choose any color for the stars and any color for the background. I've got a theme going so I chose carbon fiber and red stars.
http://www.jdmfanaticvinyls.com/12-13-impreza-wagon/
Old 11-22-2013, 03:55 PM   #48
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
Put a socket on it and smack the handle of the wrench. Boom done.
My install:
TRSAndrew is offline   Reply With Quote
Old 11-24-2013, 08:01 PM   #49
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Still have my hella trumpet horns sitting in my garage because I could never get them to work. Someone should give me a dumbass-proof diagram of what to do with the relay like this- http://imgur.com/9dhaDou
Although I still am tempted to not do it because my bumper never reattached right and I could only get 2 screws back in the grille due to the ****ty access.
goregasm is offline   Reply With Quote
Old 11-24-2013, 09:18 PM   #50
JMOLINAR
Member#: 366852
I found a stubby phillips screwdriver really helped with putting the screws into the grille
JMOLINAR is offline   Reply With Quote
