Old 11-23-2012, 04:07 PM   #1
fullCircling
Member#: 290547
Default 2010 Dual AVCS Heads - What ECU to use?
What would be a good ecu to use for my application? I've got a '97 legacy that I'm putting a Dual AVCS STI swap into, and I'm not sure on what to use to control the dual AVCS.
Any suggestions?
fullCircling is offline   Reply With Quote
Old 11-24-2012, 09:07 AM   #2
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Syvecs S6GP ;-)
jkopinga is offline   Reply With Quote
Old 11-24-2012, 01:55 PM   #3
fullCircling
Member#: 290547
lol $1200 max plz
Old 11-25-2012, 01:36 PM   #4
fullCircling
Member#: 290547
bumpp
Old 11-25-2012, 09:19 PM   #5
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
To run those heads and use the avcs, you are gonna need all the sensors and wiring and ecu from the donor car, it is can bus. Or a vipec/link g4. Or AEM v2. They dont cost as much as syvecs i dont think. I just ordered a vipec v88 ($2250) to do something simillar. Its not going to be less than $1200 sorry. I have a davcs motor going in my 04 wrx.
Old 11-26-2012, 01:30 AM   #6
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Are there any devices on the market that could be used to control just the exhaust AVCS actuators? With something like that perhaps you could stick with the single-AVCS ECU and tune the exhaust AVCS separately.
I'm just not sure if the necessary widget exists...
Old 11-26-2012, 11:49 AM   #7
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
I suppose a person could drive the solenoids and sensors with a micro controller, but its so tied in with the engine computerand whats its doing, its probably a good idea to controll it all at the same time with the same device. Thats why i like the vipec/link. It has map switching, als, ffs, etc. and bunch of inputs and outputs and easily configurable.
Old 11-27-2012, 01:58 AM   #8
NSFW
Member#: 140444
05 Stage Free LGT
I'm sure integration would be nice, but I suspect you could get almost all of the benefits of DAVCS just with a microcontroller that watches RPM and boost and gives you a table to control the exhaust cam. It'd be a little bit tricky to align that table with the ECU's Load-vs-RPM table, but it doesn't seem like a big deal.
It's just a little bit past the edge of what I'd feel comfortable creating on my own, but if I go for a built motor I'll consider taking the leap. It would be neat to make it happen.
Old 11-27-2012, 04:13 AM   #9
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
What's the point doing a nice engine swap for a lot more coin than a proper ECU? Do yourself a favour and get a proper Standalone that will control all cams properly as well as other features needed. I know it's not cheap but it just makes the car so much more reliable and drivable. Complete integration is what you should target for.
Cheers,
Jasper.
Old 11-27-2012, 06:45 AM   #10
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Nsfw, if you are that interested in a microcontroller style do it yourself deal, then i would check out the megasquirt. If you like building stuff im pretty sure it comes as a board and bags of components. Personally i wouldnt risk the cost of a built motor as jkopinga suggested, but maybe for a beater project.
Old 11-27-2012, 09:29 AM   #11
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
engine bay, dash & ecu harness from 06-07 sti..
Old 11-27-2012, 09:43 AM   #12
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Will the 32 bit ecu from the 07 run the dual acvs heads? I know some people have blocked of the exhust port avcs with a plate machined to still alow oil to the cams.
Old 11-27-2012, 02:15 PM   #13
fullCircling
Member#: 290547
I'm not really down with using some sort of piggyback controller. Seems kinda backwards for what I'm trying to do.
I really like the Link G4's, and it looks like I could get ahold of one of those used that would be in my price range... I love how bombproof these things are! See?
buutttt...
what OEM ECU options do I have? ECU wise, what would I have to do to pass New York state inspection? can i disable the other systems that are tied into an OEM dual avcs ecu (ABS?, VCD, etc) I don't wanna have to add VCD or something just to be able to pass inspection w/ dual avcs...
Old 11-27-2012, 02:50 PM   #14
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Ok so if you keep your oem ecu and leave it wired in to your obd stuff and use a link/vipec to run the motor, you can use open source or access port to keep the check engine light off and happy. That may get you past state inspection.
That is my plan to pass inspection. Hopefully ill be up and running by summer ill let you know.
In your case, i dont think the ecu controls your abs, etc. They are separate systems. Maybe an old wrx ecu would get you by, depending on whether your state looks at what the ecu and vin info is for the test.
