Old 11-24-2013, 11:35 PM   #51
USAFAndrei
Member#: 352158
2012 Impreza
Metallic Grey
Finished the new project. LED's spliced with left parking light.
USAFAndrei is offline   Reply With Quote
Old 11-24-2013, 11:39 PM   #52
kinger37
Member#: 324423
2012 Impreza Sport
ISM
You need to put white led's in your corner eyebrow lights now
kinger37 is offline   Reply With Quote
Old 11-25-2013, 01:16 AM   #53
USAFAndrei
Member#: 352158
2012 Impreza
Metallic Grey
Yea im thinking that too. Sucks getting the grille off tho so annoying I've done it like 5 times now.
Old 11-25-2013, 02:22 AM   #54
USAFAndrei
Member#: 352158
2012 Impreza
Metallic Grey
Old 11-25-2013, 06:38 AM   #55
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
That's why you just drop the bumper instead. Super easy.
TRSAndrew is offline   Reply With Quote
Old 11-25-2013, 08:03 AM   #56
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
How do?
goregasm is offline   Reply With Quote
Old 04-26-2014, 10:20 AM   #57
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Bump for an old thread.
Just finished installing my Super tones after an accident where the guys car rolled backward into mine (yes there was plenty of space but never enough when they dont hear your horn and are oblivious for the 5-6 seconds the car is rolling back on a hill)
I did install them like the OP they are VERY loud.
auskip07 is offline   Reply With Quote
Old 04-26-2014, 10:51 AM   #58
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
Glad to hear it worked out. Ive had the supertones for a number of months now and hardly ever use them even though Im in SD and actually should be using them on a daily basis.
Sometimes with loud horns I think they may actually be dangerous scaring people into hitting their brakes or the number of motocycles that are lane splitting...
CalTech87 is offline   Reply With Quote
Old 04-27-2014, 09:53 AM   #59
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
in my case scaring someone into hitting their brakes would have been a good thing. They are certainly scary loud. My wife had to cover he ears when she heard them.
Old 08-04-2014, 09:03 AM   #60
Dill-Ag13
Member#: 316535
2007 WRX (Sold 2.0i)
Three questions:
1. Can someone advise me on how to remove the OEM horn wire socket/plug? I've yanked the heck out of it but it won't budge.
2. Can I ground both the horns and the relay to the same M6-1.0 mounting position suggested in the OP?
3. All wires are single strand, correct?
Dill-Ag13 is offline   Reply With Quote
Old 08-04-2014, 12:22 PM   #61
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Originally Posted by Dill-Ag13 View Post
Three questions:
1. press down on the tab and pull.
2. why would you run all that grounding wire. Ground it to the nearest point. Grounds are dumb and not picky
3. No idea what you mean
Old 08-04-2014, 01:13 PM   #62
Dill-Ag13
Member#: 316535
1. What tab? I am unable to find a tab to press down on.
2. I have it lying around and I'd like to neatly ground it to the same point since I have wires running that direction anyways.
Old 08-04-2014, 02:07 PM   #63
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
The tab to the horn that is on the middle bottom of where you are mounting the new horns. Feel around for it. Find the ridged part and squeeze and pull. That is where i ran my signal wire for the relay.
Old 08-04-2014, 02:55 PM   #64
Dill-Ag13
Member#: 316535
Ok, I'll give it a look, thanks
Old 04-09-2015, 09:39 AM   #65
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
So do you have to remove the bumper on a 2012+ Impreza to do this install, or is removing the grill sufficient?
sgoldste01 is offline   Reply With Quote
Old 04-09-2015, 09:44 AM   #66
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
Grille is sufficient but do yourself a favor and do the bumper. This will give you a lot more room for routing the wires the way you want.
I did grille first and then later when I did a retrofit I re did the wiring. So if youre planning anything for the future...
Old 04-09-2015, 09:56 AM   #67
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Thanks for the suggestion.
How hard is it to remove the bumper (and then, more importantly, re-install it with proper alignment)?
Old 04-09-2015, 10:10 AM   #68
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Sgold,
Check out my post here http://forums.nasioc.com/forums/show...php?p=38519042
I just removed the grill and had plenty of space to wire everything on mine
Old 04-09-2015, 02:56 PM   #69
legacynub
Member#: 402628
2014 impreza
deep sea blue pearl
for those that used the subiespeed bracket, how did you get it to fit? my horns keep hitting the grill.
legacynub is offline   Reply With Quote
Old 04-09-2015, 03:42 PM   #70
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Old 04-09-2015, 04:55 PM   #71
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I don't remember which ones I bought. But one comes with a small bracket and the other does not.
Relay holder and fuse holder are good ideas. I think the relay I used already haa a bracket though? I made my own harness too by citing connector off factory horn
Old 04-10-2015, 01:58 AM   #72
Vjaramillo
Member#: 359666
2013 Impreza limited
Ice silver
@legacynub...you have to trim some of the plastic from the grille. You also need to loosen the latch bolt and make sure the bracket slides under it. At least that's what I had to do.
Vjaramillo is offline   Reply With Quote
Old 04-10-2015, 06:47 AM   #73
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Oh ya, me too
Old 04-10-2015, 11:47 AM   #74
legacynub
Member#: 402628
2014 impreza
deep sea blue pearl
Do you have pictures of the trimming? The bracket goes behind the latch??
Old 04-10-2015, 12:48 PM   #75
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I probably posted a pic on the giant thread about the trimmings. Nothing major it is just on 1 side and a little bit.
My bracket is in front of the latch, go pack a few pages and look at my pics
